POV-Ray : Newsgroups : povray.advanced-users : A macro I'm proud of I think (public Beta) Server Time
18 Oct 2026 23:03:12 EDT (-0400)
  A macro I'm proud of I think (public Beta) (Message 1 to 17 of 17)
Subject: A macro I'm proud of I think (public Beta)
Date: 30 Apr 2001 05:14:33
Message: <3AEE7E92.6963DACB@hotmail.com>
A while ago I was working on a big complicated image, and I wanted to
make a precise plane intersection shape far away from the origin.  I
quickly realized that although I knew exact locations, planes are
described around the origin.  It only takes three points to define a
plane, but for use in plane intersections there is an inside and an
outside, so I decided to use a fourth point to decide witch side of the
plane is inside.  I thought I could write a macro to do it in 15
minutes, I was very wrong.  I think it finally works now, but I thought
that a few days ago before I found some huge bugs.  If you find any bugs
or have suggestions, please comment.
//  Four_point_plane support functions
#macro Proj (U,V)  // projection of U onto V
        (V*(vdot(U,V)/vdot(V,V)))
#macro Same_test (Vector1,Vector2) //tests if two vectors are the same
returns boolean
        (vdot((Vector1 = Vector2),<1,1,1>) = 3)
#macro Collinear_test (Vector1,Vector2,Vector3)  //tests if three points
are on the same line
        #local U = (Vector1-Vector2);
        #local V = (Vector1-Vector3);
        (abs(vdot(U,V)/(vlength(U)*vlength(V))) = 1)
#macro On_plane_test (Point_on_plane,Normal,Test_point)     //  Uses a
point on the plane, and normal vector to test if Test_point
        (vlength(Proj (Point_on_plane-Test_point,Normal)) = 0)  // is on
the plane, returns boolean.
#macro Same_direction_test (Vector1,Vector2) // Tests if two vectors
point in same direction.  If either point is the zero vector,
        (2*(vdot(Vector1,Vector2)/(vlength(Vector1)*vlength(Vector2)) =
1)-1) // you will get a divide by zero error.
// Returns positive or negative 1.
#macro Same_side_test (Point_on_plane,Normal,Test_point1,Test_point2)
//  Tests if both test points are on same side of plane.
        #local Vec1 = Proj(Test_point1-Point_on_plane,Normal);
//  If either test point is in the plane you will get a
        #local Vec2 = Proj(Test_point2-Point_on_plane,Normal);
//  divide by zero error.  Returns positive or negative 1.
        Same_direction_test (Vec1,Vec2)
//  End support functions
// Four_point_plane
// In povray everything on one side of the plane is considered inside
the plane object
// Vector1, Vector2, and Vector3 are points on the plane, none of these
points can be the same as any other,
// and they can't be in a strait line.  Inside point is a control point
to determine witch side of the plane
// is considered inside.  Originally all of the error tests were just
going to be warning messages, but
// in testing I found that all of the errors the error trapping codes
are used to find would cause something
// like a divide by zero error before the warning message was
displayed.  I decided then that it would be better
// to give a usefull error, and halt the render process, because the
render would be halted regardless.
#macro Four_point_plane (Vector1,Vector2,Vector3,Inside_point)
        #if (Same_test (Vector1,Vector2))
        #error "Vector1 = Vector2" #end
        #if (Same_test (Vector1,Vector3))
        #error "Vector1 = Vector3" #end
        #if (Same_test (Vector3,Vector2))
        #error "Vector2 = Vector3" #end
        #if (Collinear_test (Vector1,Vector2,Vector3))
        #error "All vectors on same line" #end
        #local Cross =
vnormalize(vcross(Vector1-Vector2,Vector3-Vector2));
        #if (On_plane_test(Vector1,Cross,Inside_point))
        #error "Inside_point is on plane"#end
        #if (On_plane_test(Vector1,Cross,<0,0,0>))
           #local Distance_from_origin = 0;
           #local Normal_vector = -Same_side_test
(Vector1,Cross,Cross,Inside_point)*Cross;
           // If Cross vector points to the same side of the plane that
the inside point is on, inverts Cross to create normal vector.
