POV-Ray : Newsgroups : povray.advanced-users : Average of vectors? Server Time
19 Oct 2026 00:07:06 EDT (-0400)
  Average of vectors? (Message 1 to 12 of 12)
Subject: Average of vectors?
Date: 7 Jan 2001 15:46:31
Message: <3a58d5a7@news.povray.org>
Imagine two vectors, A and B.
C is a regular weighted average of the two vectors, say clock*A +
(1-clock)*B.
With this type of average the vector-point is linearly "interpolated", but
the rotation and length of the vector is not.
To make the length of C linearly interpolated is easy, but how do I linearly
interpolate the "rotation"?
I need a general method that can average not just two, but multiple vectors.
How can I do this?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
Subject: Re: Average of vectors?
Date: 7 Jan 2001 16:26:32
Message: <3a58df08@news.povray.org>
A start:
camera { location <0,2,-6>*.8 look_at 0 angle 35 translate y*.5}
light_source { y*100, 1 }
plane { y,0 pigment { checker rgb 1, rgb .5 } }
#declare A = <-1,1.5,0>;
#declare B = <1,.5,.5>;
cylinder { 0,A,.025 pigment { rgb x } }
cylinder { 0,B,.025 pigment { rgb x } }
#declare An = vnormalize(A);
#declare Bn = vnormalize(B);
#declare Al = vlength(A);
#declare Bl = vlength(B);
#declare Angle = degrees(acos(vdot(An,Bn)));
#declare Perp = vcross(A,B);
#declare Clock=0;
#while(Clock<=1)
  #declare Len = Al*(1-Clock)+Bl*Clock;
  #declare C = vaxis_rotate(An, Perp, Angle*Clock)*Len;
  cylinder { 0,C,.02 pigment { rgb x+y } }
  #declare Clock=Clock+.1;
Date: 7 Jan 2001 16:29:30
Message: <3a58dfb9@news.povray.org>
PS: If you need an explanation about the math used, just ask.
Date: 7 Jan 2001 17:27:07
Message: <3a58ed3b@news.povray.org>
Thanks, I understand it well with two vectors, but I don't quite grasp how
to handle n vectors... It hasn't really anything to do with the clock like
in the example; it was just easier for me to explain what I meant that way.
What I need is a weighted average on n vectors V[N], each with their own
weight W[N].
How can that be done?
Rune
Date: 7 Jan 2001 17:42:41
Message: <3a58f0e1$1@news.povray.org>
> with their own weight W[N].
Well, let me just reveal that what I ultimately want to do is to take an
average of multiple matrixes. Got any ideas?
Rune
Date: 7 Jan 2001 18:12:53
Message: <3a58f7f5@news.povray.org>
Rune <run### [at] inamecom> wrote:
: Thanks, I understand it well with two vectors, but I don't quite grasp how
: to handle n vectors... It hasn't really anything to do with the clock like
: in the example; it was just easier for me to explain what I meant that way.
: What I need is a weighted average on n vectors V[N], each with their own
: weight W[N].
  Perhaps something like this:
#declare C = <0,0,0>;
#declare Clen = 0;
#declare TotalW = 0;
#declare Ind = 0;
#while(Ind<Amount)
  #declare C = C+vnormalize(V[Ind])*W[Ind];
  #declare Clen = Clen+vlength(V[Ind])*W[Ind];
  #declare TotalW = TotalW+W[Ind];
  #declare Ind=Ind+1;
#declare C = vnormalize(C/TotalW)*(Clen/TotalW);
Date: 7 Jan 2001 19:09:50
Message: <3A590430.7C55FB4B@faricy.net>
> (1-clock)*B.
> How can I do this?
Make normalized copies of the two vectors, a and b.
Find the angle, A, between them: 2*asin(vlength(b-a)/2).
The vector you want is (a+b)/2 + tan(-A/2+A*clock)*vlength((a+b)/2)*vnorm(b-a)
Where clock goes from 0 to 1 from vector a to vector b.
Date: 7 Jan 2001 19:10:25
Message: <3A590456.80845E16@faricy.net>
This math is untested BTW.
Date: 8 Jan 2001 05:55:34
Message: <3a599ca5@news.povray.org>
Btw, the code I posted probably doesn't make what you want. Sorry.
Date: 8 Jan 2001 08:00:11
Message: <3A59BA2F.D5B3D8CC@spiritone.com>
I just tackled this problem myself:
given vectors v0, v1 (I assume they are at the origin)
#declare vn = vnormalize(vcross(v0,v1));
#declare v2 =
vaxis_rotate(v0,vn,clock*degrees(acos(vdot(vo,v1)/(vlength(v0)*vlength(v1)))));
v2 is in the right direction, so normalize it and adjust the length normally.
Josh
> (1-clock)*B.
> How can I do this?
> Rune
eng### [at] spiritonecom
Date: 8 Jan 2001 13:27:03
Message: <3a5a0677@news.povray.org>
Thanks anyway!
Maybe it'll be good enough if the vector lengths are linearly interpolated,
but not the rotations, and linearly interpolating the lengths isn't a
problem.
Rune
Date: 8 Jan 2001 19:48:34
Message: <3A5A5F38.B896CE18@online.no>
"The Matrix and Quaternions FAQ" has an answer to this question:
"How do I use quaternions to perform linear interpolation
between matrices?"
http://www.cs.ualberta.ca/~andreas/math/matrfaq_latest.html#Q61
Tor Olav
mailto:tor### [at] hotmailcom
