POV-Ray : Newsgroups : povray.advanced-users : Random number generator needed ! Server Time
5 Nov 2026 11:40:17 EST (-0500)
  Random number generator needed ! (Message 1 to 41 of 41)
Subject: Random number generator needed !
Date: 20 Feb 2001 14:59:36
Message: <3a92cca8@news.povray.org>
I need a macro that outputs a random number between 0 and 1 when called. It
should have two integers as input. The reason I can't just use rand() and
seed() is that I need it to always output the same random number when the
same input numbers are used.
I need a macro like this: Rand (Int1, Int2)
I don't know anything about random number generators myself, so some help
would be much appreciated.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
Subject: Re: Random number generator needed !
Date: 20 Feb 2001 15:08:59
Message: <MPG.14fced894ca8ffb1989699@news.povray.org>
hello,
what about:
#macro random(a,b)
	#local S = seed(a+b);
	rand(S)
For what do you need this? A subdivision-surface?
Lutz-Peter
Date: 20 Feb 2001 15:27:45
Message: <3a92d341@news.povray.org>
"Lutz-Peter Hooge" wrote:
> what about:
> #macro random(a,b)
> rand(S)
> #end
Already tried such things, but the sequence is not at all random.
No, my particle system. If you want to know more about the particle system,
have a look at the animations recently posted by me in
povray.binaries.animations.
Rune
Date: 20 Feb 2001 15:29:15
Message: <slrn995ksu.71c.ron.parker@fwi.com>
>> what about:
>> #macro random(a,b)
>> rand(S)
>> #end
It seems what you want is a hash rather than a random number generator.
Whether such a thing is easy or even possible to implement in POV-script
is another question entirely.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 20 Feb 2001 16:17:56
Message: <MPG.14fcfd3048501c4698969a@news.povray.org>
In article <3a92d341@news.povray.org>, run### [at] inamecom says...
That depends, of course, on how much random your input variables are.
if you could somehow feed the output of the macro back to its input
variables for the next call it would probably be much better.
> No, my particle system. If you want to know more about the particle >system,
Ah, nice. But i didn't find a message explaning why you need this ramdom
number generator there.
Lutz-Peter
Date: 20 Feb 2001 16:21:31
Message: <MPG.14fcfe2434a36dc198969b@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
says...
I think an array initialized with random numbers could be used for this.
Of course it will need to be very large, or the numbers will repeat much
more often than in a normal random numer stream.
Lutz-Peter
Date: 20 Feb 2001 16:35:33
Message: <3A92E320.229F7259@gmx.de>
How about using eval_pigment? It would require megapov of course.  It is
not really random, but since you are using integer numbers this should not
be a problem.
Date: 20 Feb 2001 17:30:38
Message: <3a92f00e@news.povray.org>
Well, since rand(seed(X)) is basically a linear function, all the randomness
would have to come 100% from the input. So there's no point in using it
really.
I even tried things like seed(X*1234567*pi), but even then it only repeats a
few numbers over and over again. Guess it's because a linear function of a
linear function is just another linear function...
> input variables for the next call it would probably be much
> better.
But I can't.
> i didn't find a message explaning why you need this ramdom number
> generator [in the particle system].
There are many reasons. For example I want my particle system to be
frame-independent, so that the even the randomness of the particles is the
same independent on the frame-rate used. I also need it for the cyclic
animation feature where the whole calculation process is basically run
through several times, and where the random numbers must be the same each
time.
I have considered the array solution myself, but it would have to be a very
large array, and it would be a clumsy solution. :(
Rune
Date: 20 Feb 2001 17:30:40
Message: <3a92f010@news.povray.org>
That might work, but is there any of the "random" patterns that have
completely equally distributed values?
Rune
Date: 20 Feb 2001 17:30:41
Message: <3a92f011@news.povray.org>
> used for this. Of course it will need to be very large, or
> the numbers will repeat much more often than in a normal
At first I thought the array needed would be too large, but wouldn't it work
to make a relative small array, and then use averages of different numbers
from the array?
If 3 numbers from the array were averaged the amount of different numbers
would be array_length^3 and if 8 numbers were averaged it would be ^8 !
Maybe this is the solution?
Rune
Date: 20 Feb 2001 17:42:37
Message: <3A92F2DD.CCE12EC3@gmx.de>
Not sure what you mean, you should not use noise_pigment, because it does
not give reproducible results, any other 'noisy' pattern should work as
long as the minimum distance between two evaluated points is larger than
the structures in the pattern, otherwise two neighboring points give
similar results.