        #else
           #local Test_n = Same_direction_test
(Cross,Proj(Vector1,Cross));
           #local Test_o = Same_side_test
(Vector1,Cross,<0,0,0>,Inside_point);
           #local Normal_vector = Test_n * Test_o * Cross;
           #local Distance_from_origin = Test_o *
vlength(Proj(Vector1,Normal_vector));
        plane {Normal_vector, Distance_from_origin}
//  Three_point_plane assumes that the origin is in the object.
#macro Three_point_plane (Vector1,Vector2,Vector3)
        Four_point_plane (Vector1,Vector2,Vector3,<0,0,0>) // lazy way
to do things
//  More macros I have been working on //
#macro Array_plane (Array)    // creates a plane from data points stored
in an array
        plane {<Array[1],Array[2],Array[3]>,Array[4]}
#macro Inclusion (Object1,Object2)     // Cuts a hole in an object and
fills it.
        union
{difference{object{Object1}object{Object2}}object{Object2}}
#macro Sign (X)    //Positive or negative 1 depending on the sign of X
        (X/abs(X))
#macro Angle_between_vectors(U,V)
        (degrees (acos(vdot(U,V)/(vlength(U)*vlength(V)))))
#macro Three_Point_Angle (Vector1,Vector2,Vector3)   //measures an angle
defined by three points the middle point is
        Angle_between_vectors((Vector1-Vector2),(Vector3-Vector2))
//the vertex.
Dan Johnson
http://www.geocities.com/zapob
Subject: Re: A macro I'm proud of I think (public Beta)
Date: 30 Apr 2001 08:04:23
Message: <3aed54c7@news.povray.org>
Dan Johnson wrote in message <3AEE7E92.6963DACB@hotmail.com>...
Perhaps much better place for it's tutorial or scene-files groups.
> If you find any bugs or have suggestions, please comment.
I don't know how your macro works but I found that....
> #macro Sign (X) // Positive or negative 1 depending on the sign of X
>        (X/abs(X))
> #end
...could be more precise and still short
#macro Sign(P)
  (P>0?1:P<0?-1:0)
also in megapov there is inclusion of Chris Chuff which builds-in function
sign() to available keywords
ABX
Date: 30 Apr 2001 08:33:20
Message: <chrishuff-61F0EA.07305030042001@news.povray.org>
In article <3aed54c7@news.povray.org>, "Wlodzimierz ABX Skiba"
Actually, it's sgn()...I was too lazy to get it to work properly with
"sign", which is already used elsewhere...and as far as I know, hasn't
been added to MegaPOV for this reason. Since it won't be in POV 3.5, you
might as well use a macro.
Oh, and it's Chris Huff. ;-)
Christopher James Huff
Date: 30 Apr 2001 09:06:45
Message: <3aed6365@news.povray.org>
Chris Huff wrote in message ...
I found in tokenize.c entry
  {SGN_TOKEN, "sgn"}, /*Chris Huff jan 2001*/
then look for SGN_TOKEN in other files and found in express.c
  case SGN_TOKEN: /*Chris Huff "sign() function"*/
then forgot about sgn() and remembered sign()
but now I write:
  #version unofficial megapov 0.7;
  #warning concat(str(sgn(100),0,0),"\n")
and it won't work ???
I try remember ;-)
The reason is that both ("H" and "CH") have identical vocalizations in polish.
ABX
Date: 30 Apr 2001 09:09:09
Message: <3aed63f5$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-61F0EA.07305030042001@news.povray.org...
Chuff being UK slang for a fart ;)
Date: 30 Apr 2001 13:39:22
Message: <3AEEF4DF.27E6A513@hotmail.com>
> but now I write:
> I try remember ;-)
> ABX
Sign was originally part of the four point plane macro, but I found that version
had huge bugs.  When I rewrote it the guts of the program were very different, and
I didn't need it anymore.  If I thought a stupid little program I wrote in 30
seconds to save myself typing elsewhere was going to take all the attention away
from the main point of my post I wouldn't have included it.  Maybe I am being
selfish, sorry, but I still don't know if I should be proud of the program I spent
hours on, because I am not completely confident that it works right.
