POV-Ray : Newsgroups : povray.advanced-users : What is HDRI? Server Time
5 Nov 2026 00:38:37 EST (-0500)
  What is HDRI? (Message 1 to 33 of 33)
Subject: What is HDRI?
Date: 11 Jan 2003 12:19:33
Message: <3e205225$1@news.povray.org>
I've been away from playing with Pov-Ray for a few years, so I haven't heard
about this utility. Some of the pictures I've seen in p.b.i. are stunning --
they look like photographs. I'm certainly not looking for advice on how to
use it (I'm back up to the point where I can make a scene with spheres and
boxes without screwing up :-) ), just a sort of basic explanation of what it
is, and how it works. Thanks.
Mark
Subject: Re: What is HDRI?
Date: 11 Jan 2003 12:36:12
Message: <3e20560b@news.povray.org>
From what I know, it's an image which can have color channel values
greater than 1 (normal images can only have values between 0 and 1).
  That's it.
  The reason why that makes a big difference is another story, which I'm
not really qualified to explain, as I don't have any experience at all.
Date: 11 Jan 2003 15:59:46
Message: <cjameshuff-2AF9BB.15493311012003@netplex.aussie.org>
In article <3e205225$1@news.povray.org>,
Basically, to make a really realistic scene, it helps for your objects
to have realistic surroundings and lighting, especially for things like
reflections. You can construct this environment entirely in the
computer, having the computer actually simulate the entire scene, but
this takes memory, computation time, and is difficult or just time
consuming.
HDRI means High Dynamic Range Image. Usually, image color values are
percentages, you can have 0%, 100%, and steps in between. Of course, in
reality, there is no "100% brightness", it is just a compromise for what
our display devices can show. High dynamic range images store
intensities instead of percentages, and can store values brighter than
"white".
An HDRI image can be used to store lighting values for a scene, either
precomputed ahead of time or taken from a real-world sample. Since the
lighting values already exist, it doesn't take as long as having the
actual scenery there, it is easier to set up, and the lighting is more
realistic than a background from an ordinary image, with color values
clipped to a small range.
http://tag.povray.org/
Date: 11 Jan 2003 23:53:16
Message: <3e20f4bc$1@news.povray.org>
Very similar, in fact, to a convolution reverb, which samples the ambience
of a space and applies that to a sound recording, given the recording the
illusion of being in the space.
D.
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
heard
stunning --
to
and
what it
> consuming.
> "white".
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 12 Jan 2003 13:19:31
Message: <3e21b1b3$1@news.povray.org>
Where does the scene come from? A scene you've already rendered? From
reading a few of the posts in p.b.i., it seemed like they were photographs.
Is that it?
Mark
Date: 12 Jan 2003 13:42:55
Message: <cjameshuff-D66628.13322612012003@netplex.aussie.org>
In article <3e21b1b3$1@news.povray.org>,
> Is that it?
"either precomputed ahead of time or taken from a real-world sample."
It doesn't really matter where it originally came from...could be
generated with a high-quality renderer, could be taken from a real-world
location. If the patch allows POV to output images in that format, you
could generate the images with POV. Then you would have to do the work
of setting up the scenery, but you would only have to do that and render
once, and could use the resulting HDRI map in several other scenes, or
to make a faster rendering animation. Most HDRI maps seem to be
real-world samples, probably because there isn't much rendering software
that can output to those images. I think Radiance can do it, or it might
just use its own RGBE format.
Date: 12 Jan 2003 21:40:39
Message: <3e222727$1@news.povray.org>
You can look for "probes" at various sites that have been mentioned
recently.
D.
"Mark Hanson" <mar### [at] attbicom> wrote in message
news:3e21b1b3$1@news.povray.org...
photographs.
> Is that it?
> Mark
Date: 14 Jan 2003 14:45:44
Message: <web.3e24683e552627465543301f0@news.povray.org>
What made HDRI make sense to me was the idea/fact that it was "invented" to
allow artificial 3D objects to be placed into a "real" scene.
Have you ever watched a program with CGI in an "real" scene where the CGI
just didn't look quite right, but you couldn't quite put your finger on why?
The likely cause was the improper lighting.  HDRI samples light differently
than, say, a single exposure on a digital camera.  From what I understand,
it does this by having multiple exposures of different lengths.  By doing
this, it can approximate the "real" intensity of the light.  By using this
light data, you can then place 3D objects into a "real" scene and have much
better lighting.
A good example is simply sunlight coming trough a window into a dark room.
