POV-Ray : Newsgroups : povray.advanced-users : The Harcore Povrayer Test Server Time
5 Nov 2026 08:27:09 EST (-0500)
  The Harcore Povrayer Test (Message 1 to 50 of 77)
Goto Latest 50 Messages Next 27 Messages >>>
Subject: The Harcore Povrayer Test
Date: 31 Jan 2002 11:58:22
Message: <3c5977ae@news.povray.org>
Some years ago I made a "Hardcore Povrayer Test" just for fun. Here it is
again, with small updates.
  For each statement which you feel is true in your case (be sincere), take
one point. The number of points you get is your score. The maximum number
of points is 65.
  (My personal score is "only" 37, so it *is* a tough test.)
* You have participated in the IRTC and got to the top 20 best images.
* You have won a price in the IRTC.
* You have made bicubic patches by hand (and they worked as you expected).
* You have made a pov-script that creates a smooth surface with bicubic patches
  using some algorithm.
* You have made triangle meshes by hand.
* You have made a pov-script which generates triangle meshes using some
  algorithm.
* You have used the quadric, cubic, quartic or poly primitives.
* You have used poly objects bigger than 4th degree.
* You have calculated the polynomial for that poly object by yourself
  (instead of looking at the formula somwhere or just trying random values).
* You know the format of a PCM file.
* You have made one by hand.
* You have made a program which outputs a df3 file and used it in a scene.
* You know what a df3 file is and what's its format.
* You have made a patch for povray.
* Your patch is included in MegaPov or at least it's popular.
* Your patch was included in POV-Ray 3.5.
* You have made a popular tool for povray.
* You have used every object type, every camera type, every light source
  type, every media type, etc. and know how to use them.
* You could write a torus-shaped isosurface by memory, without needing
  to look anywhere for the function.
* Even if you don't remember the torus function, you could deduce it by
  yourself, without looking it anywhere.
* You know what is the "sturmian root solver" thing which is used with the
  'sturm' keyword in some objects (ie. you know the algorithm it uses).
* The intensity multiplier curves and light fading functions in the light
  source section of the povray manual are very clear and you understand
  them perfectly (and you might use them to choose your light source
  types).
* You understand how photon mapping works (at algorithm level).
* You have found the 'average normal bug' by yourself in a povray version
  previous than 3.1e.
* You know exactly what was causing it.
* You never include the povray include libraries (like colors.inc) because
  they slow parsing, but always define your colors, textures, etc by
  yourself.
* You only use the png format when working with povray.
* You always use it with alpha channel.
* It's very easy to you to make slope maps and actually you often use
  them to make your textures.
* You know what the 'use_index' keyword is used for without looking at
  the manual.
* You understand the matrix transformation and you can write them by hand.
* You know how to calculate the matrix from any number of consecutive
  transformations (translate, scale, rotate).
* For any given identifier name you can tell by heart if it's a reserved
  keyword (ie. an illegal identifier name) or not (of course without having
  syntax highlighting to help you).
* You could make any of the Chris Colefax's includes or macros by yourself
  if you wanted.
* You use frequency, phase, octaves, omega and lambda without problems
  when creating your own textures.
* You can tell what does each one of them do (without looking at the
  documentation).
* You understand the scattering function pictures in the media section of
  the documentation.
* You remember all the keywords that can be put in a global_settings block and
  you know what do they mean and how to use them.
* Making good-looking radiosity images is not a problem to you.
* You remember all the built-in float and vector identifiers.
* You use all the vector and string functions without problem.
* You know if some special feature is already implemented in the POV-Ray 3.5
  standard include files (and thus you know you don't have to implement it
  yourself).
* Functions, macros, arrays, loops and file-IO directives are a piece of cake.
* You never get the "camera is inside non-hollow object" warning. If you
  ever get it, it's absolutely intentional.
* You have made a modeller for povray.
* You often debug your povray code using the text message streams.
* You can easily calculate the camera parameters when you want to put a
  box right in front of the camera so that it completely and exactly fills
  the viewing area.
* You know which .c and .h files you must change to add a keyword to the
  parser.
* You can add a keyword and get it right the first time.
* You know which .c file contains the functionality for each aspect of
  the renderer.
* You can find a bug in the renderer source code given just a description
  of the symptoms and without using a debugger.
* You know BOTH reasons why a mesh can't be used in CSG.
* You know why refraction and media do work with meshes, even though CSG
  doesn't.
