I've found in the docs that the new trace()-function from POV-Ray3.5
only
checks for an intersection with a declared object.
Now I'm wondering. This, if I want to check for an intersection in a
complex
scene, requires me to declare the entire scene, and thus, also to place
it using
object{}.
So, how much does this affect memory consumption?
And, while we're at it:
If I want to do an algorithm that trace()s a plane and places sphere on
top,
and does so over and over again, but is also supposed to place spheres
ON spheres just placed as well...
Do I have to create an array, in which I save the objects placed, and
call on these
again and again for each new sphere?
So, my main question is:
Is there an easy solution which provides me with a way to use trace() on
a
scene, alter it, and use trace() again after the alterations, without
having to
tamper around with arrays and declarations of objects en mass?
Tim
In article <3C1700A6.28651428@gmx.de> , Tim Nikias <Tim### [at] gmx de>
During parsing you need slightly more memory, but no additional memory will
be needed.
As for you problem, you don't need trace to place spheres on a plane. The
math to know where the plane is in space really isn't that hard...
Thorsten
e-mail: tho### [at] trf de
I wasn't literary speaking about "spheres on planes". Take any object, and
any environment. Use trace to place the object anywhere. Now, when I
want to place the next object, it should also consider the new object I just
placed. And this goes on and on, perhaps inside a loop?
Tim
Tim Nikias schrieb in Nachricht <3C1745B9.66BB82A3@gmx.de>...
>Now, when I
just
I would say: Just union{} the new Object with the old union{}. This way you
can always trace() against the same object. No arrays needed IMO.
Marc-Hendrik
you want something like this ?
#local Base=box{<-1,-1,-1><1,0,1> pigment{granite}}
#local Count=100;
#local Spheres=array[Count];
#local Counter=0;
#local rs=seed(0);
#local R=.1;
#while (Counter<Count)
#local Found=no;
#while (!Found)
#local Start=2*<2*rand(rs)-1,rand(rs),2*rand(rs)-1>;
#local Dir=<2*rand(rs)-1,rand(rs),2*rand(rs)-1>;
#local Dir=vnormalize(Dir-Start);
#local Norm=<0,0,0>;
#local Intersection=trace(Base,Start,Dir,Norm);
#if(vlength(Norm)>0)
#local Center=Intersection+Norm*R;
#if(Center.y>=R)
#local Bad=no;
#local Temp=0;
#while (Temp<Counter)
#if(vlength(Spheres[Temp]-Center)<2*R)
#local Bad=yes;
#local Temp=Temp+1;
#if(!Bad)
#local Found=yes;
#local Spheres[Counter]=Center;
#local Base=union{
object{Base}
sphere{
Center
R
pigment{color rgb .5+.5*<rand(rs)rand(rs)rand(rs)>}
#local Counter=Counter+1;
object{Base no_shadow}
camera{
location <2,2,-3>
up y
look_at <0,.5,0>
light_source{ y*100 color rgb 1}
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
On Wed, 12 Dec 2001 13:29:15 +0100, "Marc-Hendrik Bremer"
> > Now, when I
Without arrays with previous parameters intersection testing is much more
complicated. But probably possible.
ABX
Though I couldn't test your code yet (POV-Ray doesn't do multiple
instances yet, and I've got an I/O thingy running), I had a close look at it.
Somehow, I don't know why, there is this rumour that objects itself
can't be stored in arrays. You can actually do things like:
#declare Objects=array[3]
{sphere{<0,0,0>,1},box{-1,1},cylinder{0,y,1}}
Somehow, most people think you can only store variables in there...
But yes, your code did actually (in some other method, not using objects
themselves) do the job I was talking about. Though that was of no concern,
I just wanted to know, if there is some easier way, some special clue, which
might improve the process.
Seems there is not, but that's fine.
Another thing that was just on my mind:
Using Macros, one could also increase the dimensions of arrays dynamically,
so there is also no need to set an amount beforehand.(Just in case someone was
curious about that).
Tim
> instances yet
POV-Ray does multiple instances, but... with previous beta :-)
of course I know. but it complicates intersection checking.
you considered memory problems and mine seems optimal in this case.
My code is universal. Just replace spheres condition (distance<2R) with own
method based on another set of traces or whatever you want.
I know. My point was to write readable and fast enough code.
ABX
Hmm, do you mean something like this:
http://news.povray.org/povray.binaries.images/20145/?ttop=20670&toff=50 ?
Jonathan.
"W³odzimierz ABX Skiba" <abx### [at] babilon org> wrote in message
news:rpje1uknmu0c8ip0530f6dfje5o8hbv0p8@4ax.com...
[snip]
There was a discussion on p.u.p re trace() and I think also this
section a while ago on the difficulty of testing for <0,0,0>. This is
the first time I've seen this solution and it seems so simple. I can't
believe I missed it when I first tried to figure out an easy answer :(
Alf
"Alf Peake" wrote:
> the difficulty of testing for <0,0,0>. This is the first time
> I've seen this solution and it seems so simple. I can't believe
It's my preferred method too because it's so simple looking, and it even
parses faster than the alternatives even though you wouldn't think so! Some
tests I posted a long time ago (in povray.general I think) showed that.
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Nov 5)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
Faster than vdot(Norm,Norm) (probably, because the latter takes longer to
parse...)
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
On Wed, 12 Dec 2001 13:37:31 +0100, W�odzimierz ABX Skiba <abx### [at] babilon org>
here are visualizations from showed code
http://news.povray.org/kk1f1u0tvda2ul55rclt1or8opfkah6i5j@4ax.com
http://news.povray.org/spkf1ugdk9ffq6q3shrfs0f1sqrgf8v9se@4ax.com
ABX
