POV-Ray : Newsgroups : povray.advanced-users : Tetrahedron Macro that uses Prism primative Server Time
18 Oct 2026 16:33:25 EDT (-0400)
  Tetrahedron Macro that uses Prism primative (Message 1 to 24 of 24)
Subject: Tetrahedron Macro that uses Prism primative
Date: 6 Dec 2002 21:15:16
Message: <3DF15AEA.79C10205@hotmail.com>
Since the code is pretty short I thought it would be safe to post here
without starting a flame war.
I was looking at prism objects seriously for the first time yesterday
because this was the first time I thought it would be useful for what I
was trying to make.  I realized that I could make a tetrahedron with
it.  Not that tetrahedrons actually have anything to do with my current
project.  I was just thinking that POV-Ray might handle prisms more
efficiently than plane intersections, because they are finite as opposed
to infinite objects.  It takes 4 points anywhere in space, and creates a
tetrahedron there.  I was only sidetracked by this idea for about 6
hours.  Most of that time was fixing bugs.  Anyone know if this approach
is actually faster than plane intersections?
#include "transforms.inc"
#include "textures.inc"
light_source {<3,4,-5>*100 rgb 2}
camera {location <0,0,-15> look_at 0}
#macro Proj (U,V)  // projection of U onto V
        ((V)*(vdot((U),(V))/vdot((V),(V))))
#macro H2tr(U1,U2,V1,V2) // Here to there rotation... two reference
points for initial and final positions
        #local X1 = vnormalize(U1);                // find basis vectors
of initial and
        #local Z1 = vnormalize(vcross(X1,U2));     // final refrence
frames
        #local Y1 = vcross(Z1,X1);
        #local X2 = vnormalize(V1);
        #local Z2 = vnormalize(vcross(X2,V2));
        #local Y2 = vcross(Z2,X2);
        #local Trans1 = transform{matrix
<X1.x,Y1.x,Z1.x,X1.y,Y1.y,Z1.y,X1.z,Y1.z,Z1.z,0,0,0>}
        #local Trans2 = transform{matrix
<vdot(X2,X1),vdot(X2,Y1),vdot(X2,Z1),vdot(Y2,X1),vdot(Y2,Y1),vdot(Y2,Z1),vdot(Z2,X1),vdot(Z2,Y1),vdot(Z2,Z1),0,0,0>}
        #local Trans3 = transform{Trans1 inverse}
        #local Rotation = transform {Trans1 Trans2 Trans3}
        Rotation
#macro H2t (Oi,Ai,Ri,Of,Af,Rf)                // Here to there
       transform{
       translate (- Oi)               // center, and two reference
points on object
       H2tr((Ai-Oi),(Ri-Oi),(Af-Of),(Rf-Of))  // New center, and
refrence point locations
       translate Of}
#end   // (Origin, Absolute vector, Relative vector) initial, and final
orientations
#macro Tet_prism(Vec1,Vec2,Vec3,Vec4)
        #local Cross = vcross((Vec2)-(Vec1),(Vec3)-(Vec1));// Find
normal to plane three points are on
        #local STP = vdot(Cross,((Vec4)-(Vec1)));// Scalar Triple
Product
        #if (STP = 0) #error "degenerate tetrahedron volume = 0" #end
        #local Normal = ((STP > 0 ? -1 : 1)*vnormalize(Cross));// sign
corrected normal
        #local Basepoint = (Proj(Vec1,Normal));// point on base whose
normal points to Vec4
        #local Height = vlength((Basepoint)-(Vec4));// distance between
point 4, and the plane the other three points are on
        #local Transform = transform{H2t
(Basepoint,Vec4,Vec1,(Height*y),<0,0,0>,((Height*y)+x)) scale
(1/Height)}
        #local V1 = vtransform(Vec1, Transform);
        #local V2 = vtransform(Vec2, Transform);
        #local V3 = vtransform(Vec3, Transform);
        object {
                prism {
                conic_sweep
                linear_spline
                0, // sweep the following shape from here ...
