![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Does (mega)POV do like real telephoto lenses do and "shrink" the
distance of far away objects?
Should I just RTFM more?
Francois Labreque | It is by caffeine alone I set my mind in motion, it
flabreque | is by the beans of Java that thoughts acquire speed,
@ | the hands acquire shaking, the shaking becomes a
videotron.ca | warning, it is by caffeine alone I set my mind in
| motion.
- Stolen from Badger's .sig file
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3A1### [at] videotron ca>, Francois Labreque
Look up the "angle" keyword for the camera.
Yep. Specifically, this part of the fine manual:
4.4.1.3 Angle
The angle keyword followed by a float expression specifies the
(horizontal) viewing angle in degrees of the camera used.
...snip...
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
One thing about "angle": with panoramic projection it must be the first keyword
in the camera block, in order to take effect.
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I did. And it does not appear to be giving the desired effect.
I am talking about the fact that when you are taking pictures with a
zoom, the apparent depth of the scene shrinks. i.e. objects directly in
front of you will appear relatively closer to each other than they
really are, such as here:
http://www.americascup.org/gallery/ac/race_04/030100_TNZvsPRA_s/assets/acp20000301mcl4zr70883ph7.jpg
(watch the word wrap)
Where it looks as if the two boats were about to hit each other when in
fact they were probably a few hundred feet apart.
| motion.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Angle" does do just that. Basically, reducing the camera angle reduces the
perspective effect; angle -> infinity approaches orthographic projection.
Remember that reducing the camera angle reduces the FOV (Field of View). So if
you want a particular object to appear the same size as before, you need to
increase the distance between it and the camera.
Margus Ramst
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
After I wrote my last reply, last night, I played around and got
satisfying results.
Thanks anyway.
| motion.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
