POV-Ray : Newsgroups : povray.advanced-users : adc_bailout Server Time
13 Nov 2025 11:10:43 EST (-0500)
  adc_bailout (Message 1 to 2 of 2)
Subject: adc_bailout
Date: 19 Nov 2001 00:30:12
Message: <3bf898e4@news.povray.org>
-Hail
  I am wondering about adc_bailout and how it affects the 16-bit image
output. Do I have to change or disable this feature from the global_settings
block or are the default settings adequate for 16-bit output?
Subject: Re: adc_bailout
Date: 19 Nov 2001 04:08:40
Message: <3bf8cc18@news.povray.org>
Vampyrium <cyb### [at] hotmailcom> wrote:
:   I am wondering about adc_bailout and how it affects the 16-bit image
: output. Do I have to change or disable this feature from the global_settings
: block or are the default settings adequate for 16-bit output?
  I think that the default value for adc_bailout is 1/256, so technically you
are right: If you want to get the whole accuracy of a 16-bits-per-channel
image, you should change it to 1/65536.
  I wonder if POV-Ray should change this automatically if a 16bpc image is
used...