Date: 20 Feb 2001 22:05:15
Message: <chrishuff-9D830E.22043620022001@news.povray.org>
In article <3a92f00e@news.povray.org>, "Rune" <run### [at] inamecom>
> is the same independent on the frame-rate used. I also need it for
> the cyclic animation feature where the whole calculation process is
> basically run through several times, and where the random numbers
> must be the same each time.
If I understand this correctly, you may want to try separating your
render frames from your calculation frames...do a fixed number of
iterations for a specific time period (for example, always compute 500
iterations by the time clock reaches 1), and you will get the same
result. Of course, it won't work very well if you use more frames than
iterations, but you might be able to work out an interpolation method to
save computation time and get reasonably good results.
Christopher James Huff
Date: 21 Feb 2001 07:44:07
Message: <3a93b817@news.povray.org>
> from the array?
Those wouldn't be equally distributed though.  The mean of three uniformly
distributed numbers is not uniformly distributed.
Geoff
Date: 21 Feb 2001 08:26:16
Message: <3a93c1f8@news.povray.org>
Rune wrote in message <3a92cca8@news.povray.org>...
perhaps this will help you:
#macro Rand(I1,I2)
  rand(seed(val(concat(str(I1,0,0),str(I2,0,0)))))
ABX
Date: 21 Feb 2001 09:11:41
Message: <3a93cc9d@news.povray.org>
Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote:
:   rand(seed(val(concat(str(I1,0,0),str(I2,0,0)))))
  Isn't this effectively the same as:
  rand(seed(I1*I2))
  (Not identically the same result, but effectively the same idea.)
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 21 Feb 2001 09:22:03
Message: <3a93cf0b@news.povray.org>
Warp wrote in message <3a93cc9d@news.povray.org>...
> rand(seed(I1*I2))
multiplication has symetry
concatenation hasn't
ABX
Date: 21 Feb 2001 11:16:52
Message: <3a93e9f3@news.povray.org>
: multiplication has symetry
: concatenation hasn't
  Your solution just multiplies I1 with the smallest multiple of 10 that
is larger or equal to I2 and then adds I2 to the result.
  This is effectively the same as I1*I2+I2, the only difference being that
instead of multiplying with a the smallest multiple of 10 which is larger
or equal to I2, we are multplying with the smallest number which is larger
or equal to I2, which is, of course, I2 itself.
  Now, I1*I2+I2 = (I1+1)*I2, and by all practical means this probably will
not give a too different result than just I1*I2.
  That's why I think that I1*I2 will probably give an equally good result
with less overhead.
Date: 21 Feb 2001 11:46:19
Message: <3a93f0db@news.povray.org>
> #macro Rand(I1,I2)
> #end
Unfortunately not. It's not at all random...
Basically it will never be of any use to use rand( seed( VAL ) ) no matter
what "VAL" is, because it won't add any randomness at all.
Rune
Date: 21 Feb 2001 11:46:20
Message: <3a93f0dc@news.povray.org>
work
numbers
> > from the array?
numbers
> Geoff
Date: 21 Feb 2001 11:46:21
Message: <3a93f0dd$1@news.povray.org>
> > wouldn't it work to make a relative small array, and then
> > use averages of different numbers from the array?
> three uniformly distributed numbers is not uniformly
> distributed.
Yes, I realised that...
Maybe instead of averaging I can just add together and then use mod() on the
result. It may cause a kind of repeats in the pattern, but it should be
possible to reduce it to a minimum.
Rune
Date: 21 Feb 2001 11:46:22
Message: <3a93f0de$1@news.povray.org>
> your render frames from your calculation frames...
I did that a long time ago; that's not the problem.
> do a fixed number of iterations for a specific time period
> (for example, always compute 500 iterations by the time clock
> reaches 1),
Yes.
> and you will get the same result.
Yes, if the random steams are reliant on the calculation frames only and not
the render frames. And my problem is to achieve that.
I tried to use a new random stream for every calculation frame, but that
didn't work, as the Nth random number from the streams M, M+1, M+2, ...
would just change linearly. In other words, random numbers from one stream
are random compared to each other, but different streams are *not* random
compared to each other. (I think it's a common misunderstanding to think
that they are.)
Rune
Date: 21 Feb 2001 12:40:52
Message: <3a93fda4@news.povray.org>
: Basically it will never be of any use to use rand( seed( VAL ) ) no matter
: what "VAL" is, because it won't add any randomness at all.
  What he wanted was that a certain pair of values is converted to some
value (always the same value). Each time the function is called with a
certain pair of values, the same result is returned. This value should
be "random" in the way that there's no (easily) visible connection between
the input values and the result.