                1, // ... up through here
                4, // the number of points making up the shape ...
                <V1.x,V1.z>,<V2.x,V2.z>,<V3.x,V3.z>,<V1.x,V1.z>
                transform {Transform inverse}
                        }//prism
                }//object
#end//Tet_prism
object{Tet_prism(<1,1,1>,<-1,1,-1>,<1,-1,-1>,<-1,-1,1>) pigment{Green}}
object{Tet_prism(<1,1,1>,<-1,1,-1>,<-1,1,1>,<-1,6,1>) pigment{Orange}}
//object{Tet_prism(<1,0,0>,<0,0,1>,<-1,0,-1>,<0,5,0>)
pigment{Green}finish {ambient 1}}
Dan Johnson
http://www.geocities.com/zapob
Subject: Re: Tetrahedron Macro that uses Prism primative
Date: 7 Dec 2002 02:55:04
Message: <c1a3vu8jeouj4e7rrifrebafdgceko497i@4ax.com>
Hello, Dan.
Great idea and thanks for sharing it!
Now, for your question... you can't really tell whether it will be
faster until you stress-test it. Put several thousands of those in a
scene and compare the render times of each approach. Also, while one
object may be faster, it may still be slower in CSG, so that's also
worth a try.
As of your concerns of starting a flame war, I doubt it :) It's just
that if someone looks for examples of code, macros, scenes etc., one
usually looks into the scene-files groups. In general, the chances of
finding something (not just a post) are greater if it's in the right
place (this from the guy whose view of order is "Throw everything
here, this way the more recent stuff requires less digging." :) )
Anyway, just a thought.
Peter Popov ICQ : 15002700
Date: 7 Dec 2002 03:47:15
Message: <3df1b593@news.povray.org>
  There was once a long thread in some group about the most efficient way
of making a box with all six sides textured differently.
  Several approaches were made and their rendering times measured. For
example it was done with the intersection of six planes, the union of
six 2-dimensional boxes, six polygons and a mesh. (Also using a single
box with a clever pattern was suggested, but that's irrelevant in this case).
  Perhaps a bit surprisingly, with such a low triangle count the mesh was
not the fastest option. I don't remember which one was, but it might have
been the union of polygons. (The problem with it is that it's not usable
in CSG.)
  In your case the intersection of planes might be just ok. You simply have
to manually bound the tetrahedron eg. with a sphere.
  You might also try using a mesh (with inside_vector you can make it
CSG'able). If you don't need to use the tetrahedron in CSG, you might want
to try a union of four triangles, or even polygons, though I doubt it will
be faster than the union of triangles.
  I think that with such a low triangle count, the union of triangles may
be faster than a mesh.
Date: 7 Dec 2002 04:29:51
Message: <3DF1C0C9.2D61A2B8@hotmail.com>
Peter Popov wrote:
> Hello, Dan.
Aww shucks that makes the 6 hours I spent worth it.  Blessed feedback.
> worth a try.
Yeah I figured that would be the way to do it.  I didn't feel like doing
all that testing though.  It sounded like a lot of work.  I thought
perhaps someone might have immediate need for millions of tetrahedrons.
Well no I didn't, but I can dream can't I?  Today I was thinking, and I
believe that it is possible to make any finite polyhedron out of
tetrahedrons.  Maybe even only one per vertex.  It's even easy to split
a tetrahedron into two tetrahedrons.  So I was thinking about making a
polyhedra modeler that treated shapes as unions of tetrahedrons.  Maybe
I will have it working 6 months from now.  Well if I can motivate myself
that well.
My reasoning for putting it here is that tetrahedra are fairly simple
shapes, and I thought it was more of an intellectual thing.  Plus I
hardly ever get any replies when I post in scene-files groups.  I
thought it would get looked at here.
