POV-Ray : Newsgroups : povray.advanced-users : Grid artifact in f_noise3d isosurface Server Time
18 Oct 2026 19:18:58 EDT (-0400)
  Grid artifact in f_noise3d isosurface (Message 1 to 49 of 49)
Subject: Grid artifact in f_noise3d isosurface
Date: 22 Jun 2002 12:40:19
Message: <3d14a873@news.povray.org>
Toying with isosurfaces (pov v3.5RC6), I found a quite visible grid
artifact... I don't know what to make of it. Should I make a bug report ? It
is so basic [just function{-z+f_noise3d(x,y,z)}] that I find it very
unlikely that it is unknown. But searching with http://news.povray.org
yielded no answer... So, could anyone check this
http://web.wanadoo.be/wbrp0009/pov/main.html and tell me what to do with it.
Povingly,
Philippe
Subject: Re: Grid artifact in f_noise3d isosurface
Date: 22 Jun 2002 12:47:57
Message: <3d14aa3d$1@news.povray.org>
have you played with accuracy settings ?
Date: 22 Jun 2002 13:03:54
Message: <3d14adfa@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3d14aa3d$1@news.povray.org...
Yes. It's one of the first thing I tried after checking the gradient /
avaluate. The grid is visible from accuracy at accuracy 1e-1, 1e-2, ...,
1e-6. I went no further.
Date: 22 Jun 2002 13:58:30
Message: <3d14bac6@news.povray.org>
"Philippe Debar" <phd### [at] belgacomnet> schrieb im Newsbeitrag
news:3d14a873@news.povray.org...
it.
For what it's worth, I would say: Make a bug report in p.b-t. They will fix
it, or tell you that this is the way they want it to work. There were some
changes to the noise-functions in RC6, as changes.txt tells - maybe
something went wrong. Judging from the web-page you made, f_noise looses a
lot of it's functionality if it stays the way it is - who would want some
noise with a grid?
But I did no own test so, I really don't know what it's worth. At least I
can't remember such artefacts in MegoPov or earlier Versions of 3.5.
Greetings,
Marc-Hendrik
Date: 22 Jun 2002 14:12:38
Message: <3d14be16@news.povray.org>
  This is known to the team, so no need to report it.
  The exact reason for this is not clear (it might not be a bug at all, but
the noise_generator 3 might just produce that; better alternatives may be
studied).
  Use noise generators 1 or 2 instead (I think it was f_noise_generator()
if you want to use another noise generator instead of the default, which
is 3).
Date: 22 Jun 2002 14:32:10
Message: <3d14c2aa@news.povray.org>
news:3d14be16@news.povray.org...
Mmmh ! I guessed so ;-)
but
> studied).
I've got the feeling we'll have to wait for 3.5b or MegaPov-the-next-gen.
> is 3).
Noise gen 1 and 2 suffer from the same problem, see
http://web.wanadoo.be/wbrp0009/pov/main.html, 5th and 6th images.
Philippe
Date: 22 Jun 2002 15:14:15
Message: <3d14cc87@news.povray.org>
In article <3d14a873@news.povray.org> , "Philippe Debar"
It would really help if the image source URLs would be valid.  That is
spaces encoded as required so they work outside broken browsers like
Internet Explorer...
    Thorsten
Date: 22 Jun 2002 17:14:54
Message: <3d14e8ce$1@news.povray.org>
I had no problems with the URL. (IE6, win2k)
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 22 Jun 2002 18:52:22
Message: <3d14ffa6$1@news.povray.org>
did you read Thorstens whole answer ?
he said:
> "spaces encoded as required so they work outside broken
>  browsers like..."
Date: 22 Jun 2002 21:04:36
Message: <3d151ea4@news.povray.org>
Ooops ! Sorry, my first web experience. I plead ignorance. I change that
right away (and I thought I
could go to sleep now...*sigh*). I removed the spaces as I do not know how
they have to be encoded - and right know, I choose sleep over knowledge
;-) I also removed uppercases, just in case <g>.
Philippe
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3d14cc87@news.povray.org...
>     Thorsten
Date: 22 Jun 2002 22:19:22
Message: <3d15302a$1@news.povray.org>
Not yet
Apache
ICQ: 146690431
Date: 22 Jun 2002 23:31:17
Message: <3d154105@news.povray.org>
All the noise generators suffer from this. It's most easily seen when
they're applied as the function for a height field, viewed at a shallow
angle.
