POV-Ray : Newsgroups : povray.advanced-users : Waterdrops on Glass... How? Server Time
5 Nov 2026 00:38:19 EST (-0500)
  Waterdrops on Glass... How? (Message 1 to 34 of 34)
Subject: Waterdrops on Glass... How?
Date: 8 Jan 2003 14:24:59
Message: <3e1c7b0b@news.povray.org>
Hello all!
I've been working on my "Worldbowl" image again,
and am trying to update it with my most recent macros,
making things look better and more detailed, in order to
achieve a very pleasing and realistic image which I might
put on Zazzle. In my oppinion, its one of my images which
actually have the option to be made something very
special...
Well, to get to the point, I have come to the conclusion that
some nice raindrops on the window would look very nice
and add some tiny detail to the otherwise boring outside
view.
Right now, I'm just placing blob-components (more or less
random, I'm working on that part), but the main problem I have
is the refraction due to the water. Normally, Water has an ior
or 1.33 and glass one of 1.45 or so. In order to get rid of the
coincident surface problem, I'm just clipping the blob with a box.
This leaves an open shell on the glass surface.
I'm one of those ulra-realistic guys, so I'd like to know either
how I can either calculate an ior for the water to simulate the
refraction taking place between water and glass surfaces.
In this case, its not a big problem, I could just play with different
ior settings for the water till I get a look I like.
But let's not take a glass window, but one for drinking. In that case,
an "open shell" water would be a disc in the glass to simulate the
water surface. But I want to simulate the correct refraction taking place
when the viewing rays passes through the glass into the water.
Sounds pretty complicated and I'm not too sure if I make myself
clear. The other way round:
Most of the time, us POVers leave a little gap between two transparent
surfaces in order to avoid coincident surfaces. But when refracting rays,
the effect taking place is different as opposed to two surfaces touching
each other.
Any ideas?
Thanks in advance,
Tim
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Waterdrops on Glass... How?
Date: 13 Jan 2003 19:16:31
Message: <3e2356df$1@news.povray.org>
Hm. Seems like I'm not raising much attention with this question,
eh?
Tim Nikias
Date: 13 Jan 2003 19:42:29
Message: <3e235cf5@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> a écrit dans le message de news:
3e2356df$1@news.povray.org...
> eh?
Can't help, I've had this little problem for years and I was never able to
solve it properly. Nothing I tried seemed to work as it should.  See :
http://www.oyonale.com/ldc/images/abeillesdetail2.jpg
The main issue, though, is less the surface problem than the distribution of
the droplets themselves. Ideally, their position should be the product of a
dynamic process, so that simple random positionning always seems wrong.
Perhaps Rune's particle system could help, I don't know. Blobs doesn't
behave like real water either, which is another problem.
G.
- Graphic experiments
- Posters
Date: 13 Jan 2003 19:47:12
Message: <cjameshuff-A31848.19470813012003@netplex.aussie.org>
In article <3e1c7b0b@news.povray.org>, "Tim Nikias" <tim### [at] gmxde>
> each other.
Overlap them a bit. POV does things so that refraction is handled
correctly in this case. The gap method simulates an air gap.
Designing the textures properly also helps. I usually use perfectly
transparent textures and use interior attenuation or media to provide
any coloration.
http://tag.povray.org/
Date: 14 Jan 2003 01:10:51
Message: <3e23a9eb@news.povray.org>
> Any ideas?
Hi Tim!
Maybe, you can tinker with clipped_by, to clip the surface of the drop which
would contact the window. I don't know wether the ray remembers the ior of
the object it currently is in or not. But if it's so, the ray would go from
1.33 straight into 1.45. which should be right...
Hope could help
Kalle
Date: 14 Jan 2003 03:19:05
Message: <3uh72v0viblg0mea8cq2o0qhrhrh3v12kl@4ax.com>
Hey Kalle, that's *extremely* neat - did you try it? It does sound
plausible...
Peter Popov ICQ : 15002700
Date: 14 Jan 2003 06:49:00
Message: <3e23f92c$1@news.povray.org>
That's what I'm currently doing, but I'm not sure
if it works as we think it does. As far as I understand
the raytracing technique, POV will stay with ior 1.45 from
the glass until it hits the surface of the water, and gets
refracted the way it should when exiting a 1.33 ior to
1.00 ior (water to air). But I'm not too sure about that,
and also no quiet sure how I should test that...