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Dan Johnson
http://www.livejournal.com/userinfo.bml?user=teknotus
Date: 7 Dec 2002 04:42:43
Message: <3DF1C3CD.A9BA456F@hotmail.com>
> in CSG.)
Interesting..
If my thinking is correct that can be done such that each vertex is
exactly on the surface of the sphere.
Of course a union of triangles is so much easier that what I did.  I
used more than one in the process of debugging my code.  CSG is
important for pretty much everything I ever do.
Dan Johnson
Date: 7 Dec 2002 12:18:20
Message: <chrishuff-34E328.12151607122002@netplex.aussie.org>
In article <3df1b593@news.povray.org>, Warp <war### [at] tagpovrayorg>
Did anyone try using "heirarchy off"? With 4 triangles arranged like
that, it has to be more overhead than benefit.
http://tag.povray.org/
Date: 7 Dec 2002 15:30:20
Message: <chrishuff-E9ABBB.15271707122002@netplex.aussie.org>
In article <3DF1C3CD.A9BA456F@hotmail.com>,
You are correct (assuming no uneven scaling or shearing), but I think a
box would be a better choice. A sphere doesn't fit a tetrahedron that
closely, a box isn't much if at all better but is faster to test.
Date: 7 Dec 2002 17:19:19
Message: <3df273e6@news.povray.org>
  Have you actually made the math, which shape "wastes" more space when
bounding (optimally) a regular tetrahedron ("regular" meaning all sides
have the same length), the sphere or the box?
  I wouldn't be so sure that the optimal box is smaller than the optimal
sphere ("smaller" meaning that its volume is smaller), although I can't
be sure of the contrary either.
  Also I think that a ray-sphere intersection is faster than a ray-box
intersection, so the sphere is in that sense a better bounding object.
Date: 7 Dec 2002 20:22:46
Message: <3DF2A029.A55D1FD2@hotmail.com>
In my example one of the tetrahedrons is regular, and exactly fits
inside a 2X2X2 box.  Both exactly fit in a sphere with radius sqrt(3).
finish{Dull}}
box{-1,1 pigment{color rgbft<1,0,0,0,.6>}finish{Dull}}
sphere{0,pow(3,(1/2)) pigment{color rgbft<0,0,1,0,.8>}finish{Dull}}
sphere {<1,1,1>,.1 pigment{Yellow}}
sphere {<-1,1,-1>,.1 pigment{Yellow}}
sphere {<1,-1,-1>,.1 pigment{Yellow}}
sphere {<-1,-1,1>,.1 pigment{Yellow}}
Don't know about using a box to bound an irregular tetrahedron.  Sounds
relatively tricky.
Dan Johnson
Date: 8 Dec 2002 14:50:59
Message: <chrishuff-4B87D1.14475808122002@netplex.aussie.org>
In article <3df273e6@news.povray.org>, Warp <war### [at] tagpovrayorg>
Ok, for a tetrahedron with these corners:
<-1, 1,-1>
< 1, 1, 1>
<-1,-1, 1>
< 1,-1,-1>
(regular tetrahedron, every point equidistant from the other three)
The radius of a perfect bounding sphere is sqrt(3). Volume is pi*3/4*r^3
= 21.763 cubic units. The volume of the perfect axis-aligned bounding
box is 8 cubic units, though it will increase for other orientations (I
think the worst case makes for a bounding box sqrt(8)xsqrt(8)x2, 16
cubic units.
I think the "average visible area" would make a better measurement than
volume, though much harder to compute. And the difference is bigger than
I expected, but I can't find anything wrong with my math, please
re-check it.
Hmm...the bounding box calculation is very well optimized, I think it
only requires 3 intersections with axis-aligned planes and some code for
clipping that. A sphere is fast, but I think a bounding box is faster.
However, I'm not too sure how the bounded_by keyword fits in with the
bounding box heirarchy...it looks like a bounding box is always used,
which bounds the bounding shapes (multiple?), which bound the object.
Much of the bounding code seems to be very per-object...it's pretty
disorganized, and probably not as fast as it could be.