At first I was a bit annoyed by this, but having looked at the 3.1 source in
the past, I know that it's caused by the way the noise functions are
created. They are *based* on a grid pattern of random values, which are
interpolated between. I'm not sure exactly how the new noise generator
works, but since it shows the same artifact, I assume it's similar.
I wish there were a better way to create random noise, but I sure as heck
couldn't come up with one.
The artifact is caused by the fact that while the first derivative of the
function is continuous everywhere, the *second* derivative isn't necessarily
continuous at any of the integral values of x,y, or z.
The best workaround I can think of, if it's causing any problems, is to add
turbulence to the noise.
 - Slime
[ http://www.slimeland.com/ ]
Date: 23 Jun 2002 05:01:17
Message: <3d158e5d@news.povray.org>
In article <3d151ea4@news.povray.org> , "Philippe Debar"
Ok :-)
Using their ASCII code in hexadecimal notation with a percent sign:  %20
e-mail: tho### [at] trfde
Date: 23 Jun 2002 05:05:28
Message: <3d158f58@news.povray.org>
OK, could you either post here or place on the site a short complete sample
scene for at least the first image, please?
    Thorsten
Date: 23 Jun 2002 05:05:29
Message: <3d158f59$1@news.povray.org>
In article <3d154105@news.povray.org> , "Slime" <slm### [at] slimelandcom> wrote:
Your obervation might be correct also not worded very well, I have noticed a
similar "defect" and I actually think I know why it is there.
    Thorsten
Date: 23 Jun 2002 05:18:01
Message: <3d159249$1@news.povray.org>
I implemented myself Perlin noise and got the same bug. Double/triple check
the way you interpolate the values on non grid points: the code of the
s's/t's (or whatever you call the interpolation fractions) is handled
exactly the opposite on might resonably think (I consider Perlin noise code
one of the most counterintuive algorithms I have ever implemented/debugged).
By the way, if POV had been a free software project, handled with CVS I
would have fixed the bug more than one month ago...
Bye
Alessandro Coppo
a.coppo@<REMOVE_ME>iol.it
www.geocities.com/alexcoppo
Date: 23 Jun 2002 06:38:52
Message: <3d15a53c$1@news.povray.org>
news:3d158f58@news.povray.org...
sample
Done. Zipped scene file in p.beta-test.binaries. Small animation that
renders the following scenes :
0) the simple f_noise3d on a plane
1) the "differenced" (there must be a proper name for this...) f_noise3d on
a plane
2) same with noise gen 1
3) same with noise gen 2
4) the "differenced", noise_gen 3, f_noise3d on a sphere
5) the pure f_noise3d on a sphere
I will post the others soon, but I have to tidy the code up and my parents
are waiting me for dinner at their place + I still have to complete my
income declaration :-(, so no Pov nor post for some hours...
Povingly,
Philippe
PS : I made a copy of the web page
http://web.wanadoo.be/wbrp0009/pov/qbugs/noisegrid/main.html at, in order to
be able to free pov/main one day... at the time being (and for some long
time I think), the two urls work.
Date: 23 Jun 2002 08:43:59
Message: <3d15c28f@news.povray.org>
  Hmm... What stops you from posting a full report of the suggested fix
to this news server?
Date: 23 Jun 2002 10:50:31
Message: <3d15e037@news.povray.org>
In article <3d159249$1@news.povray.org> , Alessandro Coppo <a.c### [at] iolit>
If you had looked at the Perlin noise function code available for years now
in 3.1 and previous versions you should have been able to notice the same
bug and could have tried to fix it...
    Thorsten
Date: 24 Jun 2002 06:47:21
Message: <3d16f8b9@news.povray.org>
in
You're right.
Supposing f_noise3d is an implementation of Perlin noise, it belongs to a
class of noises called "gradient lattice" noises in which the noise values
at fractional positions are calculated interpolating "pseudorandom slope
vectors" precalculated at the intersection of an integer grid. At integer
position the value of the noise should be zero.
A deeper and more complete explanation can be found on the book "Texturing
and Modeling, a procedural approach" by Ebert et al. where D.Peachey
explains the teorethical basegrounds and shows several noises of that kind.
necessarily
That is infact the "bad situation" which makes the integer lattice visible.
