POV-Ray : Newsgroups : povray.advanced-users : Either pov or Greg fails at simple addition Server Time
11 Apr 2026 19:47:34 EDT (-0400)
  Either pov or Greg fails at simple addition (Message 1 to 4 of 4)
Subject: Either pov or Greg fails at simple addition
Date: 26 Feb 2001 09:16:44
Message: <3A9A63DE.8B60C9E2@my-dejanews.com>
I declare a macro which returns a float bounded by [-2.0,2.0].
I multiply the value of this macro by  0.05 and add it to 0.91.
What is the upper limit of the sum?
The variable of interest below is "brakepct"
//CODE BELOW HELPS YOU UNDERSTAND MY PREDICAMENT
#declare years=0;
#while(years<1)          //
#declare RRR=seed(years+99+0) ;             //note years+99 is base
#macro rdr()
(rand(RRR)-0.5)+(rand(RRR)-0.5)+(rand(RRR)-0.5)+(rand(RRR)-0.5)
#declare wallbraketurns=24.5+18.0*rdr();
#declare wallaccelturns=61.0+30.0*rdr();
#declare carbraketurns= 14.0+8.00*rdr();
#declare caraccelturns= 38.0+18.0*rdr();
#declare steerfactor=   1.20+0.29*rdr();
#declare brakepct=      0.91+0.05*rdr();
#declare accelboost=    0.93+0.41*rdr();
#declare VMAX=          6.60+2.80*rdr();
#declare otherang=      8.00+5.00*rdr();
#debug "\n The value for brakepct is "
#debug str(brakepct,7,4)
#debug "  \n"
#debug "\n brakepct is calculated by 0.91+0.05*rdr()"
// now here's a routine to investigate the upper limit of rdr();
#declare counter=0;
#declare maxrdr=0;
#while(counter<10000)
        #declare n=rdr();
        #if(maxrdr<n)
                #declare maxrdr=n;
#declare counter=counter+1;
#debug "\n 10000 iterations of rdr meanwhile gives a max of  only :"
#debug str(maxrdr,6,4)
#debug "\n   "
#debug "This value approaches 2.0, the expected value."
#declare brakepct2=      0.91+0.05*maxrdr;
#debug "\n \n So the max value of brakepct should be slightly higher
than:"
#debug str(brakepct2,6,4)
#debug "\n   "
#declare years=years+1;
  location <0, -65,-0>
  look_at  <0, 0, 0>
  angle 30
light_source{<10,-200,50>rgb .2}
Subject: Re: Either pov or Greg fails at simple addition
Date: 26 Feb 2001 09:18:33
Message: <3A9A6455.873339CD@my-dejanews.com>
"Greg M. Johnson" wrote:
> #macro rdr()
> #end
If you replace that macro with this one, the world returns to normal.
WHY!?  Is there an error in what povray (note: using mega 0.6) does with
parens???
// replace with this macro
#macro rdr()
//(rand(RRR)-0.5)+(rand(RRR)-0.5)+(rand(RRR)-0.5)+(rand(RRR)-0.5)
rand(RRR)+rand(RRR)+rand(RRR)+rand(RRR)-2
Date: 26 Feb 2001 09:27:27
Message: <slrn99kpuh.tal.ron.parker@fwi.com>
>> #macro rdr()
>> #end
I'll bet it doesn't really.
>parens???
It's not an error, but it might be unexpected if you think macros act like
functions.  This line:
is parsed as
#declare brakepct=0.91+0.05*(rand(RRR)-0.5)+(rand(RRR)-0.5)+(rand(RRR)-0.5)+
(rand(RRR)-0.5);
As you can see, the .05 only applies to the first term of your addition.
Your macro should read
#macro rdr()
((rand(RRR)-0.5)+(rand(RRR)-0.5)+(rand(RRR)-0.5)+(rand(RRR)-0.5))
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 26 Feb 2001 09:34:28
Message: <3A9A6806.9872A34F@my-dejanews.com>
> functions.
              |   OO   |
              \   OO   /
