![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
David Fontaine wrote:
> Tor Olav Kristensen wrote:
> > Are there any emulators for it ?
> Might wanna try ti89.acz.org
I couldn't find any emulators for the TI-89 there.
(Only emulators for MC68000)
How does the TI-89 compare to the TI-92 ?
Is the TI-92 TI's top model ?
Best regards,
Tor Olav
mailto:tor### [at] hotmail com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm... ticalc.org might
I believe so. TI-89 is essentially the same, IIRC smaller screen, no
Geometry Package or whatever it's called, and no QWERTY keypad (which is
a good thing in the confines of testing regulations etc).
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
either way, bound to be better than my crappy TI-80
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I believe so.
Well obviously you've never heard about the TI-106! ;)
I have that one and a TI-83...
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > I believe so.
Obviously that is not a TI graphing calculator.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> David Fontaine <dav### [at] faricy net> wrote:
> : It'd take a lot of modification since TIs don't have floating point. You have to
> : use a struct ti_float (bcd) and special functions to do all the math.
> If gcc is ported in the right way, then the compiler would handle all
> that automatically.
> For example, you can perfectly compile povray for a 386/486 with no FPU.
> It will be slower, of course, but it will run.
There has been a c compiler for the hp48 for a long time.
I got my hp48gx as an upgrade to my TI-81 back before the TI-92 existed. I have been
keeping track of new calculators as they come out, waiting, hoping that someone would
come out with something better. So far no one has. Sure there are calculators with
advantages over the hp48gx, but not as a whole package. I would like now to compare
some of the advantages.
HP 48GX
1. I can play Beethoven on the built in speaker
2. I can use the infrared port to shoot messages across the room to a friend, or
control my tv
3. Can display gray scale images like the one I have of Claudia Shiffer
4. Unit conversions. You can tag every number you enter with the unit it was measured
in. Then instantly convert to the desired unit after the calculations are complete.
I bet NASA wouldn't have lost the Mars probe due to incorrect units if they had used
this system. ALL of my classmates in physics class were jealous that I finished in
one quarter the time.
5. Equation library. Forget one of those formulas you need all the time. No
problem, almost everything you would ever need is there, just look it up. Also has
constants.
6. Durability. I knew several people who had to have their TI fixed because they
dropped it on the floor. My calculator is incredibly durable. I was usually at the
bottom of my bag under 30 pounds of books. I demonstrate this by pounding it against
hard surfaces.
7. Easy file transfers. The hp understands .txt files, so it is easy to type notes on
your computer and send them through the wire to your calculator. Easier actually than
trying to type on a TI-92 keyboard. I think the rule about no qwerty keyboards for
tests is stupid. Also you don't need any special software to transfer files. I can
do it with any terminal program I have ever tried.
8. RPN is addictive, and fast. There are many places where the notation hp uses save
so much time. For example you can write a list, and perform the same computation with
every value in the list simultaneously.
9. Works like a computer. File system is very familiar. I knew many people who
actually replaced the OS on their TI's
TI
1. Very fast data transfer. Transferring a one kilobyte file between to hp
calculators will take a minute. Between to TI calculators the rate is over 32
kilobytes a second. Now that's a lot better than my internet connection ( I want
broadband). This shouldn't be too surprising considering that they make modem chips.
2. Speed. The new TI calculators are 10 MHz. My Hp is only 4 Mhz. They will smoke
it any day.
3. Easy to use. They do not use RPN, and many things are only accessible from menus.
For me this is not a positive. It took me half a day to learn to use my calculator,
and it was worth it. It took me longer to learn POV-Ray and it has been worth it.
Things I want in my future calculator.
1. More power. Faster processor more memory.
2. More better symbolic math. They should simply call the people at wolfram
research.
3. Should play mp3's and have a headphone jack.
4. Color display capable of displaying millions of colors.
5. Good games should be in rom, like sonic the hedgehog.
6. Built in Remote program
7. Fast standardized data interface. USB maybe.
8. C compiler
9. POV-Ray
Dan Johnson
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3A6### [at] hotmail com>, Dan Johnson
How far in the future? Using current technology or nonexistant/highly
expensive technology?
Definitely.
Hmm, that would certainly require #1...
Millions? I think 256 will be the most you can hope for for a
while...and personally I would value higher resolution more.
Hmm...semi-flexible OLED color display with thousands of colors...it
could be big, say 6*8 inches, and slide in and out of the side of the
calculator, rolling up inside it to save space. And it would be
unbreakable, though it might wear out from the constant flexing. It
would be cheap to replace, though.