Date: 8 Dec 2002 14:53:39
Message: <chrishuff-CEFA0F.14503708122002@netplex.aussie.org>
In article <3DF2A029.A55D1FD2@hotmail.com>,
> relatively tricky.
Finding an optimal axis-aligned bounding box is very easy, just find the
min and max extents of all four points. A sphere or an aligned bounding
box would be trickier.
Date: 11 Dec 2002 11:45:09
Message: <3df76b95@news.povray.org>
"Dan Johnson" <zap### [at] hotmailcom> wrote in message
news:3DF1C3CD.A9BA456F@hotmail.com...
way
case).
was
have
> > in CSG.)
> Interesting..
have
I bet the Graphics Gems books have code that will allow you to determine a
sphere tangential to 4 points in 3-space.  The code for those books can be
found on-line.
Date: 11 Dec 2002 11:48:43
Message: <3df76c6b$1@news.povray.org>
Actually, I was considering rendering a D&D game with a 17,000,000th level
wizard casting Magic Missile...  ;-)
Date: 11 Dec 2002 20:57:32
Message: <3DF7EBBA.4A556875@hotmail.com>
> have
> found on-line.
I once made a macro for POV that finds such a sphere,
but I'm afraid that a sphere that tuches all the 4
vertexes will not be the optimal solution in all cases.
In fact it will sometimes be a very non-optimal sphere to
choose for bounding of tetrahedrons.
But if anyone is interested in having a look at my macro,
then it can be found here:
http://news.povray.org/povray.general/17701/?mtop=114652&moff=22
news://news.povray.org/3B82F267.36412849%40hotmail.com
Tor Olav
Date: 12 Dec 2002 02:12:49
Message: <6ldgvu8m3haqih3b2cud5narcqn8p82pvi@4ax.com>
On Wed, 11 Dec 2002 11:45:10 -0500, "Rick Gutleber" <ric### [at] hiscom>
>found on-line.
There sure is, but keep in mind that the circumscribed sphere is
usually not the smallest sphere containing four points.
Date: 13 Dec 2002 03:11:18
Message: <3DF9974D.975896FD@hotmail.com>
> Rick
I didn't know that there have been enough hours since the game was
invented for anyone to get to the 17 millionth level.  Must be quite
some D&D player.  Or is this a theoretical character, or a non player
character.  I once encountered a game bug that gave me perfect stats.
Well except for luck.  My luck in the game was so awful that people in
proximity to my character would do things like critically miss, and kill
themselves.  I had an aura of bad luck.  Or was that a different game?
Dan Johnson
Date: 16 Dec 2002 19:10:23
Message: <3dfe6b6f@news.povray.org>
If the points are _tangential_ to the sphere, wouldn't there only be one
solution?
"Peter Popov" <pet### [at] vipbg> wrote in message
news:6ldgvu8m3haqih3b2cud5narcqn8p82pvi@4ax.com...
a
be
> >found on-line.
Date: 16 Dec 2002 20:35:03
Message: <web.3dfe7e1187ba9bcf38149fba0@news.povray.org>
>solution?
Rick,
I don't think one can say about points
that they can be tangential to anything.
You probably mean that they are on the
If you have four points in 3D space that
are not coplanar (*), then yes; there
are only one specific sphere that have
them all on its surface. (And the macro
I mentioned in my other post finds that
very sphere.)
This sphere will, of coarse, enclose a
tetrahedron that has these four points
as its vertices.
But as Peter and I pointed out, this is
not always the most optimal sphere to
choose for bounding of such a tetrahedron.
It will in some cases be possible to
find spheres with smaller radii, that
encloses the tetrahedron.
And in these cases only 2 or 3 of the
4 points (vertices) will be on the surface
of the sphere. The other 2 or 1 will be
inside it.
The problem is now to find the bounding
sphere with the smallest radius.