I've made a little texturing application in Java
(http://www.falappa.net/alessandro/apps/jtexcreator/index.html if you're
interested) which uses an implementation of Perlin noise and I got those
gridding artifacts too.
Alessandro
Date: 28 Jun 2002 16:05:09
Message: <3d1cc175$1@news.povray.org>
I do NOT contribute to non-free software.
Bye
P.S.: I am currently trying out Art Of Illusion (AoI)
http://www.artofillusion.org/. If it is as good as it looks it is likely
that I will say goodbye to POVRay and switch (and contribute to) AoI.
Alessandro Coppo
Date: 28 Jun 2002 17:04:45
Message: <3d1ccf6d$1@news.povray.org>
Is there a chance that future versions of POVRay (beyond 3.5) will get
released under the GPL or the LGPL, and why not?
What are the problems with such a license? I don't have a problem to
contribute to "non-free software" if there are good reasons for not
releasing it under such a license. POVRay is in fact not comercial. Why not
support it?
BTW is a Java Raytracer not slower by nature?
Florian
Date: 28 Jun 2002 18:24:20
Message: <3d1ce214@news.povray.org>
  Hmm... Since when POV-Ray has not been free?
  (AFAIK the only definition of "free software" is that it costs no money,
and POV-Ray perfectly fits this definition. Moreover, the source code of
POV-Ray is available, and you can make modifications to it and distribute
modified versions, which pretty much makes it fit inside the "open source"
definition. What else do you want? LGPL? LGPL is very nice, but not feasible
currently. GPL? No thanks.)
Date: 28 Jun 2002 18:25:22
Message: <3d1ce252$1@news.povray.org>
*thinks*
POV-Ray isn't non-free. It's free. I don't get what you're saying.
 - Slime
Date: 28 Jun 2002 18:33:31
Message: <3d1ce43b@news.povray.org>
  The GPL license has its own problems. In some ways it's so anarchist, that
it can actually be a totalitarian license.
  LGPL is really nice (and a sign of this is that many GPL guys hate it),
however, it can be a bit *too* free (eg. publishing POV-Ray under LGPL would
allow anyone to make money by selling a program which has POV-Ray linked
in it, for example being the main renderer in the program; it's not very
nice that people would exploit POV-Ray in this way).
  I don't understand how POV-Ray is "non-free". Could someone explain?
  There's no way an interpreted language can be as fast as a compiled and
highly optimized language.
  Compiling the Java code to native machine code *might* make it reach
the same speed, but I doubt that it will ever do that.
Date: 28 Jun 2002 18:38:26
Message: <3d1ce562@news.povray.org>
  It's really funny that Java hype is so strong that people don't even
care that the program is 10 times slower than one written in C++.
  In most programs it doesn't matter, but in a high-end raytracer it
certainly matters quite a lot. Why spend 10 hours rendering a scene
which could be rendered in 1 hour?
Date: 29 Jun 2002 03:37:56
Message: <sboqhu8u72uu6f05ber7i8bdbom9a0gnkc@4ax.com>
On Fri, 28 Jun 2002 22:07:13 +0200, Alessandro Coppo <a.c### [at] iolit> wrote:
So only using CVS makes program free ?
I'm also for more opened developemnt model but I fell in love with POV.
Seems it could be nice renderer for such modeler like AoI ;-)
ABX
Date: 29 Jun 2002 07:36:03
Message: <3d1d9ba3@news.povray.org>
In article <3d1cc175$1@news.povray.org> , Alessandro Coppo <a.c### [at] iolit>
Oh, how clever to first complain about not having the source code and
claiming you fixed the bug and then say you never planned to contribute it.
So the obvious conclusion is that your claim that you fixed it a month ago
is nothing more than a lie, and your only intention of this post was to
start some flame-war.  Really nice attitude! :-(
Now do us all as you promised and waste your time ray-tracing with Java than
wasting our time reading your nonsense!
    Thorsten
Date: 30 Jun 2002 16:32:05
Message: <3d1f6ac5@news.povray.org>
> it. So the obvious conclusion is that your claim that you fixed it a month
> ago is nothing more than a lie, and your only intention of this post was
> to
> than wasting our time reading your nonsense!
If you go to my website, download my JXL java library and have a look at
the jxl.num.rng package, you will find correct implementations of Perlin
noise in 1, 2 and 3 dimensions (omit if seeing Java code harms your
reproductive capabilitis...;). Before releasing that code I checked its
behaviour creating test images and debugging it (strange practise, isn't
it?)