On a normal photograph, the window may simply look "white".  However, having
a white piece of paper hanging on the wall does not begin to have the same
effect on lighting as sunlight coming through a window.  If you consider
all-white to be rgb<1,1,1>, then sunlight would be something like
rgb<1000,1000,1000>, but a normal digital photo can only show things in the
range rgb<0,0,0> to rgb<1,1,1>, so you'd lose all of that extra light.
I'm not sure if that made sense or not.  If you're like me, you'll be
driving down the road and suddenly go, "Hey, that makes sense now!"
Good Luck,
Slash
Date: 14 Jan 2003 15:24:26
Message: <3e2471fa$1@news.povray.org>
"Slashdolt" <nomail@nomail> wrote in message
news:web.3e24683e552627465543301f0@news.povray.org...
<snip>
Well, I'm getting there. HDRI is a way of approximating real-life situations
that Pov-Ray can't do, or can't do well -- I'm thinking events like depth of
focus, glare, sun flares.
Next: is HDRI a program in itself?
Mark
Date: 14 Jan 2003 15:50:05
Message: <web.3e247766552627465543301f0@news.povray.org>
Not quite.  It really has to do with one thing only, afaik.  Simply the
lighting.
By allowing some things to be brighter than simply "all-white" it allows you
to insert a 3D object into a "real life" photo, and have the same lighting
in the room as you did when the photo was taken.  To use my "sun coming
thru a window" analogy, your 3D object could actually be "lighted" from
where the sun hits on the far side of the room indirectly, and not just
from the actual light source.
I still don't feel I'm explaining this very well.  Maybe if I said something
like, "To some extent, it's like radiosity coming from a photograph rather
than from a light source bouncing off 3D objects in a completely rendered
scene."
Slash
Date: 14 Jan 2003 16:45:52
Message: <3e248510$1@news.povray.org>
"Mark Hanson" <mar### [at] attbicom> a écrit dans le message de news:
3e2471fa$1@news.povray.org...
situations
of
No it's much simpler and limited in scope. Just think of it as a photograph
able to emit bright light. It doesn't add functionality to POV-Ray (it's
possible to have HDRI effects in POV-Ray without a patch), it's just that
HDRI photographs derived from natural environments give very realistic
results when used in 3D pics because they are by definition realistic
(realistic colors AND realistic light intensities). One thing that gives
away images using HDR maps is that the reflection of light sources is not
dimmed on poorly reflective objects (the reflection of a light bulb will be
bright even if the object has refection 0.3).
In fact, here is a basic HDR texture in regular POV-Ray:
texture{
    image_pattern{jpeg "areas_of_light_intensities"}
    texture_map{
        [0 pigment{color White} finish{ambient 0}] // regular White
        [1 pigment{color White} finish{ambient 1000}] // very very bright
White
No, it's a way to store the light intensities with the color pixels. There
are several file formats available (HDR, PIC, TIFF adaptations seem the most
frequent). What MLPOv has is the support for the HDR format. There's a free
program called HDRShop that lets you create and view HDR image though.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 14 Jan 2003 17:10:06
Message: <web.3e2489f955262746a0c272b50@news.povray.org>
>scene."
>Slash
Well, I haven't tried it yet, so I may be completely wrong, but if I
understand what I've seen here, both in comments and in images, the HRDI
image IS the light source.  That requires an image with higher values than
1.
Best example I can think of is in my frozen moment IRTC entry
(http://www.irtc.org/ftp/pub/stills/2002-12-31/hang_rg.jpg) I use a
terragen image as a background. I also had to use a lightsource with a fade
power of about 10 to get the light on the foreground to look right, not to
mention the time I spent getting it positioned to look right.  If I had
used an HRDI image I wouldn't have had to add the light source, the HRDI
image would take care of that and it would be right where it belonged.
And that is pretty much what I understand its intended for. Unfortunately,
the patch came out about three days after I submitted it or I probably
would have tried it, since it looks like terragen supports this with a
plug-in... :)
RG
Date: 14 Jan 2003 19:01:30
Message: <3e24a4da@news.povray.org>
news:web.3e247766552627465543301f0@news.povray.org...
situations
of
> lighting.
you
No, actually that about did it. I'm rendering a statue in a white room.
There is one light source illuminating the side of the statue the camera is
looking at, meaning the other side is dark. HDRI bounces the light off the
white walls and illuminates (partially) the other side if the statue. Do I
have it now? That's pretty cool.
