POV-Ray : Newsgroups : povray.advanced-users : My first grass. Server Time
18 Oct 2026 17:26:01 EDT (-0400)
  My first grass. (Message 1 to 16 of 16)
Subject: My first grass.
Date: 30 Sep 2002 00:07:55
Message: <3d97ce1b@news.povray.org>
I'm making an image with a big HF in the foreground. I want to put grass on
the HF but only on the flat areas. What is the most conventional way to do
this? I can make an image that describes which areas should and shouldn't
have grass by using world forge, but I still wouldn't know how to apply the
image to a macro for placing grass. Thanks in advance!
Corey
http://www.4gigs.com/~schitzo/
Subject: Re: My first grass.
Date: 30 Sep 2002 02:30:52
Message: <borfpuo0greo8tsvd20c0pvusqh63rk5rd@4ax.com>
On Mon, 30 Sep 2002 00:08:23 -0400, "Corey Woodworth" <cdw### [at] mpinetnet>
as function based on pattern as image ?
ABX
Date: 30 Sep 2002 02:45:07
Message: <web.3d97f2bc855d30e7f70c33440@news.povray.org>
>Corey
First, declare your heightfield picture and your grass-info-picture each as
a function (see "6.1.6.5 Declaring User-Defined Color Functions" in your
POV-documentation)
Then use a loop to randomly 'try' where grass can be (where the
grass-function is above 0.5, i.e.).
Last, get the height info from your heightfield function where to put the
grass in y-direction.
It will be a bit tricky to get the right coordinates and to compensate the
scaling of your heightfield, but that's the best way I thing.
Any other ideas?
Date: 30 Sep 2002 03:54:46
Message: <3d980346$1@news.povray.org>
I've written some macros for just that purpose, though
they're still experimental and not yet fully finished. See my
homepage's WIP section, or some rather old images
I posted to the newsgroups.
Though they're not fully up to what you'd like, you
could perhaps use the source to learn from, at least
for placement etc.
Tim
Tim Nikias
Email: Tim### [at] gmxde
on
the
> Corey
Date: 30 Sep 2002 05:51:47
Message: <3D981EB4.4DECCE3B@gmx.de>
The easiest is usually to use 'trace()'.  You can use the returned normal
vector to determine the slope at the position.
Date: 30 Sep 2002 06:41:35
Message: <3D982A2E.8E9D1F0B@pacbell.net>
Vegetate it -
http://www.geocities.com/SiliconValley/Program/9231/povray.html
Ken Tyler
Date: 2 Oct 2002 19:23:19
Message: <3d9b7fe7@news.povray.org>
> Christoph
I've seen lots of cool stuff done with trace but I've never dabbled with it
myself. I read the docs on it and I'm a bit confused. I have a heightfield
named canyon, and this is a nested loop to test for an intersection. It
should always intersect so it should always generate a sphere (I havn't the
slightest how to test for the slope yet), but it loops infinetly and I dunno
why. I'm not too good at Macros yet. =)
Here is my code, can someone point me in the right direction?
#declare Norm = <0, 0, 0>;
#declare Start = <0, 2, 0>;
#declare End = <0, 0, 0>;
#declare Counter = 100;
#declare xCount = Counter;
#declare zCount = Counter;
#while (xCount != 0)
  #while (zCount != 0)
    #declare End =   <xCount/Counter,0,zCount/Counter>;
    #declare Start = End + <0,2,0>;
    #declare Inter =   trace ( canyon, Start, End, Norm );
    #if (vlength(Norm)!=0)
      sphere {
        Inter, .2
          pigment {color green 1}
    #declare zCount = zCount - 1;
  #declare xCount = xCount - 1;
Corey
Date: 2 Oct 2002 20:06:18
Message: <chrishuff-4761E3.20031102102002@netplex.aussie.org>
In article <3d9b7fe7@news.povray.org>,
Well, your first problem is that you are testing for equality in your
loop conditions...almost always a Bad Thing. Scalar variables in POV-Ray
are double-precision floating point numbers, and numeric errors could
cause them to go right past 0 without ever being exactly equal to it.
Normally, you loop while the counter variable is higher or lower to a
value instead of while it is not equal to a certain value.
You are also looping down, this is just odd, since usually people loop
up unless they have a good reason, but it works, there isn't any reason
not to.
Finally, and probably the real reason you have a problem, the trace()
function takes a ray direction, not an end point. All your trace() calls
are going off in a plane perpendicular to the y axis and passing through
< 0, 2, 0>. Use "trace(Canyon, Start, -y, Norm)" instead.
Oh, and you are missing an #end...I assume this just got lost in editing
for the post, because the code doesn't do anything without it.
http://tag.povray.org/
Date: 4 Oct 2002 10:58:45
Message: <3d9daca5$1@news.povray.org>
That was code copied strait from the docs =) I didn't, and still don't
completely understand how and what trace returns. What I'm aiming for is
something that detects if the given point on the HF is somewhat flat and if
so put a sphere there.