Dan Johnson
Date: 30 Apr 2001 15:58:35
Message: <chrishuff-325259.14560530042001@news.povray.org>
In article <3aed6365@news.povray.org>, "Wlodzimierz ABX Skiba"
> but now I write:
Because, as I said, it's turned off...you left out the #ifdef
SignPatch...#endif blocks surrounding those lines. The definition of
SignPatch in frame.h is commented out, and a reason given:
/*#define SignPatch*/ /*Chris Huff July 2000 (added to mp jan 2001)*/
/* not truned on because of the conflict with sign in the isosurface.
sng and sign ???? no :) */
Date: 30 Apr 2001 21:36:29
Message: <3AEE1216.3DE4296E@faricy.net>
> #macro Sign(P)
>   (P>0?1:P<0?-1:0)
> #end
Who says the sign of 0 is 0? ;-)
Date: 1 May 2001 21:07:09
Message: <3aef5dbd$1@news.povray.org>
Dan,
I was kind of surprised to see the sign-discussion spawned with no mention
of your macro, too. The macro is very cool, in my opinion. In fact, this
will be a life-saver for me if it you can work out the bugs -- I'm rendering
a house with very strange roof-lines, which in real life were cut
on-the-fly, which makes for very complicated work to reproduce accurately in
POV.
I've been playing with it, and it never seems to generate a plane with a
negative normal. I did this quick test:
Four_point_plane(<0,16,7>,<0,16,45.3>,<19,22,26.15>,<1,-100,26.15>)
I tried y=+/-100 in the fourth vector, and the results are the same in both
cases. The angle and position of the plane looks perfect, but the vector is
always positive (the plane is always solid "pointing down", towards y=0).
This box roughly defines the size of the house I'm rendering so you can see
how this plane cuts it and how the points are positioned relative to most of
the rest of the model:
box{<0,0,7> <66,22,45.3>}
Unless I misunderstand the usage, changing y from 100 to -100 in this case
should flip the plane "up" and "down", correct?
--Jon
"Dan Johnson" <zap### [at] hotmailcom> wrote in message
news:3AEEF4DF.27E6A513@hotmail.com...
function
you
> > but now I write:
> > I try remember ;-)
polish.
> > ABX
version
different, and
30
attention away
being
I spent
> Dan Johnson
Date: 3 May 2001 06:07:18
Message: <3af12dd6$1@news.povray.org>
Anybody want to take a crack at fixing the +/- normal problem?
My vector math skills aren't up to it -- I understand the basics, but
not enough to understand how they work together to make up the
final result. The macro appears to generate a plane in the correct
position and orientation, but the inside_point vector doesn't seem
to work right -- no matter what coordinates I specify, the plane always
ends up with the normal in the same direction.
It's a pretty nice little tool... any takers?
Date: 3 May 2001 20:19:31
Message: <3AF1F567.A679D7E2@hotmail.com>
> to make a precise plane intersection shape far away from the origin.
> I quickly realized that although I knew exact locations, planes are
> a plane, but for use in plane intersections there is an inside and
> an outside, so I decided to use a fourth point to decide witch side
> of the plane is inside.  I thought I could write a macro to do it in
> 15 minutes, I was very wrong.  I think it finally works now, but I
> thought that a few days ago before I found some huge bugs.  If you
I think that the macro below will do the same.
#macro FourPointPlane(p1, p2, p3, pInside)
  #local vA = p2 - p1;
  #local vB = p3 - p1;
  #local vC = pInside - p1;
  #local vN = vcross(vA, vB);
  #local STP = vdot(vN, vC); // Scalar Triple Product of vA, vB and vC
  #if (STP = 0) // Check for coplanar vectors
    #error "\nMacro FourPointPlane: All points lie in the same plane.\n"
  #else
    #local vN = (STP > 0 ? -1 : 1)*vnormalize(vN);
    plane { vN, vdot(p1, vN) }
  #end // if
#end // macro FourPointPlane
- But I haven't tested it much. Sorry.
I also have some suggestions for some of
your support macros if you are interested.