* You know that 'merge' doesn't have to be a primitive CSG operation
  and can recite the equivalent sequence of intersections, unions, and
  inverses.
* You know that 'difference' isn't a primitive CSG operation and you
  know how POV represents one internally.
* You understand how 'bounded_by' _really_ works.
* You know that a height_field has an inside and how it is defined.
* You've written your own include file and distributed it on the net. It has
  got some popularity.
* You understand all the options to 'media' without having to look in
  the manual.
* You know, without looking at the docs, how antialiasing methods 1 and 2 work
  and what's their difference.
* You have made yourself an obfuscated signature in POV-Ray SDL in 4 lines
  or less, and you use it by default when posting to the POV-Ray news server.
* You didn't know the answer to one of the above questions so you tried
  to find it in the manual.
  to find it in the source code.
* You didn't know that 'merge' wasn't a primitive but now that you do
  you have worked it out for yourself.
* You are a member of the POV-Team.
Subject: Re: The Harcore Povrayer Test
Date: 31 Jan 2002 12:35:16
Message: <slrna5j02k.gm.ron.parker@fwi.com>
On 31 Jan 2002 11:58:22 -0500, Warp wrote:
46.  More if I can get multiple points for the .signature one. :)  But
you're only really hardcore if you use that .signature on Usenet too.
Of course, it's impossible to get a perfect score, but I didn't even get
close.  Too many "knows all the options to <complicated thing nobody ever
uses all the options for>" questions.
Also, while you're updating, the .c questions will have to change to .cpp.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 31 Jan 2002 12:39:31
Message: <3c598153$2@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3c5977ae@news.povray.org...
> of points is 65.
15 for me.
Tom Bates
(let's see if this doesn't get wrapped this time)
#macro T(B)#local m=mod(B,8);#local B=floor(B/8);m#end#local C=126981491245202;#
local D=115694168992822;sphere_sweep{b_spline 16#local i=0;#while(i<16)<T(C)-4,T
(D)-4,10-i/10>.1#local i=i+1;#end pigment{rgb 1}}light_source{-10,1} //Tom Bates
Date: 31 Jan 2002 12:53:09
Message: <3C59846D.AA650653@gmx.de>
14!
Wow, I'm a genius!
I agree with Ron Parker that many questions aren't realistic,
those "know all about everything that is concerned with X"
may be true in some cases, but in most, you'll have to be
Einstein or Rain Man to do that...
Tim Nikias
Date: 31 Jan 2002 13:18:41
Message: <3c598a81$1@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote:
> 14!
87178291200 ? ... wow ... thats a lot
#macro J(N A)#local a=mod(N 3);#local W=<int(mod(A,4)*2)int(-A/4)9>*2;#if
(!mod(a 2))sphere{W,2,2pigment{color rgb<a*5A/2W.x/A*5>}}#if(a<1)sphere{W
+<2,0>2 2pigment{color rgb<a*10A 10>}}#end#end#if(N>3)J(int(N/3)A+1)#end#
end blob{J(29229171 0)threshold 1translate<-6 3>}/******Jan Walzer******/
Date: 31 Jan 2002 13:32:43
Message: <3c598dcb@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Too many "knows all the options to <complicated thing nobody ever
: uses all the options for>" questions.
  I'm open to suggestions. :)
Date: 31 Jan 2002 13:51:11
Message: <3c59921f@news.povray.org>
In article <3c598dcb@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
How about "You modified POV-Ray to support real-time ray-tracing"?
    Thorsten
e-mail: tho### [at] trfde
Date: 31 Jan 2002 13:57:00
Message: <3c59937c@news.povray.org>
In article <3c5977ae@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Mine is 36 - I really should _use_ POV-Ray more often...
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 31 Jan 2002 14:02:34
Message: <3c5994ca@news.povray.org>
25.
But, uhm:
* You didn't know the answer to one of the above questions so you tried to find
it in the manual.
So you get a point for cheating?
cu!
Date: 31 Jan 2002 14:09:31
Message: <slrna5j5jb.gn.ron.parker@fwi.com>
On Thu, 31 Jan 2002 20:02:27 +0100, Zeger Knaepen wrote:
> 25.
> But, uhm:
> it in the manual.
Nope.  You get a point for trying to better yourself.  You don't get the
point for the question you had to look up the answer to.  Thus, the best
score you can get is 64.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 31 Jan 2002 14:55:54
Message: <Xns91A7D532EF6C9seed7@povray.org>
in news:3c5977ae@news.povray.org Warp wrote:
23,
...and they let me fool around with the docs....