> not to.
It just seemed more intuitive to me at the time. =)
Ah! That makes sense. I thought it was an endpoint. Thats why I moved End in
relation to Start.
Whoops =)
Ok. Here is the updated code, but it still doesn't work.
#declare Counter = 1000;
    #declare Start = <xCount/Counter,2,zCount/Counter>;
    #declare Inter = trace(canyon, Start, -y, Norm);
      sphere {
        Inter, .5
Date: 4 Oct 2002 12:10:36
Message: <3d9dbd7c$1@news.povray.org>
"Corey Woodworth" <sch### [at] hotmailcom> wrote in message
news:3d9daca5$1@news.povray.org...
>       sphere {
>         Inter, .5
>         texture {
>     #end
All that (vlength(Norm)!=0) is checking is that you've hit your hf (the only
time when vlength is 0 is when you've missed the object).
I haven't used trace for a while now, but iirc what you want to do is check
whether Norm.x and Norm.z are under a certain range. I think the following would
only place a sphere if the point was perfectly flat:
#if(Norm.x = 0 & Norm.z = 0 & Norm.y != 0)
       sphere {
         Inter, .5
or, with a bit more give and take...
#if(abs(Norm.x) < 0.1 & abs(Norm.z) < 0.1 & Norm.y != 0)
       sphere {
         Inter, .5
... but wait for corrections from others (untested).
Date: 4 Oct 2002 13:52:34
Message: <chrishuff-AD64E5.13490004102002@netplex.aussie.org>
In article <3d9daca5$1@news.povray.org>,
It takes an object and the beginning point and direction of a ray, and
optionally a variable to put the surface normal in. If the ray hits the
object, it sets the normal variable to the surface normal at the point
where it hit, and returns the intersection point. If it doesn't hit the
object, it sets the normal to < 0, 0, 0> (an impossible value for a
normal) and could return anything for the point, that value is
unpredictable.
> What I'm aiming for is something that detects if the given point on
> the HF is somewhat flat and if so put a sphere there.
How easy that is depends on how you define "flat"...you could check the
y value of the normal. If it is perfectly horizontal, it will equal 1,
perfectly vertical it will equal 0, you will probably want some
leeway...placing spheres only if the y value is larger than 0.7, for
example. It will be the sine of the angle to a horizontal plane, so some
simple trig could be used to set the threshold to a specific angle if
you want this.
This is only affected by the normal of the surface at that point
though...it could be a bump on the side of a steep cliff, or the ground
at that point could be extremely rough.
How does it not work? It still infinitely loops? Or it just doesn't
place the spheres?
Here's a (untested) corrected (and reformatted to be closer to the way I
write code, just ignore that) version:
#while(xCount > 0)
  #while(zCount > 0)
    #declare Start = <xCount/Counter, 100, zCount/Counter>;
    #if(vlength(Norm) > 0.0001)
      sphere {Inter, .5
        texture {pigment {color green 1}}
I increased the "height" the rays are cast from to 100...I don't know
how tall your canyon object is, if it went higher than 2 there would
have been a problem.
Date: 4 Oct 2002 13:55:02
Message: <chrishuff-653276.13514304102002@netplex.aussie.org>
In article <3d9dbd7c$1@news.povray.org>,
> would only place a sphere if the point was perfectly flat:
Just checking y would be easier. If it is very near 1, both x and y must
be near 0. It is equal to the sine of the angle to a horizontal plane.
And if it is non-0, the intersection is valid, so you don't even have to
check for < 0, 0, 0> any more.
Date: 7 Oct 2002 08:50:00
Message: <3da182f8$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
That's the bit I couldn't quite remember (i.e. whether trace could return
<1,1,1> as a vector).
Date: 7 Oct 2002 12:20:20
Message: <chrishuff-EB8B45.12170307102002@netplex.aussie.org>
In article <3da182f8$1@news.povray.org>,
Well, it can't return that either, and never will...unless I am very
wrong, it always returns either a normalized vector or < 0, 0, 0>.
Date: 8 Oct 2002 05:06:08
Message: <3da2a000$1@news.povray.org>
Well, exactly (I think). BTW, what is the normalised vector of <1,1,1>? Oh, hang
on, there must be a function for that....
#debug vstr(3, vnormalize(<1,1,1>), ", ",2,5)
Date: 8 Oct 2002 10:28:46
Message: <chrishuff-743246.10251008102002@netplex.aussie.org>
In article <3da2a000$1@news.povray.org>,
> hang
The normalized vector is < x, y, z>/sqrt(x*x + y*y + z*z), so the result
is < 1, 1, 1>/sqrt(3). This can't be perfectly represented in decimal or
binary form, so you will get a lot of decimals from that #debug
statement. You probably don't need to know this unless you are trying to
simplify algebraic expressions.