Tim Nikias
which
of
from
> plausible...
Date: 14 Jan 2003 06:52:13
Message: <3e23f9ed$1@news.povray.org>
It "does things"? What does it do? Just curious.
Though doing that with blobs is still kinda difficult...
Instead of clipping, I'd have to difference it away
position it slightly inside the window... Pretty tracing
intensive, hu? I'll try and look what happens. Thanks
for the suggestion though,
Tim
Tim Nikias
rays,
> > each other.
> any coloration.
Date: 14 Jan 2003 07:22:57
Message: <3e240121$1@news.povray.org>
You're definitely right about placing the droplets.
I've written a small include, which scatters droplets
randomly across an area (the whole thing was designed
so far only for windows), and also creates "trails":
At one spot, it starts, and moves downward (a little
randomly moving towards right or left), and leaves
very small droplets on the way, and at the end, a big droplet.
Just like those drops that get big enough to flow down.
I've uploaded a zoomed-version on the window,
http://www.digitaltwilight.de/no_lights/rain_1.jpg
Its 100kb, but shows how the results look so far. I'm
fiddling a bit with size and numbers to see if I can
get something near-realistic with this method.
I guess Rune's Particle System won't be of use, cause
it doesn't have particle-particle-interaction, and that
would be what droplets on windows are screaming for.
Perhaps I'll try to create an include file for windows, but
doing it with curved survaces and other objects... Way
too difficult. Got to have a running particle-system to do
that...
But near-realistic isn't too bad. Its all about the looks.
How did you place those droplets of yours? Using trace?
Though some look like the gravitational-pull is actually
affecting the droplet. How'd you do that?
Tim
Tim Nikias
of
a
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 14 Jan 2003 07:35:42
Message: <3e24041e@news.povray.org>
Using google this came up when looking for
"water droplets simulation":
http://www.cs.unc.edu/~lin/COMP259/LEC/29b.ppt
Its pretty interesting and perhaps, when I get the time to
understand it, I'll implement it. Could be useful, at least
for meshes (and windows can easily be done with
meshes).
Tim Nikias
Date: 14 Jan 2003 16:21:55
Message: <3e247f73$1@news.povray.org>
3e240121$1@news.povray.org...
Looks like a good start. Perhaps the droplets should be more homogeneous in
shape, though it depends on whether it's still raining or not. Here are some
reference images if you haven't got them.
http://www.danheller.com/images/Italy/Tuscany/rain-window-big.jpg
http://www.pacamera.com/memberGalleries/ammac/rainWindow.jpg
http://www.sengers.ch/special/tropfen.jpg
The trouble is that the code isn't commented...
From what I understand of it, it first creates a grid of droplets in a u,v
plane, because I had observed that in real life dew droplets are somehow
organised and not 100% random (it's different from the rain-beated window
then). The macro is given attractor points that draw droplets to them
(droplets far from the attractor are smaller), with some gentle
function-based displacement. This allows "lines" of droplets of decreasing
size to be created (it's more visible here
http://www.oyonale.com/ldc/images/abeilles.jpg). It's far from perfect but
100% random positionning was really unrealistic.
The u,v positions and sizes of the droplets are stored in arrays and are
then wrapped around the object (a simple cylinder in this case) as a single
blob.
About the gravitational pull, I remember doing it but I can't find it in the
code so perhaps it's just luck...
G.
- Posters
Date: 14 Jan 2003 16:27:38
Message: <3e2480ca$1@news.povray.org>
hey guys
can you tell me which app i have to use to view that file? powerpoint fails
(normaly uses .ppt, didn't think it would fit either), but google, wotsit ?
co just give powerpoint as target application...
thanks:florian
Date: 14 Jan 2003 16:29:19
Message: <3e24812f@news.povray.org>
3e24041e@news.povray.org...
> meshes).
Thanks ! It looks very interesting indeed. I'll have a look at it too, but I
haven't done this kind of math since 1986... It seems feasible in POV-Ray
SDL and could give very nice results.