I did not fix any POV bug, I simply discorvered it and laughed about such
silly thing still laying around in a 10 years old program!
I did not want to start a flame war... I just do not care!
Alessandro Coppo
Date: 30 Jun 2002 16:33:13
Message: <3d1f6b09$1@news.povray.org>
No...
STOP: SYSTYEM DETECTED FLAME BAIT. DO NOT RESPOND
Alessandro Coppo
Date: 30 Jun 2002 16:41:42
Message: <3d1f6d06$1@news.povray.org>
Just have a look at this URL:
http://tilde-hoschek.home.cern.ch/~hoschek/colt/index.htm
(do you notice the domain? CERN... these idiots use Java for particle
physics, poor stupid boys, aren't they?)
Alessandro Coppo
Date: 30 Jun 2002 16:43:15
Message: <3d1f6d63$1@news.povray.org>
> *thinks*
>  - Slime
It is free as beer, not as speach. Unfortunalety english uses the same word
for two extremely different concepts. For more explanations, have a look at
www.gnu.org site.
Bye!!!
Alessandro Coppo
Date: 30 Jun 2002 16:45:23
Message: <3d1f6de3@news.povray.org>
> feasible currently. GPL? No thanks.)
Fascinating: first you talk as if you did not know anything about Free
Software then you dissert upon different OSI licences... what about
deciding what position to take?
Alessandro Coppo
Date: 30 Jun 2002 16:47:35
Message: <3d1f6e67@news.povray.org>
  Yes, they are. They must have too much spare time to wait.
  I can give you a version of POV-Ray which is 10 times slower than usual.
Would you use it?
Date: 30 Jun 2002 16:50:14
Message: <3d1f6f06@news.povray.org>
>   that
> would allow anyone to make money by selling a program which has POV-Ray
> linked in it, for example being the main renderer in the program; it's not
> very nice that people would exploit POV-Ray in this way).
So stick to GPL which is EXACTLY meant to prevent your fears! LGPL is just
a stepping stone to smuggle Free Software into the commerical world then...
he he!!!
For your information it is years that Java is just-in-time compiled and, as
I wrote on another post, benchmarks show that it can be a competitor to
Assemebler for numerical tasks.
By the way, just to show you what a mature just-in-time compile technology
can do, there are benchmarks on the net which show Scheme (a dialect of
LISP) to be consistently faster than C!
Alessandro Coppo
Date: 30 Jun 2002 16:52:06
Message: <3d1f6f76$1@news.povray.org>
Well, when discussion sinks to this level, it is time to log out.
Alessandro Coppo
Date: 30 Jun 2002 17:06:50
Message: <3d1f72ea@news.povray.org>
In article <3d1f6d06$1@news.povray.org> , Alessandro Coppo <a.c### [at] iolit>
Oh, sure, nobody said you cannot _use_ Java for it!   Maybe you should have
read the page first:
May 15 - Version 1.0.1 is here - and just broke the 200Mflop barrier. Due
too further library tuning, benchmarks now show the 100% pure Java
matrix-matrix and matrix-vector multiply running only about 2.5 times slower
than the algorithms from the Intel® Math Kernel Library.
200 MFlops I can do that on my five year old computer easily, you know...
    Thorsten
Date: 30 Jun 2002 17:14:51
Message: <3d1f74cb@news.povray.org>
  Apparently I am unable to run Java in JIT-compiled mode because whatever I
do, it's slow as hell. Apparently JRE 1.3.1 does not do this. I don't know
what else could I do than download the latest JRE.
  I once found a factorization program in the net made in Java, which
factorized arbitrarily large numbers using the elliptic curve method.
I gave it a really large number, which was composed of three very large
primes, and it factorized it in something like 2 minutes in my 1.2GHz Athlon.
I thought that "wow, that was fast!".
  Well, then I found the pari/gp library and utility, which is written in C
(with some parts optimized in assembler). It also supports arbitrarily sized
numbers and factorization using the elliptic curve method.
  I run it in a 500MHz UltraSparc, which is about half fast than my Athlon
(of not even slower than that). The program factorized the same number in
less than 10 seconds.
  I have been laughing at the Java program since then.
Date: 30 Jun 2002 17:15:27
Message: <3d1f74ef@news.povray.org>
  Why are you trolling?
