![](/i/fill.gif) |
Hi there,
I have posted an image on the images group, and my quesiton is how can I
make the edges of the shadows softer? Right now, the image is just
compromised of three point lights. Will area lights do the trick? Is
there a simpler solution?
Thanks for your help,
Arie
![](/i/fill.gif) |
![](/i/fill.gif) |
Arie L. Stavchansky <ari### [at] bellatlantic net> wrote:
: I have posted an image on the images group, and my quesiton is how can I
: make the edges of the shadows softer? Right now, the image is just
: compromised of three point lights. Will area lights do the trick?
First you ask a question and then you answer it... ;)
: Is there a simpler solution?
Simpler than using an area light? Are area lights complicated?
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
![](/i/fill.gif) |