G.
- Posters
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 14 Jan 2003 16:32:10
Message: <3e2481da$1@news.povray.org>
It worked fine with Powerpoint for me. Perhaps you've
got the wrong Version?
Here's something that looks much better, and covers the same
topic (I guess its actually the same, though the PPT was the
presentation part...)
http://www.eml.hiroshima-u.ac.jp/member/staff/kin/publications/CA93/wdroplet
.pdf
Tim Nikias
Date: 14 Jan 2003 16:34:46
Message: <3e248276@news.povray.org>
As mentioned to Florian Brucker, here's a link to a better
and more handsome PDF-Version:
.pdf
If you actually do it, remember to comment it the SDL heavily,
so that others might learn from it. I know, you're french, and would
probably comment in french, but I'm german and still try to stick to
english when naming parameters and such, so that most Users might
learn something and understand it very easily...
And from your posts it doesn't look like you're not skilled enough for
english commentary! :-)
Tim
Tim Nikias
Date: 14 Jan 2003 16:55:58
Message: <3e24876e$1@news.povray.org>
3e248276@news.povray.org...
Oh well, some people here are so good at maths that they could probably
implement this in a evening or so [hint, hint ;-)] ...
My only advantage is that Nobel Prize Pierre-Gilles de Gennes (who is cited
a in the paper) works a couple of streets away so I could perhaps kidnap him
and ask for functional, working code...
I know, I know, even the scenes I don't plan to release are commented in
English now, just in case I have to cut and paste some code in these
groups... Not that I like it but it's better than renaming the variables at
the last minute.
G.
- Posters
Date: 14 Jan 2003 17:07:02
Message: <cjameshuff-CABB66.17064414012003@netplex.aussie.org>
Don't. This will not work properly: the ray will never leave the object
if it goes through an area that was clipped away, and won't enter the
object properly from the glass side. The correct solution is simpler,
just overlap the objects.
Date: 14 Jan 2003 17:16:49
Message: <cjameshuff-95B46C.17162714012003@netplex.aussie.org>
In article <3e23f9ed$1@news.povray.org>,
Take a ray entering a droplet for example: it hits the droplet surface
and gets refracted, and is now inside the droplet. The next surface it
hits is the glass, so it gets refracted as it should when going from
water to glass. It is now inside the glass and the droplet. When it hits
the other droplet surface, *no refraction is done*, but it leaves the
droplet. (I think it still computes the texture, I'm not sure it should
though.)
Now the ray has gone through the droplet, been refracted going from
air/water and water/glass, and is now in the glass, just as it should be.
No more so than for any other object. The difficulty is more determined
by the object you are placing the blobs on.
Date: 14 Jan 2003 19:56:42
Message: <3e24b1ca$1@news.povray.org>
Why don't you like it? I've heard several rumours about
french people and languages... They like to stick to theirs... ;-)
In some respect, germans are much the same. Some are
really against incorporating english words into the known german
vocabulary. And sometimes, things get messed up. For example,
cell-phones are called "Handy", but ask any american, they
wouldn't know what we're referring to, unless they're told.
About that math-stuff... I think, if I sit down, I could solve it,
though perhaps not strictly by the rules given in the paper. Especially
that modelling part about angles of the water-droplets and such would
be quite difficult, I think.
But right now, I'm not really in the mood to dig into that. There's a lot
of scientific papers floating on my harddrive, waiting to be implemented
in one way or the other... Next week perhaps... ;-)
No, seriously, I do like the idea of this, might be a very useful addition
to lots of realistic scenes. I've actually found some MPEG showing off
what the code is capable of:
http://www.eml.hiroshima-u.ac.jp/member/staff/kin/publications/JVCA
As I'm posting this, the page can't be accessed, don't know why. Perhaps
back online tomorrow.
We'll see who gets to implement this first. That wave-algorithm Rune
and then Christopher Hormann (if I'm not mistaken, was at least a
Christopher :-) implemented was something I wanted to do as well...
Tim Nikias
cited
him
at
> the last minute.