Ingo
Date: 31 Jan 2002 14:57:25
Message: <3c59a1a4@news.povray.org>
Zeger Knaepen <zeg### [at] studentkuleuvenacbe> wrote:
: * You didn't know the answer to one of the above questions so you tried to find
: it in the manual.
: So you get a point for cheating?
  The meaning of that is that you didn't know the answer to some question
and thus you didn't take a point in that question, but it interested you
so much that you tried to find the answer.
Date: 31 Jan 2002 15:00:49
Message: <3c59a271@news.povray.org>
  Hmmm... only 21, and cheating a bit! Hardcore is not for me... I will
better keep listening groove.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 31 Jan 2002 15:10:01
Message: <3C59A485.39D4EB53@gmx.de>
> of points is 65.
30, but with some questions i had doubts about the answer (and then
answered 'no').
A lot of questions are not very good, i picked out a few of them:
>   yourself.
This is total crap of course, esp. with Povray 3.5
Why does this qualify for a hardcore Pover?
Can you define 'modeller' please?
What is the second one?
I also have some suggestions:
* You have written isosurface functions by hand with more than X
characters (for 'X' use a reasonable value, for example 2000)
* You know the parameters of every internal function of Povray 3.5
(functions.inc) without looking it up. (that's a really hard one, maybe
just knowing every function is enough...)
* Your longest render was more than X days (X=5, 10, 20 or more)
Date: 31 Jan 2002 15:12:39
Message: <3c59a537$1@news.povray.org>
25 ...
damn ...
maybe additional point for:
"you don't know .... but you know exactly where to find it in the docs ?"
Date: 31 Jan 2002 15:22:26
Message: <slrna5j9s3.in.ron.parker@fwi.com>
Oh, sure, we tell you and then you tell someone else and pretty soon
everyone has an extra hardcore point.
It's because (at least in 3.1) All_Mesh_Intersections doesn't actually
return all of the intersections; it just returns the closest one.
I rendered the sample scenes on my old Amiga when I started using POV;
some of those took days to render.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 31 Jan 2002 16:06:19
Message: <3c59b1cb@news.povray.org>
In article <3C59A485.39D4EB53@gmx.de> , Christoph Hormann
Whatever size you pick up to the limit that functions allow, I have created
such a function ...  not that alternating sequences of x-x+y-y+z-z or similar
combinations make a lot of sense ;-)
    Thorsten
Date: 31 Jan 2002 16:08:28
Message: <3C59B235.2B73FBC0@gmx.de>
I only know one reason: There is no 'inside' and 'outside' in a mesh.
This is perfectly sufficient.  The problem with this questions is that you
can answer it on different levels, the logical and the programming level,
of course in the latter you can easily find several reasons.
The idea for this question is that a hardcore Pover devotes more
computational power to render jobs, whether the scene is complicated or
not is not the question IMO.
Date: 31 Jan 2002 16:13:38
Message: <MPG.16c3cab4ad23cad9896be@news.povray.org>
In article <3c5977ae@news.povray.org>, war### [at] tagpovrayorg says...
I didn't pass one single question of the test, so I guess for me it is
0.
Who did worse??
Sander
Date: 31 Jan 2002 16:17:45
Message: <slrna5jd3p.js.ron.parker@fwi.com>
Nope, those two are the only ones I know.  The 'inside' vs. 'outside' thing
is basically programming, too, in the case of meshes where such is defined,
so I don't see the same dichotomy you do here.
Date: 31 Jan 2002 16:37:32
Message: <3C59B8FC.9955EE2B@gmx.de>
Probably this should be changed to 'You have written and used in a
scene'.  You are still allowed to answer yes of course... ;-)
Date: 31 Jan 2002 16:38:45
Message: <3C59B954.818D8FF2@gmx.de>
If you have a method to determine if some point is inside or outside the
object there is nothing further needed apart from the existing
intersection routines.  This makes only one reason why a mesh can't be
used in CSG.
Or did i miss something essential?
Date: 31 Jan 2002 16:51:34
Message: <3c59bc66@news.povray.org>
y-y-y-n-y-n-n-n-n-y-n-n-y-n-n-n-n-y?-y-y-n-y-y-n-n-y?-y-n?-y-n-y-n-y?-y, but probably
worse-y-y-n-y-y-y-y-y, I think-y-y-n-y-n, but give me a piece of paper and could try
it-n, never looked at the source-n-n-n-n, just the obvious one-y-n, really?-y-y-y-y
but not for the popularity-y-y-n, not obfuscated-y-y: intersection {
sphere {
    y-x/2,1 inverse}
sphere {
    y+x/2,1 inverse}
inverse
        rgb 1 transmit 0.5}
-definitely no.
