![](/i/fill.gif) |
I think so, although as I remember Erable does a slightle better job of it (not that
ALG48
does a bad job though)
Dan Johnson wrote:
> Kevin Wampler wrote:
> > > 2. More better symbolic math. They should simply call the people at wolfram
> > > research.
> > Have you tried ALG48 and Erable combined? It's not Mathmatica, but it's pretty
good.
> One of my favorites. Would be on my calc now if I hadn't broken my computer
interface
> cable. I don't remember it simplifying trigonometric expressions, does it?
> Dan Johnson
![](/i/fill.gif) |
![](/i/fill.gif) |
David Fontaine wrote:
> Dan Johnson wrote:
> > HP 48GX
> > 1. I can play Beethoven on the built in speaker
> I hardly see how you can get decent quality music on a calculator. "Beep beep beep
> boooooop, beep beep beep boooooop, beep beep beep boop beep beep beep boop beep beep
beep
> boop" (that was Beethoven's 5th BTW ;).
It depends, since the HP48 has a clock, there are music programs out there that time
music
playback accurately enough that you can program multiple parts of a song into
different
calculators, and so long as you start them playing at the same time, the drift isn't
at all
noticeable, even over reasonably long songs. I once set four HS48s up to play
Contrapunctus I
from Bach's The Art of the Fugue, and it didn't sound too bad.
![](/i/fill.gif) |
