POV-Ray : Newsgroups : povray.advanced-users : Use of povray functions to make fractals other than "famous" Mandelbrot with same scalability? Server Time
28 Jul 2026 18:19:03 EDT (-0400)
  Use of povray functions to make fractals other than "famous" Mandelbrot with same scalability? (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Use of povray functions to make fractals other than "famous" Mandelbrot with same scalability?
Date: 3 May 2003 07:47:24
Message: <3eb3ac4c@news.povray.org>
Warp wrote:
>   If POV-Ray supported recursive functions, then you could do them with
> those.
>   In fact, I implemented the Mandelbrot pattern as a recursive function
> in a prototype version of POV-Ray 3.5, and it worked ok (it was acceptably
> fast).
What du you need recursion for?  Most fractals I know of
(Mandelbrot included) are computed in simple iterations,
as in (pseudo-code):
FOR Y-coordinates [of the entire fractal image]
   FOR X-coordinates
     WHILE conditions (i.e.: |Z| < 4 AND num_loops < max_loops)
       Iterate function (i.e.: Z = Z*Z + C [Mandelbrot])
     END
     Draw Pixel
   END
END
Any end-recursive function can be written as an iteration.
And in most cases the iterative version will be faster.
> It's a bummer the recursion support didn't completely work out.
That is true, however. ;)
g.
++++++++++++++++ http://www.psico.ch/ ++++++++++++++++
Date: 3 May 2003 10:29:37
Message: <cjameshuff-5D3960.10291803052003@netplex.aussie.org>
You can make an iterative version of any recursive algorithm. However,
the recursive version is often much simpler, and most fractals are
mathematically defined as recursive because of the self-similar nature
of fractals. At the time this was written, POV supported function
recursion, but it still does not support loops, though you can imitate
it using a long string of select() calls.
http://tag.povray.org/
Date: 3 May 2003 11:14:04
Message: <3eb3dcbc@news.povray.org>
AFAIK this is only proven to be true for end-recursive algorithms
(though /many/ of the functions with a single recursion call can
be made end-recursive; but you will usually run into trouble if
the algorithm has multiple recursive calls).
> However, the recursive version is often much simpler,
I agree, but it depends on how you look at it.  For people
not too familiar with the concept, an iterative function
is far easier to grasp. - And, as I mentioned before, it's
faster (and more efficient) in almost every case (Note that
I speak as a programmer here, not as a mathematician).
 > and most fractals are mathematically defined as recursive
 > because of the self-similar nature of fractals.
Can you elaborate on this kind of definition?
   I don't doubt this, I just think that one can as well
define them by iterative means ("As long as the conditions
are not fulfilled, do repeat...").
   However, I doubt that the relation between recursion and
self-similarity is as strong as you think.  Recursion is
often (ab-)used in order to make code look slick, when in
fact it isn't.
You mean "does not support loops" because there is no
proper stack to store (local) variables on?  In this
case, yes; but I'd prefer to solve (not "imitate") this
by implementing one - *if* I *really* need to... ;)
BTW, Christopher, what is your profession?
g.
9) Count the number of odd entries in the 100th row of
Pascal's triangle.
Date: 3 May 2003 12:08:03
Message: <3eb3e963@news.povray.org>
  POV-Ray functions do not support iterative control structures. The only
way of making a loop with functions is using recursion (as in any functional
language).
Date: 3 May 2003 12:13:41
Message: <3eb3eab4@news.povray.org>
  Not true. It has been proved that there are recursive algorithms which
can't be implemented as iterative ones.
  (The difference between recursive and iterative algorithms is the
amount of memory they require: If the amount of memory required by the
algorithm is directly proportional to the amount of loops performed
(typically when you need a stack) then it's recursive. If the amount of
memory needed is constant, ie. doesn't depend on the amount of loops,
then it's iterative.)
Date: 3 May 2003 12:37:40
Message: <3eb3f054$1@news.povray.org>
> language).
I see that now...  I have just tried to do that
fractal pigment function thing myself.  What a pity! :(
<sulk>
Now I just feel like never calling the POV-Ray language
a "programming language" again!!
</sulk> ;)
g.
Be very careful to never use Date::Manip twice in the same
program, or you could form a black hole! :-)
  -- Randal L. Schwartz
Date: 3 May 2003 12:48:20
Message: <3eb3f2d4$1@news.povray.org>
> language).
One more thing: Neither does it support conditional
structures like "#if ... #else ... #end" nor "(C ? A : B)",
AFAICS in the docs.  So, One would have to workaround this
using "select"; now I understand why Christopher mentioned
that..!
Thanks,
g.
Date: 3 May 2003 12:58:47
Message: <3eb3f547@news.povray.org>
> AFAICS in the docs.
  It does. It's called 'select'. 'select' is not a workaround, it's a
conditional structure.
  In theory adding the support for recursive function calling should
be easy (AFAIK you could simply remove the existing check which stops
the parsing if recursion is detected). The problem is that there seems
to be cases where it doesn't work ok, and fixing it to work always may
need severe work. For simple recursive functions it should work ok (at
least according to prototype tests).
  (I don't know if it would be a good idea to enable recursion in a patched
version of povray because of the detected instability, but a personal
version would be interesting to try.)
Date: 3 May 2003 13:38:04
Message: <3eb3fe7c@news.povray.org>
>>AFAICS in the docs.
[And gimi also wrote:]
 >> So, One would have to workaround this using "select";
 >> now I understand why Christopher mentioned that..!
Of course 'select' isn't a workaround in itself, but its
use as a conditional *structure*.  In a practical sense,
it is of course the same, but I would be careful not to
speak of a "structure" if it's in fact a function or
operator.  After all, there must be a reason why there
*are* conditional structures, and not just functions,
in programming languages!?
It is listed as a float function in the docs, and I
prefer to put it in the same drawer together with the
signum function, or even the '<=>' operator (Perl).
Or would you call "if ... then ... else" a function?
However, as far as POV-Ray is concerned, I don't know
how these different statements are implemented, nor if
it means anything whether it's called a function or
not...
I can't help getting the feeling that this POV-language
design or implementation is a little messy...
It certainly would!  OTOH, I think that this would better
be accompanied with some major redesign... - SCNR ;)
Have a nice weekend, I'm off...
gimi
"What right does Congress have to go around making laws
just because they deem it necessary?" -- Marion Barry
Date: 3 May 2003 13:44:26
Message: <3eb3fffa@news.povray.org>
  Have you taken a look to a (purely) functional language?
  Purely functional languages do not have loops (or other things like
assignment to a variable).