So, that would make it a... 36. Hmm, maybe I cheated a bit too much?
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
Date: 31 Jan 2002 16:59:25
Message: <3c59be3d@news.povray.org>
> 0.
> Who did worse??
Zero, but i'd get a point if the first question read:
* You have participated in the IRTC and got to the top 21 best images.
Although I did once write some code to display triangle meshes. It even
performed simple shading...
does that count as a modeller?
So with a little cheating I get 2 points -  more of a softcore pover I
think...that'd be my Channel 5 compared to Warp's Adult Channel ;>
Jim
Date: 31 Jan 2002 17:45:57
Message: <v2ij5usc5eg7t031erq66n6msdqp6vqo4g@4ax.com>
On Thu, 31 Jan 2002 22:38:28 +0100, Christoph Hormann
>used in CSG.
For CSG, you'll need all intersections, and in 3.1, the
All_Mesh_Intersections function returned just the closest one (for
speed reasons I guess).
Peter Popov ICQ : 15002700
Date: 31 Jan 2002 17:46:25
Message: <3C59C898.951097B2@hotmail.com>
> of points is 65.
My score: About 10.
Tor Olav
Date: 31 Jan 2002 17:50:56
Message: <99ij5uc2cccb4c76umefpa8dvhkk43sg3k@4ax.com>
Does being a TAG member count? How about alpha and pre-beta testers?
How about coordinators (scene files, docs)?
Does writing a raytracer count? How about a 3D engine using other
methods of visualization (voxel geometry, point clouds, scanline)?
Maybe you should include the julia object in there in terms of trivia.
Well, that's pretty much it for now.
Date: 31 Jan 2002 18:21:13
Message: <3c59d169@news.povray.org>
oh, yes, forgot about that :)
cu!
Subject: Improved test
Date: 31 Jan 2002 18:39:34
Message: <3c59d5b6@news.povray.org>
Ok, I tried to make the test more rational and also divide it into more
readable sections. What do you think? What is your new score?
  The maximum score (this time I think it's reachable) is 66.
  I myself got a score of 48. (Ok, perhaps the test got a bit biased
torwards my own knowledge, but I tried to keep it as unbiased as possible;
judge by yourself :) )
POV-SDL:
  to you.
* You don't like modellers because they don't allow you to create your
  scenes algorithmically. It's a lot more interesting to find an algorithm
  to create certain effect or surface than just doing it with the mouse.
* It's not unusual that the scene files you write take several minutes to
  parse, even though the file itself only takes a few hundreds of lines.
* It sometimes happens that the scene you made takes a lot longer to parse
  than to render, even at a very high resolution and lots of antialiasing.
POV features:
* You have made bicubic patches by hand, by writing plain coordinates (and
* You know the principle behind joining several bicubic patches so that they
  form a contiguous smooth surface (with no sharp edges).
* You know what is the relation between bicubic patches and bezier splines.
* You have made triangle meshes by hand, by writing plain coordinates.
  algorithm.
* These meshes you create usually use UV-mapping.
* You know the basic principle of smoothing a mesh, ie. make a mesh of
  smooth triangles from a mesh of regular flat triangles.
* You can tell what does each one of them do.
  the documentation.
  types).
  if you wanted.
  yourself).
  and what's their difference. You know why method 2 gives usually a much
  better result but is slower.
Math:
* Making isosurfaces is not a problem to you. The only problem is just
  figuring out the right function.
* You usually know when an isosurface function can be implemented as a
  poly primitive, and you could convert the function to polynomial form and
  construct the poly primitive from it (the torus function is one example
  of this).
  'sturm' keyword in some objects (ie. you know the algorithm it uses) and
  why it is needed sometimes.
  transformations (translate, scale, rotate). (This means, for example,
  that you could write a #macro which creates the matrix transformation from
  any given set of other transformations.)
* You know how to use all the internal float, vector and string functions
  without problem. You usually use them a lot.
  the viewing area.
Raytracing algorithms:
* You know the principles of raytracing. For example, you know how to calculate
  the intersection of a segment and a simple primitive like a sphere, and
  how to calculate basic lighting for this intersection point. You might even
  have written a simple raytracer some time.