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
http://hjem.sol.no/t-o-k/tokpicts.html
http://www.crosswinds.net/~tok
Date: 4 May 2001 04:58:10
Message: <3AF3C0C5.BCD4AEFE@hotmail.com>
>   #else
>   #end // if
> Best regards,
> Tor Olav
You have the right idea, my beta program seems to be working lets optimize
it.  Your error catching test is simple, and clever.  I checked all the
math, and it should effectively catch all the bugs my functions do.  It
isn't very helpful to anyone using it, as to what specific thing, or things
they did wrong though.  I would like to use it as a condition for running
the other tests so that it only tries to find out what is wrong, after it
has found out that something is wrong.  I don't understand how the sign of
the triple scalar product is used to find out if the normal needs to be
corrected.  The line " plane { vN, vdot(p1, vN) } " is very similar to what
I get when I write out the formula I used and simplified.  An important
difference is that when I simplified I needed an abs around the result of
the vdot.
Having written my own version I have a fairly comprehensive test scene.  I
decided to replace my macro with your macro in the scene, and see what
happens.  Immediately it got a user error directive.  I commented out all
the function calls, but the first, and it still happened.  Now I knew that
the very first function call was getting an error.  I did the math by hand,
and found out that the value of STP should be -4 not 0.  I dug further, and
found out that the value of vN was <0,0,0>.  This shouldn't be, now I am
very confused.  Here is the test scene maybe you can make sense of it.
#include "polyhedra.inc"
#include "finish.inc"
#macro ThreePointPlane(P1,P2,P3)
        FourPointPlane(P1,P2,P2,<0,0,0>)
#declare Cube1 = <1,1,1>; // Cube vertexes
#declare Cube2 = <1,1,-1>;  // from polyhedra.inc
#declare Cube3 = <1,-1,1>;
#declare Cube4 = <1,-1,-1>;
#declare Cube5 = <-1,1,1>;
#declare Cube6 = <-1,1,-1>;
#declare Cube7 = <-1,-1,1>;
#declare Cube8 = <-1,-1,-1>;
intersection {
                ThreePointPlane (Cube5,Cube3,Cube2)
                ThreePointPlane (Cube8,Cube3,Cube2)
                ThreePointPlane (Cube2,Cube5,Cube8)
                ThreePointPlane (Cube8,Cube5,Cube3)
                FourPointPlane (<0,1,1>,<0,0,0>,<0,-1,1>,<-1,0,0>)
                texture {pigment {rgbt <1,0,0,0>}} finish {
                ambient .1
                diffuse 1
                reflection .15
                specular 0
                roughness .6
object{Cube_edges(1,.1) texture { finish {
                ambient .1
                diffuse .4
                reflection .25
                specular .6
                roughness .1
}pigment{Green}}}
//object {FourPointPlane (<2,2,1>,<3,3,1>,<4,7,1>,<0,0,20>) pigment
{CornflowerBlue}}
sphere{Cube1,.2 pigment{Blue}}
light_source {<100,30,-100> rgb 2}
camera {location <6,8,-12> look_at 0 angle 20}
Dan Johnson
Date: 4 May 2001 14:06:35
Message: <3AF2EF5D.1193AEE@hotmail.com>
Your macro below has an error.
> #end
You're not using P3. (P2 is written twice.)
I'm in a hurry right now, so I don't have
time for more testing or to try and explain.
Maybe later ...
But if you're going to do further tests,
then I'm interested in hearing about your
results.
Best regards,
Tor Olav
Date: 4 May 2001 16:30:30
Message: <3AF46305.E4FDE7CA@hotmail.com>
> > #end
Doh!  Such a headache over a typo.  Well now everything works.  I'm sure I will
spend a few hours figuring out why.  Much more enjoyable than figuring out why
something doesn't work.  Then I will obfuscate it.  I am learning more about math
this way than reading the book.  Jon wrote me directly telling me about the
project he is working on that uses my macro.  When he is done maybe he will be
willing to share his code, and we can test this version on it to see if it gets
the same results.  Thanks for pointing out my error, I'm sure it would have taken
me another hour before I spotted it.
> Maybe later ...
> results.
> Best regards,
> Tor Olav
Dan Johnson
Date: 7 May 2001 08:10:09
Message: <3af690a1$1@news.povray.org>
If you're interested in this subject, please see my
follow-up and pics in povray.binaries.images.
news:3AF324DD.D3777CCE@hotmail.com...
