POV-Ray : Newsgroups : povray.advanced-users : Saving an object? Server Time
18 Oct 2026 14:26:59 EDT (-0400)
  Saving an object? (Message 1 to 15 of 15)
Subject: Saving an object?
Date: 7 Apr 2003 10:34:28
Message: <3e918c74@news.povray.org>
Is there any way to save an object (IE, a union of lots of other objects) to
disk and then read it back in?
THis could potentially save me tons of parsing time if there's a way to do
it.
Subject: Re: Saving an object?
Date: 7 Apr 2003 10:38:56
Message: <25339v4nfh9cf54is5t498luhelf2uoj5c@4ax.com>
On Mon, 07 Apr 2003 11:33:31 -0400, Tyler Eaves <tyl### [at] hotpopcom> wrote:
> it.
During first parsing you can parallel create file on drive with equivalent of
content you creating for parsing. This is common habit in case of creation of
meshes. For example look for HF_* macros in standard distribution. There is a
parameter for choosing output to file.
ABX
Date: 7 Apr 2003 10:42:23
Message: <3e918e4f@news.povray.org>
>> to disk and then read it back in?
>> do it.
> of content you creating for parsing. This is common habit in case of
> creation of meshes. For example look for HF_* macros in standard
> distribution. There is a parameter for choosing output to file.
> ABX
That makes sense.
Date: 7 Apr 2003 10:44:28
Message: <3e918ecb@news.povray.org>
>> do it.
> ABX
Ack, hit send too soon.
What I was really hoping for was some sort of binary save,
ala photons. But that'll help, since my code is VERY loop intensive.
Speaking of that, is there any real speed hit for unioning a number of
objcets together, as opposed to not unioning?
Date: 7 Apr 2003 10:49:31
Message: <1m339vs90olfojbaueda0sol14kc4quh0o@4ax.com>
On Mon, 07 Apr 2003 11:43:31 -0400, Tyler Eaves <tyl### [at] hotpopcom> wrote:
> ala photons.
AFAIK photons related files are not binary. They are probably fully portable
ascii files. Supported portable format for exchenging objects are ascii files
with scripts written in SDL.
As usually depends it depends on situation. Hard to say without knowing objects,
environment, complexity of scene.
ABX
Date: 7 Apr 2003 12:32:19
Message: <3e91a812@news.povray.org>
> objects, environment, complexity of scene.
One thing I've done, that helps quite a bit, is calculating the posistions
where the objects should be placed along the spline in my python code.
so instead of doing something akin to.
#while(pos < end)
#declare d = d + distance_from_the_last_point;
#if (d > somenumber)
#declare d = 0;
//Do something
#declare pos = pos + .0001
Now I loop over an array of the positions. Helps quite a bit.
Date: 7 Apr 2003 12:53:27
Message: <3E91AD06.89BA2DBF@gmx.de>
> > ala photons.
photons are not stored in ascii but in binary form.  This of ocurse also
means that photon data files are not as portable as POV-Ray itself.  This
does not matter that much since photon data is not really intended to be
moved between different platforms.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 7 Apr 2003 12:55:31
Message: <78b39vs5bju40d2eu1otajq7hksq0imic0@4ax.com>
On Mon, 07 Apr 2003 18:53:26 +0200, Christoph Hormann <chr### [at] gmxde>
So there is no way to use photons data for multiplatform distributed rendering ?
I'm surprised.
ABX
Date: 7 Apr 2003 13:39:38
Message: <3E91B7DA.D12CC40A@gmx.de>
> I'm surprised.
Not necessarily, the most common platforms are compatible in terms of the
photon data (there are no byte order problems, only non-IEEE floating
point numbers will be difficult).  But as i said this compatibility is
less than what is possible with POV-Ray itself.
Date: 7 Apr 2003 15:32:23
Message: <3e91d247$1@news.povray.org>
In article <78b39vs5bju40d2eu1otajq7hksq0imic0@4ax.com> , ABX
> I'm surprised.
Since when is "multiplatform distributed rendering" a feature of an official
version of POV-Ray?
    Thorsten
e-mail: tho### [at] trfde
Date: 8 Apr 2003 04:25:38
Message: <qa159vss0903hu8oms990f7nees385mv0q@4ax.com>
On Mon, 07 Apr 2003 21:32:24 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> > So there is no way to use photons data for multiplatform distributed rendering?
> > I'm surprised.
> version of POV-Ray?
It's very popular to split animation into parts rendered on various machines.
6.10.5.4: "The photon map itself is view-independent, so if you want to animate
a scene that contains photons and you know the photon map will not change during
the animation, you can save it on the first frame and then load it for all
subsequent frames". Perhaps this should be extended about binary nature of this
file and portability limitations.
ABX
Date: 8 Apr 2003 05:46:57
Message: <3e929a91@news.povray.org>
In article <qa159vss0903hu8oms990f7nees385mv0q@4ax.com> , ABX
No, because that is not of concern of, nor understandable by, users.  There
is such a thing as "too much" documentation for users.  Keep in mind this
document isn't a software engineering style document, but a simple user
manual.  Users are not be able able to understand what is behind it because
they cannot know the technical background.  Thus, it doesn't belong into a
user manual.
    Thorsten
Date: 8 Apr 2003 14:20:09
Message: <web.3e9311feaefa053934dff4bb0@news.povray.org>
Thorsten Froehlich wrote:
>In article <qa159vss0903hu8oms990f7nees385mv0q[at]4ax.com> , ABX
>user manual.
>    Thorsten
Then maybe there need to be two manuals.  One for regular users, and one for
power users.  The first one could be a stripped down version of the current
documentation, since it already has several topics that are covered in
graphic mathematical detail.
The second one could be a beefed up version of the current documentation,
for those who are curious about how the innards work, without having to
resort to the most in-depth documentation, i.e. the source code.  I find
myself venturing into the code to see how things work that should be
documented, such as how POV-Ray handles refraction between multiple objects
(such as water in a glass bottle; see my thread a couple posts before this
one).
In fact, my latter example (refraction) is not some esoteric quirk that no
one will ever use.  It is a very commonly used feature that, in my opinion,
was implemented incorrectly.  Had there been better documentation, perhaps
the design team would have found the flaw earlier (nothing points out a
mistake like trying to document how something works), or someone else would
have come forward with a fix earlier.
Subject: Re: Saving an object? - Thanks!
Date: 8 Apr 2003 15:21:05
Message: <3e932121@news.povray.org>
I've cut the parse time for a single frame from 45 seconds to 6.5 seconds.
Slight improvement when doing a 1500 frame animaiton *g*
Date: 8 Apr 2003 23:49:15
Message: <3E939830.4BDDD1F3@pacbell.net>
> power users.
You obviously have no clue what is involved in just maintaining the current
documentation and all the hard tedious work that went into getting it where
it is now.
Ken Tyler