* You understand why hidden surface removal, shadow testing, reflections and
  refractions are so easy to implement in raytracing and so difficult to
  implement in other rendering techniques. You know how they are implemented
  in raytracing.
* You understand why non-linear transformations are next to impossible to
  implement for any given primitive. You understand why, regardless of this,
  any type of transformation is possible for pigments and such.
* You know how CSG operations are implemented in raytracing.
  inverses.
  doesn't.
* You understand how the stochastic radiosity algorithm used by POV-Ray
  works at algorithmical level.
* You understand how photon mapping works at algorithmical level.
* You understand how dispersion works at algorithmical level.
Formats:
The IRTC:
* You participate in almost every IRTC contest.
* You have got to the top 20 best still images.
POV-Ray programming:
* You have made a popular external tool for povray.
* You know which .cpp and .h files you must change to add a keyword to the
  parser.
* You know which .cpp file contains the functionality for each aspect of
  the renderer.
Subject: Re: Improved test
Date: 31 Jan 2002 22:20:57
Message: <slrna5k2cq.n3.ron.parker@fwi.com>
On 31 Jan 2002 18:39:34 -0500, Warp wrote:
54 this time.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 1 Feb 2002 00:30:11
Message: <chrishuff-9416FA.00312201022002@netplex.aussie.org>
In article <3c59d5b6@news.povray.org>, Warp <war### [at] tagpovrayorg>
I also got 48, not counting the ones mentioned below.
Well...I've done a lot of work on the scene and include file collections
for 3.5, and I once released a macro collection, though nobody ever used
it...
No...if I need that much control of surface features, I generally use
isosurfaces. ;-)
>   yourself).
I think I'll refrain from answering this one...
Nope, I stick to isosurfaces. That count? I think it should...
I've used polynomials of greater than 4th degree in isosurfaces...
Hmm...you know how to do real blurred reflection, you can get the media
parameters right on the first try (or first few tries), you know the
difference between using a colored transparent texture and using
fade_color or media, you can explain why using a mesh is better than a
union of triangles, you've run into the "patterned textures in layered
textures" error, you've reached the depth limit in recursive macros, you
have used the POV-Ray scene description language for purposes which have
nothing to do with scene description...
Date: 1 Feb 2002 00:43:47
Message: <3c5a2b13@news.povray.org>
I got a 43.
Mark
Date: 1 Feb 2002 00:56:40
Message: <slrna5kbgq.rc.ron.parker@fwi.com>
You had a hand in creating the current method used to do blurred reflection;
you've run into the "too many layers" error...
...you've gotten past it by creating a single-layered texture that looks just
like the one you couldn't get with layers...
...you've done that without using a texture_map;
you've used nested pigment_maps;
you understand what "form" and "metric" do in the 3.5 crackle pattern;
you understand why, given that A is #declared as a number, (A) and A aren't
always the same thing;
you've used 'radial' more than once in the same pigment;
you know all of the options to the repeat warp;
you've used one or more repeat warps to create your own infinitely-tileable
patterns;
...at least one of those patterns does not appear to be made of rectilinear
regions;
you know how to force the media code to take more samples in an interesting
area of the scene;
you understand why a plane makes a bad media container;
you know how to use type 5 scattering media;
you know how to simulate distance-dependent reflection;
you know how to use .df3 files to create arbitrary full-color solid pigments;
you've used multiple text objects to achieve a desired text effect...
Date: 1 Feb 2002 01:11:55
Message: <3c5a31ab@news.povray.org>
32
cu!
Date: 1 Feb 2002 01:14:05
Message: <3c5a322d@news.povray.org>
news:3c59d5b6@news.povray.org...
8 :-<  (10 if I take the questions about itrc literally since my best
placing pic was
created in Vue d'espirit)
Warp, I suggest for the questions about top 20 and prize in irtc add the
requirement that the pic must have been created in pov-ray
Gail
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)//GS
Date: 1 Feb 2002 02:25:35
Message: <3C5A42EA.D5A63AA8@gmx.de>
I think i understand what you mean, so it's clearly a 'Povray internals'
question and not a 'Raytracing in general' one, of course it's perfectly
valid for the list though.
Date: 1 Feb 2002 03:19:13
Message: <3c5a4f81$1@news.povray.org>
25 now for me (up 10 from 15).
including:
(I do now)
Tom Bates
Date: 1 Feb 2002 04:34:34
Message: <Xns91A86BD86DCE1seed7@povray.org>
in news:slr### [at] fwicom Ron Parker wrote:
> you ....