(*) More precisely I mean:
vdot(p1 - p0, vcross(p2 - p0, p3 - p0)) != 0
Tor Olav
>news:6ldgvu8m3haqih3b2cud5narcqn8p82pvi[at]4ax.com...
>a
>be
>> >found on-line.
Date: 16 Dec 2002 21:16:45
Message: <chrishuff-01A022.21121216122002@netplex.aussie.org>
In article <3dfe6b6f@news.povray.org>, "Rick Gutleber" <ric### [at] hiscom>
> solution?
He said that the circumscribed sphere (with all points on the sphere)
wasn't the smallest sphere *containing* the points. In some cases, the
smallest sphere touches only 2 or 3 points.
For a regular tetrahedron, the smallest sphere does touch all 4 points.
Date: 17 Dec 2002 12:33:49
Message: <3dff5ffd@news.povray.org>
> inside it.
I seem to remember the sequence goes something like this:
Find the two points furthest apart and set a sphere so that they are on
the diameter. If both other points are inside the sphere you are done.
If one or two points are outside the sphere find the point furthest
outside the sphere. Produce the sphere that has the circumcircle of the
three points as its great-circle. If the fourth point is inside this
Otherwise find the sphere with all four points on the surface.
I think this is right ...
Mike Andrews.
Date: 17 Dec 2002 14:49:57
Message: <3DFF8126.37A7E1BE@hotmail.com>
> Mike Andrews.
I think you are right.  I don't think it would be too hard to make a
macro to do that either.  Now I guess the next thing is to find the
smallest oriented bounding box, and see which one is smaller.  If one is
always smaller.
Dan Johnson
Date: 17 Dec 2002 15:10:15
Message: <3DFF85CA.6BBEFADF@hotmail.com>
> always smaller.
Do bounding boxes with sheer work?  If they do I think you can get even
closer.  Then you could define it as a cube, and a matrix.  I think that
in an ideal bounding box all vertices would also be vertices of the
inclosed tetrahedron.
Dan Johnson
Date: 17 Dec 2002 16:07:20
Message: <3dff9208@news.povray.org>
Yes, of course, you're right about my wording.  I see what you are talking
about WRT to the smallest sphere, too.  Nearly coplanar points would produce
an enormous sphere if you only allowed the points to be on the surface of
the sphere.
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:web.3dfe7e1187ba9bcf38149fba0@news.povray.org...
> >solution?
> Rick,
> very sphere.)
> as its vertices.
> inside it.
> Tor Olav
determine
> >a
can
> >be
> >> >found on-line.
Date: 17 Dec 2002 16:31:50
Message: <chrishuff-29F656.16265717122002@netplex.aussie.org>
In article <3DFF8126.37A7E1BE@hotmail.com>,
> always smaller.
I am almost certain the box is always smaller. The optimal sphere
bounding is a circumscribed sphere around a regular tetrahedron. The
optimal box bounding of that tetrahedron would have each corner of the
tetrahedron at a corner of the box, the least optimal (I think) would
have two edges of the tetrahedron against opposing faces of the box,
parallel to different axii (the best case, rotated 45 degrees around one
axis).
For a regular tetrahedron with 1-unit edges, the best bounding sphere
has a radius of sqrt(3)/sqrt(8) (~0.612), the best-case box a
2/sqrt(8)-unit (~0.707) cube, the worst-case box a 1x1x2/sqrt(8)
(1x1x~0.707) box. The sphere has a volume of 0.96 units^3, the cube
0.353 units^3, and the box 0.707 units^3.
For optimal bounding of irregular tetrahedrons, both will be less
efficient, but I think a box will always be better. Even if the
tetrahedron is a thin rod along a diagonal of the box (the worst case),
the sphere will have a larger volume (having a diameter about equal to
the length of the diagonal of the box).
This is for axis-aligned boxes, if you use oriented boxes the bounding
of a regular tetrahedron or some irregular tetrahedrons (those you can
get by applying an affine transformation to a regular tetrahedron) is
always the best case, for other tetrahedrons it still improves.