  For this rand(seed(VAL)) works quite well. It returns a value from 0 to 1
which is seemingly not related to VAL.
Date: 21 Feb 2001 13:11:43
Message: <3a9404df@news.povray.org>
Warp wrote in message <3a93fda4@news.povray.org>...
but this works fine
I've checked and compared results for independent running and for independent
loops of one running
it is little slow but as I said - it works
// start of file
#declare Generator=seed(0);
#declare RandTable=array[1][3]
#macro Extend(Table,I1,I2,R)
  #local Counter=0;
  #local End=no;
  #while (!End)
    #ifndef (Table[Counter][0])
      #local End=yes;
    #else
      #local Counter=Counter+1;
  #local NewTable=array[Counter+2][3]
  #local NewTable[Counter][0]=I1;
  #local NewTable[Counter][1]=I2;
  #local NewTable[Counter][2]=R;
  #while (Counter>0)
    #local Counter=Counter-1;
    #local NewTable[Counter][0]=Table[Counter][0];
    #local NewTable[Counter][1]=Table[Counter][1];
    #local NewTable[Counter][2]=Table[Counter][2];
  NewTable
#macro RandForRunesParticles(I1,I2)
  #local Counter=0;
  #local Found=no;
  #local End=no;
  #while (!End)
    #ifndef (RandTable[Counter][0])
      #local End=yes;
    #else
      #if ((RandTable[Counter][0]=I1)&(RandTable[Counter][1]=I2))
        #local Found=yes;
        #local End=yes;
  #if (Found)
    #local R=RandTable[Counter-1][2];
  #else
    #local R=rand(Generator);
    #declare RandTable=Extend(RandTable,I1,I2,R)
  R
// end of file
ABX
Date: 21 Feb 2001 13:13:50
Message: <3a94055e@news.povray.org>
Warp wrote in message <3a93e9f3@news.povray.org>...
>with less overhead.
there was big misunderstand in my thinking
I thought that
#declare A=seed(0);
#declare B=seed(0);
cause A=B
but I've checked it's not true
and that's why this not work as expected
ABX
Date: 21 Feb 2001 13:48:01
Message: <3a940d61@news.povray.org>
>> distributed.
How big are your numbers?  You could use the nth value off the stream seeded
with m, if you're assured they're not too big (expensive, though)
Another possibility is using some sort of function to hash to a single
value.  a*n1 + b*n2 which you then use as your seed, and get the random
number that way.
Geoff
Date: 21 Feb 2001 15:20:16
Message: <3a942300@news.povray.org>
"Warp" wrote:
> : no matter what "VAL" is, because it won't add any randomness at all.
>   What he wanted
Who?
> was that a certain pair of values is converted to some value (always
> the same value). Each time the function is called with a certain pair
> of values, the same result is returned. This value should be "random"
> in the way that there's no (easily) visible connection between the
Yes, that's what I wanted.
> 0 to 1 which is seemingly not related to VAL.
Yes if wanted just a single random value - but I need dozens of them!
Not only should the random number have no visible connection to VAL. It
should also have no visible connection to the other random numbers. I didn't
explicitly say that, as I thought it was needless to say.
Rune
Date: 21 Feb 2001 21:28:59
Message: <388.452T547T12023756PeterC@nym.alias.net>
If I read your posting correctly, you need what is
called a "hash function".  Try a web search on "one
way hash".  You will most likely find C code or C++ code
within ten minutes or less of searching.  Most hash functions
seem to operate on integers and use bit shifts so you'de need
to write extra macros to emulate an integer bit shift, since
pov uses floats for numbers.
Pete
Date: 22 Feb 2001 05:35:02
Message: <3a94eb56@news.povray.org>
: Yes if wanted just a single random value - but I need dozens of them!
  Now I don't understand.
  You want a macro so that you give it two values and it returns a random
value corresponding to those input values. That is, if you call MyRand(2,5)
it would return something seemingly not related to 2 and 5, like 0.27642.
Is this correct?
  What I don't understand is how it can return several values. Do you mean
that if you call it again with MyRand(2,5) it should return a different
value? What's the difference with regular rand() then?
: Not only should the random number have no visible connection to VAL. It
: should also have no visible connection to the other random numbers.
  What other random numbers?
Date: 22 Feb 2001 08:03:39
Message: <3a950e2a@news.povray.org>
Ok, so you want a random stream created based on two numbers, but one that
doesn't show obvious connection to the strems based on any other two
numbers.
In other words, you can't just use something like:
#macro MyRand(v1,v2)
  seed(v1*19873+v2)
because while it gives a seed value for each pair, and you've got a stream,
it is a stream which is not random when compared to a stream with two other
inputs?  Ie, you need multiple random streams that are also random with
regards to each other.
