POV-Ray : Newsgroups : povray.advanced-users : mesh and media Server Time
18 Oct 2026 21:05:28 EDT (-0400)
  mesh and media (Message 1 to 12 of 12)
Subject: mesh and media
Date: 19 Nov 2001 08:24:15
Message: <3BF907C6.51F7B63C@psu.edu>
Hi folks,
I am having difficulty filling a closed mesh (made in Rhino v1.1,
exported as "pov-mesh") with media of any kind. Am I missing something?
I have checked the docs and there is no mention (that I can find) of
this issue.
thanks,
paul
Subject: Re: mesh and media
Date: 19 Nov 2001 09:02:19
Message: <3bf910ea@news.povray.org>
paul jones <pdj### [at] psuedu> wrote:
: I am having difficulty filling a closed mesh (made in Rhino v1.1,
: exported as "pov-mesh") with media of any kind. Am I missing something?
  Meshes have no inside, which means they have no interior, which means
they can't have media.
Date: 19 Nov 2001 09:25:05
Message: <3BF91607.3CBA1E25@psu.edu>
well, that is no good.... :-(
thanks!
paul
Date: 19 Nov 2001 09:25:37
Message: <3bf91661@news.povray.org>
Almost right - except a quick experiment reveals that media can indeed be
placed inside a closed mesh, provided the hollow keyword is specified for
the mesh object (3.1 and 3.5).
Date: 19 Nov 2001 10:27:27
Message: <3bf924df$1@news.povray.org>
made hollow ?
Jan Walzer <jan### [at] lzernet>
Date: 19 Nov 2001 13:57:18
Message: <3bf9560e@news.povray.org>
Which means that Gilles is a god.
Jonathan.
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3bf910ea@news.povray.org...
Date: 19 Nov 2001 14:18:53
Message: <slrn9vimou.n0g.ron.parker@fwi.com>
This is one of those oft-misunderstood things.  Patch objects do have an
interior, because none of the interior effects (media, IOR, attenuation, etc.)
care about whether a point is inside or outside the object.  I've demonstrated
this before, but just for the heck of it...
#include "textures.inc"
plane {-z,-5
  pigment {Hex_Tiles_Ptrn() color_map {[.1 rgb 1][.1 rgb 0]} rotate 90*x
            scale .5}
  finish {ambient 1}
union {
  bicubic_patch {type 1 u_steps 3 v_steps 3
    <-1,-1,0> <-1,-.5,0> <-1,.5,0> <-1,1,0>
    <-.5,-1,0> <-.5,-.5,.5> <-.5,.5,.5> <-.5,1,0>
    <.5,-1,0> <.5,-.5,.5> <.5,.5,.5> <.5,1,0>
    <1,-1,0> <1,-.5,0> <1,.5,0> <1,1,0>
    <-.5,-1,0> <-.5,-.5,-.5> <-.5,.5,-.5> <-.5,1,0>
    <.5,-1,0> <.5,-.5,-.5> <.5,.5,-.5> <.5,1,0>
  pigment {color rgbt 1}
  interior {ior 1.5}
camera {location -5*z look_at 0}
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 19 Nov 2001 16:41:48
Message: <3bf97c9c$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> a écrit dans le message de news:
Media work very well with meshes, even non closed ones. There's really
nothing special here.
See my (and other people's) subsurface scattering posts in p.b.i. of some
weeks ago. The head is an open mesh. Yep, it looks funky where the mesh is
open but nobody's obliged to look there.
Now repeat after me : "Test first, then answer, Test first, then answer..."
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 19 Nov 2001 17:13:49
Message: <3bf9841d@news.povray.org>
*LoL*
Date: 20 Nov 2001 06:57:02
Message: <3bfa450e@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: This is one of those oft-misunderstood things.
  No-one is perfect. Not even me. :P
Date: 20 Nov 2001 06:58:28
Message: <3bfa4564@news.povray.org>
Gilles Tran <tra### [at] inapginrafr> wrote:
: Media work very well with meshes, even non closed ones. There's really
: nothing special here.
  Thinking about it, I can't think of any reason why media calculations would
need to know whether a certain point is inside of the object or not. So you
are probably right.
Date: 20 Nov 2001 07:56:33
Message: <3bfa5301$1@news.povray.org>
3bfa4564@news.povray.org...
> you are probably right.
In fact at one time in the history of povray meshes weren't anything else
than unions of triangles, which is why I didn't even blink at the idea of
using media with them.
Try :
light_source{-z*50 rgb 1}
mesh{ // or union
    triangle{0,x,x+y}
    triangle{z*0.5,x+z*0.5,x+y+z*0.5}
    hollow
    texture{
        pigment{rgbt <1,0.5,0.5,0.5>}
        finish{ambient 0 diffuse 1}
    interior{
        media{
            emission 5
            density{
                bozo
                scale 0.1
                color_map{
                    [0 rgb 1]
                    [1 rgb 0]
    translate -x*0.5-y*0.5
    rotate y*20
    translate z*2
- Posters
