POV-Ray : Newsgroups : povray.advanced-users : Clouds Server Time
5 Nov 2026 06:52:03 EST (-0500)
  Clouds (Message 1 to 14 of 14)
Subject: Clouds
Date: 3 Mar 2002 22:29:35
Message: <3c82ea1f$1@news.povray.org>
Alright, I've got some really neat looking clouds using the stacked planes
method, but it only looks good at lower resolutions. So when I increase the
resolution, I increase the number of layers. However, when I get to the
point of over 100 or so layers, POV-Ray says: Too many nested refraction
objects. I assume this has something to do with stack overflows from the
recursion?
Is there anyway around this? If I decrease the max_trace_level, I get black
sillouts of the disc object, but if I don't have enough disks, you can see
the individual layers. Any ideas?
Subject: Re: Clouds
Date: 3 Mar 2002 23:48:06
Message: <3c82fc86@news.povray.org>
"Chris Becker" <cmb### [at] ritedu> wrote in message
news:3c82ea1f$1@news.povray.org...
> recursion?
black
There is a work-around.  Use very thin cylinders (however infinitely thin is
impossible).  It seems to be a limitation with infinite objects of which
disc and plane are two such things.
I don't know the reason for it or if there's a setting that will circumvent
this error.
bob h
Subject: Re: Clouds
Date: 4 Mar 2002 00:35:16
Message: <chrishuff-7E2D75.00352004032002@netplex.aussie.org>
In article <3c82ea1f$1@news.povray.org>,
> recursion?
Planes only have one surface, so POV never exits a layer, and it sees
all the layers as being nested. Use an object which the ray will
eventually exit, like a box. The box will simulate two planes, halving
the number of objects used for the clouds, and will be better bounded
than planes.
Subject: Re: Clouds
Date: 4 Mar 2002 02:23:43
Message: <3c8320ff@news.povray.org>
Wow, it was that simple, it worked better than great!
Thanks a bunch!
the
> recursion?
black
Subject: Re: Clouds
Date: 4 Mar 2002 23:02:55
Message: <3c84436f$1@news.povray.org>
> method, ...
I don't understand why people use this "stacked-planes" technique when
method 3 media basically simulates it, sometimes making it faster because of
it's anti-aliasing capability.
Unless, of course, one doesn't have version 3.5, although I created some
pretty good clouds with 3.1 media once...
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Subject: Re: Clouds
Date: 5 Mar 2002 07:08:12
Message: <3c84b52c@news.povray.org>
  When a concept gets popular, it's quite difficult to eradicate. In this
case the concept is "media is slow".
  (Another example of this kind of misconception is "area lights are slow;
it's better to use an array of point lights". See
http://www.students.tut.fi/~warp/povQandT/misconceptions.html#arealightconfusion)
Subject: Re: Clouds
Date: 5 Mar 2002 10:13:15
Message: <3C84E0E0.16BE866A@engineer.com>
I have a scene where area_light length*x,z,32,1 takes 6 times
longer to render than 32 point lights.
_____________
Kari Kivisalo
Subject: Re: Clouds
Date: 5 Mar 2002 17:07:59
Message: <3c8541bf@news.povray.org>
I'd be interested in the source.
- Slime
Subject: Re: Clouds
Date: 5 Mar 2002 17:12:34
Message: <3c8542d2@news.povray.org>
  Me too. There's no logical explanation for this.
  (Unless 1-dimensional light sources have some defect or bug in POV-Ray.)