Mark
Date: 16 Jan 2003 10:58:21
Message: <cjameshuff-A31352.10574316012003@netplex.aussie.org>
In article <3e24a4da@news.povray.org>,
No. Radiosity alone does that. HDRI just lets you encode the lighting
values in a high dynamic range image, so you don't have to calculate it
during rendering and can use real-world surroundings without having to
model them.
Date: 16 Jan 2003 11:37:14
Message: <3e26dfba$1@news.povray.org>
is
the
I
> model them.
Okay, I give up. :-) I don't know enough about higher-end rendering to
understand it. But I'll get there some day. Thanks to everyone.
Mark
Date: 3 Mar 2003 09:07:43
Message: <3e6361af@news.povray.org>
Do not give up!
HDRI is just the BITMAP, nothing more.
Its higher dynamics & lower bounds on intensity clamping give you
opportunity to use it as a source of data which is more real than
clamped & more discretized RGB map such PNG,BMP etc.
Its a BITMAP!   ... used in a very cheap way to light the scene or
place more dynamic reflections/refractions.... its a touch of reality in
the very clamped POVRAY world....
Date: 3 Mar 2003 09:13:57
Message: <sjo66v0co8k9mdl2n5qiqnk8dk6lspm00j@4ax.com>
On Mon, 3 Mar 2003 15:07:05 +0100, "T.J.Viking" <vik### [at] bp-domarpl> wrote:
would you like to make "clamped" word usage more clear here?
ABX
Date: 3 Mar 2003 09:47:27
Message: <3e636aff@news.povray.org>
clamping (in GFX world) - clipping some values in suitable range
.. in POVRAY clamping occurs in final RGB discretization process, but also is
present in radiosity code i many places - the author of implementation had some
intention to make POV radiosity more artistic one.. rather than real one....
Date: 3 Mar 2003 10:00:26
Message: <85r66vgt97vbv62ou75qoimr6qv89ju5oe@4ax.com>
On Mon, 3 Mar 2003 15:46:50 +0100, "T.J.Viking" <vik### [at] bp-domarpl> wrote:
Gooood. I was affraid that you meant "POV community" as "POV world" which could
change "clamped" sense a lot.
Have you done some "unclamping" for radiosity code ? Have you some results ? Any
patched version available ?
ABX
Date: 3 Mar 2003 12:08:21
Message: <3e638c05$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:85r66vgt97vbv62ou75qoimr6qv89ju5oe@4ax.com...
could
Now, *THATS* paranoid.... ;)
Date: 4 Mar 2003 03:39:02
Message: <3e646626$1@news.povray.org>
ehhhh :) no comment... :)
Nope.
I am writing my own GI renderer and studied radiosity/monte carlo/irradiance caching
over
years.... then tried to look how POV is doing that.
When I saw the GI code in POVRAY, I sat down and started to cry :)
Many bugs! Bugs meant by misunderstanding light theory and many nifty
"methods" of coping with "crossing 1's value".
I know the code is working, but is highly limited in some areas eg. light is not so
well
propagating in corridors, tunnels etc. due to many limits bound on GI values during
caching and mixing with diffuse coefficients - no matter how many GI bounces you
gave in rendering settings.
I think that it is the time to redesign radiosity code, there are so many new theories
and
algos now... somebody could boost POV in XXI century.
Date: 4 Mar 2003 04:26:59
Message: <3E647162.7C018C44@gmx.de>
theories and
Very funny.
Instead of making 'wise' comments just get the POV-Ray source from
http://www.povray.org/download/
and implement a better radiosity function.  If you are as competent in
that matter as you pretend to be this should not be a problem.  If not i
suggest you either stop your complaints or support your critiques with
some proof.  This of course would require actually using POV-Ray.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 4 Mar 2003 04:28:34
Message: <3e6471c2@news.povray.org>
"T.J.Viking" <vik### [at] bp-domarpl> wrote in message
news:3e646626$1@news.povray.org...
theories and
If you can provide a decent patch, I'm sure it will make it's way to megapov.
Once megapov gets enough features, it tends to become the standard
pov-executable for the majority of users.
Date: 4 Mar 2003 04:39:52
Message: <3e647468@news.povray.org>
theories and
> Very funny.
Yup very funny indeed :)
Being wise is not my mission...
Yes I was, I am & I will (I hope) use POV :)
Your problems are not my problems, I can live with it how POV is working.
I do not understand one thing, why POV community is so touchy about any
complaints..... POV is marvelous, but as everything on the world can be better.
And one word to you guys..... go for a walk, and leave POV for a while... you are
going crazy
about you "preccious"
Date: 4 Mar 2003 05:05:06
Message: <3E647A52.154332E7@gmx.de>
"T.J.Viking" wrote:
> Your problems are not my problems [...]