> See povray.binarys.images for reply
> Dan
Subject: Beta 2
Date: 7 May 2001 21:16:06
Message: <3AF89A84.AE68E4FF@hotmail.com>
Ok Tor Olav now that I understand the math I am certain your code works perfectly I
simplified it enough to remove 3 local variables.  I then added descriptive error
messages without halting rendering.  There aren't any support functions now.  Unless
someone thinks of a way to make it better this is the final version.
// Four_point_plane  Beta 2  May 7 2001
// Original Idea Dan Johnson
// Code Dan Johnson, and Tor Olav Kristensen
// In povray everything on one side of the plane is considered inside the plane
object
// P1, P2, and P3 are points on the plane, none of these points can be the same as
any other,
// and they can't be in a strait line.  Inside point is a control point to determine
// is considered inside. Tor Olav posted much simpler code to do the same job a few
days after me.
// I believe that I can prove it always works.  The plane generating code is based on
Tor Olav's with a
// few minor simplifications, and the error trapping is mostly mine.
// Dan Johnson
#macro Four_point_plane(P1, P2, P3, I)// P1-3 = points on plane I = inside point
  #local Cross = vcross(P2 - P1, P3 - P1);
  #local STP = vdot(Cross, I - P1); // Scalar Triple Product
  #if (STP = 0) // Check for invalid data
    //determine specific error, or errors.
    #local Errors = "\nFour_point_plane did not create a plane because of the
following bad imput\n"
    #local S1 = (vdot((P1 = P2),<1,1,1>) = 3);  // same checks
    #local S2 = (vdot((P2 = P3),<1,1,1>) = 3);
    #local S3 = (vdot((P3 = P1),<1,1,1>) = 3);
    #if (S1 + S2 + S3 > 0)
     #if (S1) #local Errors = concat (Errors,"Point1 = Point2\n")#end
     #if (S2) #local Errors = concat (Errors,"Point2 = Point3\n")#end
     #if (S3) #local Errors = concat (Errors,"Point3 = Point1\n")#end
    #else
     #if (abs(vdot(vnormalize(P2-P1),vnormalize(P3-P2))) = 1)
      #local Errors = concat (Errors,"All points on same line\n")
     #else
      #local Errors = concat (Errors,"Inside point is on plane\n")
    #warning Errors
    sphere {<0,0,0>,0}  //Whatever called Four_point_plane is expecting an object.
  #else
    #local N = (STP > 0 ? -1 : 1)*vnormalize(Cross);// normal vector
    plane { N, vdot(P1, N) }
  #end // if
#end // macro Four_point_plane
#macro Three_point_plane(P1,P2,P3)
        Four_point_plane(P1,P2,P3,<0,0,0>)
Dan Johnson
Subject: Re: Beta 2
Date: 14 May 2001 20:27:17
Message: <3B0077E8.76846FC@online.no>
Your macro looks much better now. And it also
seems that you have got a better understanding
of vector dot products now ;)
But I still have some more suggestions for you.
=> See my comments below.
Best regards,
Tor Olav
To "check" if any two points are equal you could write:
#local EqualAB = (vlength(PB - PA) = 0);
You may want to try this:
#if (S1 | S2 | S3)
>     #else
You could simply check if the length of the
normal vector is 0. (If the length of your
"Cross" vector is greater than 0, then a
proper normal vector was formed.)
>      #else
>      #end
But what if Point1, Point2 and Point3 are
all on a line, while the "inside point" is
not on the same line ?
>     #end
>     #warning Errors
>   #else
>   #end // if
> #end
Further notes:
If the STP test fails while the normal vector
is found to be "sound" (I.e.: The length of
your "Cross" vector is greater than 0), then
you can deduce from this that the "inside
point" must also lie within the the plane
defined by the 3 points: P1, P2 and P3.
To see this, you may form a vector from the
"inside point" to any one of the other three
points. Now it might be easier to understand
that the only way the dot product between
this vector and the plane's normal vector
can be orthogonal to each other (I.e.: their
dot product equals zero) is if the "inside
point" lies within that plane.
Also note that if you calculate the point-
to-point vectors several times, then this
will probably slow down your macro bitte-
littegranne.