Date: 14 Jan 2003 20:01:20
Message: <3e24b2e0$1@news.povray.org>
I guess you meant "When it hits the other glass surface", cause it makes
no sense if it doesn't refract when exiting the water and entering air.
> though.)
I think it should compute the texture, since if an object is transparent and
has two sides, POV's rays will be affected by each surface. That's just
the way its implemented and IMHO how I would expect it to behave. If
we'd want 100% realism, we'd probably have to texture it completely
transparent, but add some interior color, like using fade_color and
fade_power or such.
You're right about that. It works pretty well for a window made of a single
box, but I'm always thinking "general", to keep things flexible.
Tim Nikias
Date: 14 Jan 2003 23:08:49
Message: <cjameshuff-CCD54F.23083314012003@netplex.aussie.org>
In article <3e24b2e0$1@news.povray.org>,
No, I meant the other water surface, I was ignoring the case where it
exits directly into air. First the ray hits the drop and goes from air
to water. Then it hits the glass and goes from water to glass, though it
is still inside the drop object it is now travelling through glass. Then
it hits the far side of the drop...they overlap, remember? Since it
already did the refraction for water/glass, it ignores the refraction
this time, and just removes the drop from the containing objects.
Date: 15 Jan 2003 06:18:13
Message: <3e254375@news.povray.org>
Oh, now I get it. I was thinking of my special case
scenario, in which the rays travels through the glass
first and meets the droplets on the backside. Thus my
interpretation of air-glass to glass-water to water-air.
To make the point: the issue is, once its inside the first
medium and enters the next, it won't get refracted again
when exiting the first medium it was in, right?
Tim Nikias
hits
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 15 Jan 2003 07:10:46
Message: <3e254fc6$1@news.povray.org>
hey tim
could be. anyhow, the pdf worked. thanks
greetings:florian
Date: 15 Jan 2003 07:15:11
Message: <3e2550cf@news.povray.org>
hey guys!
i think i'll give it at least a try, i just checked the maths stuff, looks
like the things we do in school these days.
it'll nevertheless take some time, cause i'm graduating this spring and
really should do some excercises ;-(
greetings:florian
Date: 15 Jan 2003 11:06:11
Message: <cjameshuff-74CD4E.11054315012003@netplex.aussie.org>
In article <3e254375@news.povray.org>, "Tim Nikias" <tim### [at] gmxde>
Right. When going from one object into another overlapping one, a ray
goes through two surfaces but only gets refracted once.
Date: 15 Jan 2003 14:06:05
Message: <3e25b11d$1@news.povray.org>
Well... was just an idea... - I used something like this when I modeled a
closed glass with halfway water and halfway air - there are some
"conincident-surface" problems...
Is this really correct? There is this border of my drop, sitting in the
window-glas...
Or is it just a good looking workaround?
Greetings, Kalle
Date: 15 Jan 2003 17:34:36
Message: <3e25e1fc@news.povray.org>
> the window-glas...
> Greetings, Kalle
Well, answered in another piece of this thread...
Thank you anyway.
Kalle
Subject: First results
Date: 16 Jan 2003 10:55:26
Message: <3e26d5ee$1@news.povray.org>
hey guys!
this nice little paper about water droplets on glass did really fascinate
me. I started right away yesterday evening (in spite of learning for a class
test *g*) and had half of the algorithm implented till I went to bed.
I rendered a small animation of it while I was at school this morning. You
can download it from
http://www.torfbold.com/droplets.avi (about 330K,100 Frames)
(its compressed using divx 5, you can download it from http://www.divx.com)
I'm afraid it is not water on glass but water on something non-transparent.
I didn't have the time to set up a nice demo-scene, suggestions welcome *g*.
For this animation, I used a grid of 120x120 cells. It took about one hour
to render it on my Athlon 600 256 MB SDRAM, half of the time was spent
parsing, the other half tracing. I think the algorithm could be made faster,
but I'm not a specialist in this field.
I'll release it after I coded the rest of the algorithm, so anybody can have
a try.
I didn't used the approach of using a mesh which was suggested by the paper,
but reduced it to a simple n*m grid. Due to this, it's only possible to
render droplets running down even plates like windows. These plates may have
nevertheless all possible inclination angles.