> complaints.....
You gave the reason yourself.  Because it is a community.  Just making
complaints without supporting them with actual arguments and proofs is not
of any help.  Do you really think people actually using POV-Ray everyday
can't complain about its shortcomings themselves?  What you said clearly
places you outside the community.
I strongly suggest you reread my last post because following its
suggestions will almost surely guarantee you friendly replies to your
postings.
Date: 4 Mar 2003 05:15:16
Message: <3e647cb4$1@news.povray.org>
I really appreciate what youve done to the community Chris,
but you simply not understanded my intentions...
My intention was to start talking about changes to the radiosity code.
Do not put that heavy work to one and only person... its undoable in
the current state of code - in my opinion most of the features rely on
structures used not only in radiosity code...
> postings.
Your suggest leads to nowhere...
Many people was using GI in POV for years and know their problems better
than me and you. Let them speak about it if you even matter about "community".
It is not communism it is more like democracy - let other people have their
opinions and needs.
The matter is open... let the people speak, then start implementing.
Date: 4 Mar 2003 06:16:40
Message: <er196vs4qngodll7fvoqh4c05leijnrjkj@4ax.com>
On Tue, 4 Mar 2003 09:38:24 +0100, "T.J.Viking" <vik### [at] bp-domarpl> wrote:
Sorry. Your CV at http://news.povray.org/search/advanced/?s=Viking&a=1 is short
so I wasn't sure your intentions. The meaning of some recent threads made me sad
and I become sensitive.
> Nope.
over
Can you refer to exact line in sources? Knowing what is broken can allow make it
better. Having more info MegaPOV can make those bugs "optional". Can you share
your knowledge and help us make it better ?
theories and
Tomku, zarówno zródla POV-Raya jak i MegaPOV sa publiczne, z checia
przetestujemy twoje propozycje. Zachecam do wypuszczenia patcha. Jesli tylko
jestes chetny do wspólpracy zapraszam do kontaktu ze mna: abx### [at] abxartpl :-)
ABX
Date: 4 Mar 2003 06:25:48
Message: <3e648d3c$1@news.povray.org>
Yes I will provide full list of "bad points" in code.
Where should I post it ? Which group would be the best for such discussion?
Date: 4 Mar 2003 06:27:52
Message: <bt296v0af7k8ci4at8hauhkfe4581dv6if@4ax.com>
On Tue, 4 Mar 2003 10:39:13 +0100, "T.J.Viking" <vik### [at] bp-domarpl> wrote:
Wait, Tomek!
Did you said you have read the sources ? Did you said you have seen bugs there ?
Do you want to be parasite only ? We (community) give you application,
resources, contests, nearly on-line help. Please give us something too. POV-Ray
wasn't created in one week. Everyone bring something to it during last eleven
years. Having your post we have signal something is wrong. Writing what
*exactly* is wrong you can make time of repair short. Just complaining you did
not help us at all and we are still at the same place with the same real life
burdens and own current tasks opened.
ABX
Date: 4 Mar 2003 06:32:59
Message: <pd396vogkog0646mqds403c0f1ggokn6dv@4ax.com>
On Tue, 4 Mar 2003 12:25:08 +0100, "T.J.Viking" <vik### [at] bp-domarpl> wrote:
I think:
- The povray.programming for current source code discussions.
- The povray.unofficial.patches for complete working changes.
- The povray.binaries.utilities for uploading files.
http://www.povray.org/resources/newsgroups/
ABX
Date: 5 Mar 2003 08:55:03
Message: <r80c6vgea830te3futo3uj3vaeksu2ajpu@4ax.com>
going crazy
I can assert that Chris *does* go for a walk from time to time, even
if only to meet fellow POVers or ride his insane home-made bike :)
Peter Popov ICQ : 15002700
Date: 11 Mar 2003 17:31:08
Message: <3e6e63ac$1@news.povray.org>
news:3e6361af@news.povray.org...
> Do not give up!
I'm mildly flattered that you imagine that I could understand that.
Mark
Date: 14 Mar 2003 13:13:59
Message: <cjameshuff-306B80.13141114032003@netplex.aussie.org>
In article <3e6e63ac$1@news.povray.org>,
Ordinary images store intensity percentages. You can have from 0% to
100% intensity, with 100% being "white", anything brighter gets chopped
off. HDRI doesn't have that limitation, it keeps more information which
makes it useful in processing and rendering calculations even if it
can't be displayed.
