POV-Ray : Newsgroups : povray.advanced-users : Using images in density-medias? Server Time
2 Apr 2026 15:30:37 EDT (-0400)
  Using images in density-medias? (Message 11 to 14 of 14)
Subject: Re: Using images in density-medias?
Date: 5 Feb 2002 18:22:31
Message: <3c606937@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote:
: It does create some sort of emission, based on the calculated grayness
: of a colored pixel, but the colors get lost. That's not the behaviour of
: POV-Ray 3.1g, and probably MegaPOV (I don't use MegaPOV).
  When I try to render a scene like that in povray 3.1g, it says:
error: Keyword 'image_map' can only be used in a pigment statement.
  In MegaPov it works, though.
Date: 6 Feb 2002 00:41:30
Message: <3C60C1F2.761C8F7D@gmx.de>
Thats the error I meant. Someone suggested using image_pattern,
and that gives only gray-scale media from the image.
Tim Nikias
Date: 6 Feb 2002 23:45:39
Message: <3c620673$1@news.povray.org>
> I wanted to create an emission-media which actually uses
> an image as base, simulating a glowing image.
color_map your emmision media!
Date: 7 Feb 2002 08:56:39
Message: <chrishuff-10CAED.08583807022002@netplex.aussie.org>
In article <3C602B2E.39A4AA9F@gmx.de>, Tim Nikias <tim### [at] gmxde>
wrote:
> Before, all I did, was use image-map right inside
> the density-statement, but I don't get it to work.
POV 3.5 doesn't support that feature (I wonder when it got added to
MegaPOV?), but you should still be able do it this way...
#declare imgFn = function {pigment {image_map {...}}}
density {average
    density_map {
        [1 function {imgFn(x, y, z).red}
            color_map {[0 rgb 0] [1 red 3]}]
        [1 function {imgFn(x, y, z).green}
            color_map {[0 rgb 0] [1 green 3]}]
        [1 function {imgFn(x, y, z).blue}
            color_map {[0 rgb 0] [1 blue 3]}]