There is still much room for improvements, but this is as far as I came
yesterday:
- The basic algorithm for animations is implemented
- the masses of the droplets and their paths are already calculated
correctly
What is still to be done:
- calculating the correct size of each droplet according to its mass (at the
moment i'm using a simple linear connection)
- calculating the correct velocities of the droplets. I'm not sure about
this part of the paper as it is not clearly stated how these velocities are
used.
I think the result in the middle of the animation is pretty nice, but in the
end there are many non-moving masses around and you can see that they are
arranged in a grid. The blob-parameters i used were imho not that good, the
droplets lack "blobiness". I'm not very familiar with blobs, but I hope I'll
find some better values for them.
The behaviour of the droplets are dependent on some parameters. Perhaps
other values for these parametres will lead to nicer results, but i had not
yet time to try this.
Comments & ideas welcomed!
greetings:florian
Date: 7 Feb 2003 12:05:04
Message: <web.3e43e6949320e9d02ce39a3a0@news.povray.org>
Water-Glass-Air problem:
I've given this problem a lot of thought while trying to accurately model a
glass of Champagne. I've come up with four non-solutions.
Model with air-gap:
  -Doesn't work because it results in total reflection where
   there shouldn't be. (The air gap work the same way as the
   air gaps in optical fiber lines.)
  -Awful render times because of rays bouncing back and forth
   in the gap.
Union with overlap:
  -Not as much total reflection, but still incorrect.
  -Still awful render times, because of the two surfaces.
Merge with overlap:
  -Not really correct since merged objects shouldn't have different
   interiors.
  -The material is determined by the ray's point of entry, and
   doesn't change, because there is no surface at all where there
   were two surfaces before
Union + clipping.
  -Correct number of surfaces (one) between water and glass.
  -Problem when ray reenters air. (It doesn't, because it
     misses the surface where it should leave the water.)
  -Example:
    1st surface: Enter water (Ray is in water)
    2nd surface: Enter glass (Ray is in glass in water)
    - Surface to leave water is clipped
    3rd surface: Leave glass (Ray is in water, when it is actually in air.)
The only solution that I can think of would be to modify POV-ray itself.
The feature we need is a half-merge. That is a method which takes the
union of two objects, and keeps exactly one of the internal surfaces.
/Per
Date: 7 Feb 2003 14:33:24
Message: <cjameshuff-0E5DB4.14301007022003@netplex.aussie.org>
In article <web.3e43e6949320e9d02ce39a3a0@news.povray.org>,
Read the rest of this thread, what POV-Ray does has been explained. You
should simply overlap the surfaces slightly, this will give the correct
result.
Date: 7 Feb 2003 15:18:26
Message: <3e441492$1@news.povray.org>
> result.
No, that would be 'will give a visually acceptable result'.   Surfaces
don't overlap in the real world.
--Tim Cook
Version: 3.12
Date: 10 Feb 2003 18:54:56
Message: <cjameshuff-E232E7.18515910022003@netplex.aussie.org>
In article <3e441492$1@news.povray.org>,
As already mentioned in this thread, the way POV handles this situation
results in refraction being handled correctly.
Can we drop it now?
Date: 10 Feb 2003 19:22:18
Message: <3e48423a$1@news.povray.org>
> Can we drop it now?
Water drop it, even.  hehehehhehehehehe
er
*cough*
--Tim Cook
Version: 3.12
Date: 2 Apr 2003 19:35:31
Message: <3e8b81d3$1@news.povray.org>
Hi!  I realize this is an old posting from the POV news sever, but you can
go here to see a new technique I created to make waterdroplets do what I
want them to do on a flat, glass surface, and am working on making it happen
on a curved surface.  The piece is animated, but here are some screenshots
to look at.  All the water droplets on this image are CG created.
http://www.actlab.utexas.edu/~arie/intersection/
Arie Stavchansky
"Per Rutquist" <per### [at] volvocom> wrote in message
news:web.3e43e6949320e9d02ce39a3a0@news.povray.org...
a
> Model with air-gap:
>    in the gap.
> Union with overlap:
> Merge with overlap:
>    interiors.
> Union + clipping.
>   -Example:
air.)
> /Per