Is that correct?
Geoff
Date: 22 Feb 2001 11:45:41
Message: <MPG.14ff60ef8ab352fd98969c@news.povray.org>
In article <3a94eb56@news.povray.org>, war### [at] tagpovrayorg says...
> value?
No, if I understand Rune correctly, he means if you call it several times
with different, but somehow linked to each other, pairs of values, the
resulting "random" values should NOT have a visible link to each other.
example:
#declare R1 = random(1,5);
#declare R2 = random(2,6);
#declare R3 = random(3,7);
#declare R4 = random(4,8);
#declare R5 = random(5,9);
#declare RT = random(1,2);
now the resuling values Rn (n=1...5) should not have a visible link to
each other (although te input values are obviously linked) and RT = R1.
Lutz-Peter
Date: 22 Feb 2001 17:24:07
Message: <3a959187@news.povray.org>
> times with different, but somehow linked to each other, pairs of
> values, the resulting "random" values should NOT have a visible
> link to each other.
Exactly.
Rune
Date: 22 Feb 2001 17:31:27
Message: <3a95933f@news.povray.org>
> but one that doesn't show obvious connection to the strems based
> on any other two numbers.
Actually I need not a random stream but just a random number, i.e.:
I want a random number created based on two input numbers, but one
that doesn't show obvious connection to the random numbers based on
any other two input numbers.
The problem is exactly the same though.
> Is that correct?
Sort of but not quite. I need not streams, just random numbers, but the
problem is to create those random numbers without using streams.
random(2,3)
random(2,4)
random(2,5)
random(2,6)
There should be no connection between those numbers above.
Rune
Date: 23 Feb 2001 07:35:35
Message: <3a965916@news.povray.org>
Lutz-Peter Hooge <lpv### [at] gmxde> wrote:
: No, if I understand Rune correctly, he means if you call it several times
: with different, but somehow linked to each other, pairs of values, the
: resulting "random" values should NOT have a visible link to each other.
  And why rand(seed(I1*I2)) doesn't give the desired result? It looks to me
like it gives values between 0 and 1 quite randomly, not very related to
I1 and I2.
Date: 23 Feb 2001 12:03:14
Message: <3A96976D.C31B21D0@reading.ac.uk>
Hi Warp,
> I1 and I2.
Unfortunately, it doesn't work.
There are a couple of drastic problems in fact:
1) this function is symetric about the diagonals so, for example, the
points (2,3), (3,2), (-2,-3), (-3,-2) all give the same values. The axes
give 0*I2 or I1*0 and so return the same value along their length.
2) seed() itself is based on, I believe, a simple linear congruent
random generator. The first call to these tend to depend highly on the
seed value, being highly correlated for certain sequences.
I ran a test which showed this using
// --** start **--
#declare S = 30;
#declare X = -S; #while (X <= S)
  #declare Y = -S; #while (Y <= S)
    #declare Col = rand(seed(X*Y+3000));
    box { <X,Y,0>-0.5, <X,Y,0>+0.5
      pigment { colour rgb Col }
      finish { ambient 1 diffuse 0 }
  #declare Y = Y + 1; #end
#declare X = X + 1; #end
camera { location -(2*S+10)*z }
// --** end **--
The +3000 term in the seed() is just to keep X*Y positive.
Next I tried a macro:
#declare Col = random(X,Y);
where
#macro random (N1, N2)
  #declare IM = 233280;
  #declare IA = 1861;
  #declare IC = 49297;
  #declare LN = mod(N1 * 117127 + N2 * 121499, IM);
  #declare LN = mod(LN + IM, IM);
  #declare maxC = 8;
  #declare C = 0; #while (C < maxC)
    #declare LN = mod(LN * IA + IC, IM);
  #declare C = C + 1; #end
  #declare N3 = LN;
  (N3/IM)
which is a 'quick and dirty' LCRG with the inputs multiplied by large
(prime?) numbers. This gave results worse than the first attempt! Highly
correlated adjacent values.
So as a last attempt I put
#declare maxC = 40-floor(30*LN/IM);
and *gasp!* it gave a visually random pattern. I have done no stats on
the output, but it looks similar to a pattern created by putting
#declare Col = rand(R);
into the X, Y loops after initializing R with seed() outside the loops.
So, there you have my investigations into random numbers. I'm sorry if
this post seems as random; I've been typing it intermittently at work
over the last four hours or so ... time to post it I guess.
Bye for now,
	Mike Andrews.
