![](/i/fill.gif) |
S <sha### [at] nocannedhamactive ch> wrote:
> what would the command line string for Warp's mesh compressor to handle a
> bunch of inc files?
> "C:\meshcomp *.inc *.pcm" would be the direction of what I need.
> Compress a directory full of mesh include files.
The program supports converting just one file at a time. If you want
to automatize converting several files, you'll have to resort to any tools
your OS offers you.
In a Unix shell it would be a command like this:
for F in *.inc; do meshcomp $F $F.pcm; done
(of if you don't like the files named in the form 'file.inc.pcm' but would
like them to be named like 'file.pcm', you'll have to use a bit more
complicated command, like:
for F in *.inc; do meshcomp $F `basename $F .inc`.pcm; done
However, from your question I deduce that you are using Windows. If you
have the command-line version of the program, you can do something like this
in the DOS-prompt:
for %%F in (*.inc) do meshcomp %%F %%F.pcm
(It will create files with the form 'file.inc.pcm', and I don't know if
it can be made to create them otherwise.)
![](/i/fill.gif) |