After all this harcore stuff,
you actually renderd a complete scene, posted it, somebody even liked it
and publicly said he uses it as his desktop image.
Ingo
Date: 1 Feb 2002 06:08:36
Message: <3C5A772E.8EF28446@gmx.de>
40
not counting those i have learned meanwhile (like the mesh-CSG question)
You threw out several very nice questions i think, most ones added are not
bad, but generally quite easy, you should give Ron some more room for
improvements... ;-)
Date: 1 Feb 2002 06:27:12
Message: <3C5A7B8A.37F8BF3B@namtar.qub.ac.uk>
I got 24 in this one. Now to try the new version...
signature{
Date: 1 Feb 2002 06:31:09
Message: <3c5a7c7d@news.povray.org>
I got 25.
Some observations.
yourself.
  Not because they are too slow to load but because it's usually faster to
  write what I want than to look it up in the includes.
You only use the png format when working with povray. You always use it
with alpha channel.
  No, only when appropriate.
  I'll credit myself with another point for that thank you ;)
yourself).
  I'll be getting 3.5 when the source code comes out.
  How else?
PoD.
Date: 1 Feb 2002 06:33:20
Message: <3C5A7CFA.69A5EBEA@namtar.qub.ac.uk>
> it...
Actually, I was just looking at your site and saw a picture of a DNA
ring. If you still have the macro for generating that, I'd like it.
signature{
Date: 1 Feb 2002 06:39:18
Message: <3C5A7E5F.F2DF7A14@namtar.qub.ac.uk>
POV-SDL: 6
POV features: 9
Math: 9
Raytracing algorithms: 6
Formats: 1
The IRTC: 0
POV-Ray programming:1
Total: 32
That was informative; splitting it up into sections gives a better idea
of your area of expertise.
signature{
Date: 1 Feb 2002 07:26:55
Message: <3c5a898f$1@news.povray.org>
you're right...
my scores are:
POV-SDL: 6 / 8
POV Features: 11 / 19
Math: 6 / 12
Raytracing Algorithms: 7 / 11
Formats: 0 / 4  :-/
IRTC: 1 / 3
POV-Ray Programming: 0 / 9 :-/
Total: 31 / 66 ... Weird, my other post says 32 :)
(considering "I think I know why" is the same as "I know why")
cu!
Date: 1 Feb 2002 07:43:04
Message: <3C5A8DD3.3FC94AF0@pacbell.net>
Does not. It just depends upon what you are trying to accomplish.
Ken Tyler
Date: 1 Feb 2002 08:02:38
Message: <3c5a91ee@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
:> * You have used the quadric, cubic, quartic or poly primitives.
: Nope, I stick to isosurfaces. That count? I think it should...
  No, it doesn't count.
  The idea behind that question is that using polys is more challenging
and requires a bit more mathematical knowledge.
  Anyone can make a torus-shaped isosurface knowing the torus function.
However, try to convert that function to polynomial form and construct the
equivalent quartic. That's a bit more challenging math.
  (I know. I have even made a webpage about the issue.)
Date: 1 Feb 2002 08:25:30
Message: <3C5A9742.AF657613@namtar.qub.ac.uk>
Oh, good point; it's the percentage that matters, not the absolute score
(wouldn't think I was a maths student...)
Mine:
POV-SDL:         6/8  = 75%
POV features:    9/19 = 47%
Math:            9/12 = 75%
RT algorithms:   6/11 = 55%
Formats:         1/4  = 25%
The IRTC:        0/3  = 00%
POV programming: 1/9  = 11%
Total:           32/66= 48%
Zeger's:
POV-SDL:         6/8  = 75%
POV features:    11/19= 47%
Math:            6/12 = 50%
RT algorithms:   7/11 = 64%
Formats:         0/4  = 00%
The IRTC:        1/3  = 33%
POV programming: 0/9  = 00%
Total:           31/66= 47%
signature{
Date: 1 Feb 2002 11:17:52
Message: <3c5abfb0$1@news.povray.org>
18.5... maybe.... And I could add a point by opening the documentation up.
Okay, so I'm no where near a "hardcore" POVer.  I think my score could even
be subtracted by 4 points considering I'd have to double-check everything to
know it for certain.
bob h
Date: 1 Feb 2002 12:58:54
Message: <slrna5llr1.3kq.ron.parker@fwi.com>
That's "harcore", Bob.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 1 Feb 2002 13:29:54
Message: <3c5adea2@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
even
Oh, as in Harcore Composites http://hardcorecomposites.com/highlights.html
bob h