Date: 30 Jun 2002 17:17:20
Message: <3d1f7560@news.povray.org>
  From the page: "benchmarks now show the 100% pure Java matrix-matrix and
matrix-vector multiply running only about 2.5 times slower than the
algorithms from the Intel® Math Kernel Library."
  "Only"? Yes, the *do* have too much spare time. I don't.
Date: 2 Jul 2002 02:02:12
Message: <n8g2ius42lc9e8uiggcg8ptksuss0ou3cm@4ax.com>
On Sun, 30 Jun 2002 22:34:14 +0200, Alessandro Coppo <a.c### [at] iolit> wrote:
It is laying around becouse people prefer laughing than reporting. They prefer
free software without their possibility of help.
ABX
Date: 2 Jul 2002 02:05:58
Message: <qdg2iuobc6jjs8p34lsds1j84ngmo4k8ej@4ax.com>
On Sun, 30 Jun 2002 22:43:52 +0200, Alessandro Coppo <a.c### [at] iolit> wrote:
domain doesn't say anything about author. java skills of one of the authors
are for example described at http://wwwinfo.cern.ch/support/java/utilities/:
  "I thing that it is a nice job, even though as a begginer in Java
  (I am using Java a few weeks only), I'm not quite sure that I've
  used the best way to do it."
ABX
Date: 2 Jul 2002 03:59:15
Message: <3D215CCA.4090300@wanadoo.be>
And maybe also because it wasn't visible before isosurfaces ?
Philippe
Date: 2 Jul 2002 04:35:41
Message: <d9p2iukr9mf6n1iv1g0mqria0g3urbi5r8@4ax.com>
On Tue, 02 Jul 2002 09:56:58 +0200, Philippe Debar <phd### [at] wanadoobe> wrote:
Wasn't isosurfaces originally written for POV 2.2 ?
ABX
Date: 2 Jul 2002 09:50:20
Message: <3D21AF0C.3080409@wanadoo.be>
Oops, yes... I forgot about that (I began to discover isosurfaces with
Megapov...).
Anyway, the point I wanted to convey (I wonder why I always try the very
roundabout way instead of writing what's on my mind...) is:
Why allow a lone laughing troll to depreciate your opinion of all free
software users? The POV team itselfs, the Tag Team and most people on
this news server (yourself included) is ample proof that many are ready
to help :-)
Povingly,
Philippe
Date: 2 Jul 2002 15:47:57
Message: <3d22036d@news.povray.org>
in
Is the interpolation cubic like in sp_lines or cosine based? (
http://freespace.virgin.net/hugo.elias/models/m_perlin.htm has decription of
the funtions that I'm writing) I tried to look at the source myself but my C
skills are pretty bad. If it is cosine based the grid could be natural part
of the function. I'm thinking this because the small lines that cause the
grid are visible even when using one dimentional version of the function.
(just change f_noise3d(x,y,z) to f_noise3d(x,0,0) ) Sorry if this is too
newbie question for advanced-users.
Klaus Lehtonen
Date: 2 Jul 2002 17:45:31
Message: <chrishuff-E851E1.16424602072002@netplex.aussie.org>
In article <3d22036d@news.povray.org>,
If I remember correctly, that page describes a very different algorithm
than what is usually called "Perlin noise". It uses a bitmap filled with
random values and then interpolated to get the basic noise, which is a
very simple and direct way of doing it but doesn't give great results.
The algorithm Ken Perlin came up with was quite different and more
complex, I don't understand all of it and can't explain it here, but it
doesn't rely on a 2D or 3D bitmap.
http://www.mrl.nyu.edu/~perlin/doc/oscar.html
http://students.vassar.edu/mazucker/code/perlin-noise-math-faq.html
http://www.threedgraphics.com/texsynth/
Date: 4 Jul 2002 07:51:41
Message: <3d2436cd@news.povray.org>
"Christopher James Huff" <chr### [at] maccom>
Thanks for the links. I think I understand what is causing the grid. I've
made a web page that explains it. http://koti.mbnet.fi/lehtkl/f_noise3d.htm
What do you think does this make some sense or am I just dreaming here?
Date: 4 Jul 2002 08:08:20
Message: <3D243A20.9000908@wanadoo.be>
>> sample
<snip>
e-hem... I did not... Would they be useful? If yes, I'll try to post
them this week-end. If no, well...
Philippe
