POV-Ray : Newsgroups : povray.advanced-users : macro inside a loop Server Time
29 Jul 2024 18:21:17 EDT (-0400)
  macro inside a loop (Message 1 to 4 of 4)
Subject: macro inside a loop
Date: 19 Oct 2001 02:31:46
Message: <3bcfc8d2$1@news.povray.org>
I have the following:
//macro to make a tube of rings of spheres
#macro sphereTube(height, tubeRadius, elements, bottomSurface, topSurface,
place)
 #declare i = 10;
 #declare shift = <0, 0, 0>;
 #while (i < height)
  objectRing(
   tubeRadius, //radius of ring
   elements, //number of objects in ring
   bottomSurface, //start texture of object
   topSurface, //end texture of object
   place + shift //place away from origin
  #declare shift = shift + <0, ballRadius(tubeRadius, elements)*2*i, 0>;
  #declare i = i+1;
The problem is that the macro inside the loop (which functions properly) is
not being called more than once.  In fact, even the message I am given says
there are only a certain amount of frame level objects, as opposed to a
certain amount of frame level objects times the height (which is the loop
condition).
If you replace the macro inside the loop with a simple prmitive, such as a
sphere, then you will see the many spheres.  Why is the macro not being
called multiple times?
Thanks for your help,
Arie
Subject: Re: macro inside a loop
Date: 19 Oct 2001 02:56:58
Message: <3bcfceba@news.povray.org>
[snip]
is
says
> condition).
Check that your objectRing macro is actually returning the objects you want
in the scene, rather than declaring them as object variables.  Otherwise, it
might help to see the code for that macro as well...
Date: 19 Oct 2001 03:32:40
Message: <B$i7SBABN9z7Ew+p@econym.demon.co.uk>
>place)
> #declare i = 10;
> #while (i < height)
>  objectRing(
>  #declare i = i+1;
> #end
>#end
>condition).
>Arie
Since it works with simple primitives, I'd guess that one of the macros
you call "ballRadius" or "objectRing" is clobbering the value of your
counter variable "i".
The way to fix this is to change your #declares into #locals. This
allows each macro to have its own copy of the variable which then won't
interfere with similarly names variables in the calling macro or in the
top level of the scene file.
When you use "#declare i" you are changing the value of the global
variable called "i". So, if objectRing() uses "i" as its counter, and
counts up to "elements", when control returns out from objectRing() into
sphereTube(), the value of "i" has been changed from 10 to elements. If
elements+1 is greater than height, the while clause of sphereTube() is
satisfied, and the macro terminates.
If this is the case, then you're lucky that height is less than
elements+1, otherwise it could easily have gone into an infinite loop.
Mike Williams
Gentleman of Leisure
Date: 19 Oct 2001 13:04:05
Message: <3bd05d05@news.povray.org>
That was it Mike!  I had not declared them as local.  I didn't know that
directive existed.  Thanks for the help!
Arie
"Mike Williams" <mik### [at] nospamplease> wrote in message
news:B$i7SBABN9z7Ew+p### [at] econymdemoncouk...
topSurface,
> >place)
> > #declare i = 10;
> > #while (i < height)
> >  objectRing(
> >  #declare i = i+1;
> > #end
> >#end
is
says
> >condition).
a
> >Arie
> Mike Williams