This is a *calculator*! ;-)
There shouldn't be any reason for them not to be available, but many of
the people buying them would consider games a waste of money and ROM
space. And even rewritable rom is too slow...the calculator should use
Microdrives. They have them up to 1GB now, and the disk platter is the
size of a quarter...
You mean a program to use the infrared port as a remote control? Good
idea...
Or FireWire...(IEEE-1394). That should be fast enough. :-)
It should be able to talk to a USB printer, too...that would be a nice
way to get high-resolution color graphics. It should be able to charge
itself while plugged in, too.
> 8. C compiler
Or at least a simplified C variant...
> 9. POV-Ray
Right. :-)
How about:
~100MHz RISC processor
8MB RAM for active stuff and video memory
2 slots for micro-hard drives for storage and virtual memory
modified USB port (the connector and cable would need to be made less
bulky, but the other end could be standard)
slide-out 16-bit color 6*8 inch OLED display with 640*480 resolution,
touch sensitive screen optional.
Decent quality built in microphone and speaker, microphone and headphone
jack.
Mini-touch pad.
Built-in cell phone capability, and internet/e-mail access. (cell phones
are getting too small anyway...I think they are going to have to start
combining these things soon, or you will keep loosing them...)
Software including: remote control emulator, simplified Java virtual
machine, C/C++ compiler, and of course, math and graphing software. Oh,
and *good* handwriting recognition. Optional game packs.
Where do you draw the line between high-end calculator and palm computer?
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> research.
Have you tried ALG48 and Erable combined? It's not Mathmatica, but it's pretty good.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Dan Johnson wrote:
> HP 48GX
I hardly see how you can get decent quality music on a calculator. "Beep beep beep
boooooop, beep beep beep boooooop, beep beep beep boop beep beep beep boop beep beep
beep
boop" (that was Beethoven's 5th BTW ;).
> control my tv
Okay, that's cool.
Built-in? The TIs have plenty of user-created grayscale programs.
measured
I'm not sure what you mean "instantly convert", but TIs have unit conversion. In the
89
it's as simple as typing "48_kg>_lbs".
> constants.
That would be helpful, though on the 89 it's pretty easy to get most of them. eg
"Solve(a*x^2+b*x+c=0,x)" and it'll give you quadratic formula. It has built-in trig
identities.
against
> hard surfaces.
I've dropped my TI-89 a few times. But every time it freaks me out. I don't trust it
to
take that abuse.
on
than
The 89 has a text editor, and it's easy enough to type it on the computer using the
graphlink software. They are stored on the calc as plain ascii, but there's no direct
compatability with .txt I think. Oh well, use graphlink, cut-n-paste from Notepad.
Easy
enough.
save
with
I don't know about the time it takes to type stuff in, but the TI can do operations on
lists very easily.
TI-89 has directories and custom file types. But no sub-directories. You access them
with
a backslash too.
> TI
chips.
Calc to calc, but not graphlink. Unless you build your own. (Theirs is 9600.)
> it any day.
>;) :p mwuhahaha
menus.
The 89 has many many keyboard shortcuts. You can even get any greek letter by pressing
diamond-left parenthese-letter in aplha mode. It has four function keys, alpha, shift
(which works as on a computer, and it has cut-copy-paste features), diamond and 2nd,
and
pressing diamond-EE gives you the diamond keyboard map. As for menus there is a new
system
with menus along the top (like in Windows), with F1-F8 keys to acces them and every
element has a number shortcut, you can customize them too. Compared to the old TIs it
has
a very very nice OS.
Don't we all. :) As for mem, even some of the current calcs use more than the
processor
can address, so they page it. Why don't they make one with like a Pentium I? Too hot?
They'd be cheap and they'd fit.
> research.
"More better"? The 89 has pretty good symbolic math, I don't know what they could add.
For
example:
0^-3 is undef but 0^-2 is inifinity. (think asymptote) Everything is automatically
simplified as far as it can possibly be, and if you have it written a different way
you
can just enter one expression equal to the other and it says true or false. Does
complex
solutions too.
Yes!
I dunno, teachers would get awfully suspicious.
To control your TV and stuff? ha!
TI's calc-to-calc is pretty fast. You can't have a transfer faster than your other
compnents anyway.
> 8. C compiler
> 9. POV-Ray
You could have those easily now if it weren't for the fact they would take all your
mem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > research.
good.
One of my favorites. Would be on my calc now if I hadn't broken my computer interface
cable. I don't remember it simplifying trigonometric expressions, does it?
Dan Johnson
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