// --** active sig alert **--
plane{y,0 pigment{color rgb 1}}camera{location<1,5,-2>look_at 0}
light_source{10 color 1.5}#declare g=sqrt(3);#macro m(a,b,c,n,i)
#if(i=0)cylinder{a,b,c pigment{color rgb vnormalize(<abs(a.x),max
(0,4*(1-abs(a.z))-abs(a.x)),4*abs(a.z)>)}}#else#local f=vlength(a
-b)/32;#local d=(b-a)/8;#local e=vnormalize(vcross(d,n))*f*4;m(a-
e,a+e,f,n,i-1)m(a+d+(1-g)*e,a+2*d+e,f,n,i-1)m(a+6*d+e,a+8*d+e,f,n
,i-1)m(a+e,a+d+(1-g)*e,f,n,i-1)m(a+6*d-e,a+8*d-e,f,n,i-1)m(a+2*d+
e,a+2*d-e,f,n,i-1)m(a+6*d-e,a+6*d+e,f,n,i-1)m(a+3*d-e,a+3*d+e,f,n
,i-1)m(a+4*d-e,a+4*d+e,f,n,i-1)m(a+4*d,a+(4+g)*d+e,f,n,i-1)m(a+6*
d,a+8*d,f,n,i-1)m(a+4*d,a+(4+g)*d-e,f,n,i-1)#end#end
m(-3*x,3*x,1/8,y,3) // Mike Andrews after Jan Walzer
// --** end **--
Date: 23 Feb 2001 14:16:18
Message: <slrn99ddo3.rsv.ron.parker@fwi.com>
>// --** end **--
Not to start this again, but you might want to go find the thread in
off-topic where his sig was discussed.  I posted what I think are some
significant improvements to it (even got it below the McQuary limit!)
Date: 23 Feb 2001 22:43:50
Message: <3a972df6$1@news.povray.org>
In article <3A96976D.C31B21D0@reading.ac.uk> , Michael Andrews
l1*l2+l2
     Thorsten
Date: 26 Feb 2001 04:47:49
Message: <3a9a2645@news.povray.org>
Warp wrote in message <3a965916@news.povray.org>...
> I1 and I2.
rand(seed(I1*I2)) gives random results becouse
seed(I1*I2)<>seed(I1*I2) :-)
just test
#warning concat(str(seed(1),0,0),"\n")
what was output ?
0
1
2
3
ABX
Date: 26 Feb 2001 07:47:54
Message: <slrn99kk3r.t9k.ron.parker@fwi.com>
This is meaningless, as the output of the seed function is not a number.
It's a random number stream.
Date: 26 Feb 2001 08:32:40
Message: <3a9a5af8@news.povray.org>
>> Is that correct?
> random(2,3)
> random(2,4)
> random(2,5)
> random(2,6)
Ok, well, one possibility is using the seed (n1 * x1 + n2 * x2) where x1 and
x2 are large.  This might work, but I'm not certain.
Are the values always that small?  If so, the n2'th value from stream
initialized with n1 would work, but wouldn't work in the case:
random(1,2)
random(2,2)
random(3,2)
ie, it wouldn't be symmetricly random (can you even talk about such
things?).  Dunno if that's an issue, though.
Geoff
Date: 26 Feb 2001 09:24:27
Message: <3a9a671b@news.povray.org>
Ron Parker wrote in message ...
I know
I just answered why proposed usage: rand(seed(I1*I2))
returns different values for the same arguments
ABX
Date: 26 Feb 2001 09:45:02
Message: <slrn99kqvf.tal.ron.parker@fwi.com>
>I know
But it doesn't.  My point was that just printing the result of the seed
function is meaningless, as it is merely an index into an array of RNG
streams.  The only thing that result is good for is for feeding into the
rand function.  You should find, though, that rand(seed(1)) always returns
the same result.
Note that using rand(seed(foo)) to generate hashes gives poor performance,
as POV will track each stream separately.  So, if you call rand(seed(foo))
1000000 times, POV will allocate enough memory to track 1000000 streams.  If
what one wants is a hash, one really should implement a hash.  Of course,
that's not easy, because there are no bitwise operators, but something
like
#macro hash(t1,t2)
  #local p1=log(t1);
  #local p2=cos(t2);
  #local p3=sin(1e6*p2-1e2*int(1e4*p2)+1e6*p1-1e2*int(1e4*p1));
  (1e4*p3-int(1e4*p3))
might work in a pinch, though the distribution may not be entirely uniform.
The principle in operation here, which might not be entirely valid, is that
the less significant digits of transcendental numbers tend to be pretty
random.  There is some correlation, but it should be at a scale far below
the integer arguments we've been talking about.
