![](/i/fill.gif) |
Danni Coy <rgc### [at] midcoast com au> wrote:
> I am writing a plugin and I am not certain of how to
> use the two vector statements in the area light setup.
> I need to generate these after the user has specified the
> to and from points of the light and the height and width of
> the area plane.
You can create the area light at the origin, use the Point_At_Trans()
macro to reorient it so that it heads to the correct direction and then
translate it to its place.
It could look like this:
light_source
{ 0, COLOR
area_light x*WIDTH, z*HEIGHT, ACCURACY, ACCURACY
adaptive ADAPTIVENESS
Point_At_Trans(TO-FROM)
translate FROM
![](/i/fill.gif) |