Subject: Re: Clouds
Date: 5 Mar 2002 17:43:08
Message: <3C854A52.15853322@engineer.com>
Here is the 2.0 source hastily converted to 3.5:
#version 3.5;
#declare USE_AREA=1;
  location  <6,6,-6>
  direction <0,0,1.5>
  look_at   <1,0,0>
#declare length=10;
#declare h=0.6;
#declare i=1;
#declare tube1=
union{
  light_source{
    <0, h, 0>
    color rgb i
  cylinder{
    <-length/2,h,0>,<length/2,h,0>,0.05
    pigment{color rgb<1,1,1>}
    finish{diffuse 0 ambient 1}
    no_shadow
#declare d=length/31;
#declare di=i/32;
#declare light=light_source{<-length/2,h,0> color rgb di}
#declare tube2=
union{
  #declare I=0;#while(I<32)
    object{light translate I*d*x}
  #declare I=I+1;#end
  cylinder{
    no_shadow
#if(USE_AREA=1)
  object{tube1}
#else
  object{tube2}
#declare ball=sphere{<0,0.25,0>,0.25}
#declare row=
union{
  object{ball translate<-1.5,0,0.5>}
  object{ball translate<-0.5,0,0.5>}
  object{ball translate<0.5,0,0.5>}
  object{ball translate<1.5,0,0.5>}
union{
  object{row translate<0,0,1>}
  object{row translate<0,0,0>}
  object{row translate<0,0,-1>}
  object{row translate<0,0,-2>}
  finish{diffuse 1.5 ambient 0.1 phong 1}
plane{y,0
  texture{
    pigment{checker color rgb<1,1,1> color rgb<0.5,0.8,1>}
    finish{diffuse 1.5 ambient 0.1}
    scale 0.5
_____________
Kari Kivisalo
Subject: Re: Clouds
Date: 5 Mar 2002 18:42:55
Message: <3c8557ff$1@news.povray.org>
Interesting. It seems as though you're right.
Here's what I suspect: when I changed the number of lights in the Z
direction of the area light to 2, the render time didn't change (38 seconds
with either 1 or 2 in the z direction). I think maybe POV-Ray is treating
1-dimensional light sources as two-dimensional ones, thereby checking each
point on the area light twice. If this is right, it borders on a bug...
- Slime
Subject: Re: Clouds
Date: 6 Mar 2002 17:21:02
Message: <3c86964e$1@news.povray.org>
The reason I used stacked planes is that it was a very simple idea and I was
just exploring how well it works. I can see that it does have its
limitations due to how close you can get and a limit of 256 recursion depth
(at least on  Windows 98). The one thing I found that was really great was
that I could use the 'object' pattern and actually model a cloud and then
you the turbulence modefier to make it wavy and such which produced some
very nice results. Also, with the stacked plains and the 'filter' color, you
can light the cloud and it will actually shadow itself like a gas really
does.
Is it possible to do all that with media, and is there some kind of tutorial
that might help me with it? (My luck with media is very very low, I change
something from the demo scene file and poof, it's all gone)
news:3c84b52c@news.povray.org...
because of
sion)
M()}}
Warp -
Subject: Re: Clouds
Date: 7 Mar 2002 12:51:04
Message: <chrishuff-D937E0.12511407032002@netplex.aussie.org>
In article <3c86964e$1@news.povray.org>,
> very nice results.
This is at least as easy with media density, just use the object pattern
with turbulence.
> Also, with the stacked plains and the 'filter' color, you can light
> the cloud and it will actually shadow itself like a gas really does.
This is automatic with scattering media. Media doesn't have problems
with recursion limits, and you don't need as many samples in the first
place because they are spaced differently, more like planes
perpendicular to the camera.
Subject: Re: Clouds
Date: 9 Mar 2002 04:04:25
Message: <3c89d019$1@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3c8557ff$1@news.povray.org...
> I think maybe POV-Ray is treating 1-dimensional light sources > as
two-dimensional ones, thereby checking each point on the
I don't think so. I changed the spheres into boxes to see the shadows
better, lifted the light to 2.6 and got the following:
area_light, area 32x1, points 32x1
Box                    21684326       2200482     10.15
Cone/Cylinder          54435326      54420812     99.97
Plane                  56639191        969192      1.71
Bounding Box          339332733     110901120     32.68
Vista Buffer            3909343       2764547     70.72
Shadow Ray Tests:       7041549   Succeeded:    2095158
Time For Trace:  0 hours  3 minutes  11.0 seconds (191 seconds)
Notice the Cone/Cylinder intersection tests..
area_light, area 32x1, points 32x2
Box                     43843409      4878047     11.13
Cone/Cylinder              33295        18794     56.45
Plane                   55546322       971544      1.75
Bounding Box           285838244      3696599      1.29
Vista Buffer             3928127      2776387     70.68
Shadow Ray Tests:       97865400   Succeeded:   4766193
Time For Trace:  0 hours  2 minutes  46.0 seconds (166 seconds)
I guess the extra ray->shape intersection tests come from the lights being
inside the cylinder in the 32x1 points case. Could this be avoided some how?
I don't see why all the test should be done if the light_source is unioned
with a no_shadow object. Using looks_like gives also approximately the same
result as in the 32x1 case.
Ari-Matti
