Hello,
I hope this qualifies as advanced.
To calculate a CGH (computergenerated hologram) I need to create a
pattern which consists of the sum of several translated onion patterns
squared. How can I accomplish this? Layered textures obviously won't do
the trick.
Using an Isosurface function as the pattern would be perfect. Does that
work, and if so how?
Cheers,
Daniel
Daniel Schwen wrote:
> Hello,
> the trick.
Would the average pattern be the solution...
> Hello,
> the trick.
> Cheers,
> Daniel
Daniel,
one possibility would be to use my POV-Ray patch POVMan, which allows to
use RenderMan Shading Language for defining pigments. With this you can
create onion shader and use it as pigment in POV-Ray scene. I've made
small test with onion pattern, if you're interested, then drop me a note
and I'll post them in my homepage or send by email.
POVMan homepage:
http://www.aetec.ee/fv/vkhomep.nsf/pages/povman2
> Hello,
> the trick.
> Cheers,
> Daniel
I do not understand what exactly you want to du, but in megapov you can use any
isosurface function as a pattern, for example:
pigment { function { ... } }
Christoph Hormann <chr### [at] gmx de>
In article <3A096641.FB1CA85B@schwen.de>, Daniel Schwen
Just put the function in as a pattern, no syntax changes are needed.
#declare Onion = function {cos(sqrt(sqr(x) + sqr(y) + sqr(z)))}
// this is an onion-like pattern, a sine wave emanating from < 0, 0, 0>.
// You could also use a pigment function, but that might render a little
// slower.
Then, in your pigment you want to use the pattern on:
function {
sqr(
Onion(x, y, z)
+ Onion(x-5, y+2, z-3)
+ Onion(x+2, y-4, z+1)
color_map {...}
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
That leaves me with one problem. The functionvalues are taken modulo 1, but
with several interfering waves I might get 'overexposures' on my
'photographic plate' which I don't want to warp back in intensity, but keep
white.
if(pattern>1) pattern=1
if(pattern<0) pattern=0
Would it be hard to implement a keyword like 'no_modulo' for the pigments?
In article <3a09fccd$1@news.povray.org>, "Daniel Schwen"
> 1, but with several interfering waves I might get 'overexposures' on
> my 'photographic plate' which I don't want to warp back in intensity,
> but keep white.
If you just want to limit the pattern to the range of 0 to 1, you can do
that within the function:
max(0, min(1, YourFunction(x,y,z)))
This will clamp the function values to the range [0, 1], and avoid the
repeating effect. I like to declare it as a separate function:
#declare Clamp = function {max(y, min(z, x))}
When you use "Clamp(Value, Min, Max)" in your function after declaring
this, the function will return Value constrained to the range between
Min and Max.
> pigments?
What exactly would it do? Would it clamp the values instead of repeating
the range [0, 1]?
Another thing that might help: just divide your function by a large
enough number that it can't go outside that range. This will "darken"
the areas without constructive interference, though...which might be
what you want.
Oh, and be aware that the "Onion" function I gave will return negative
values...you might want to use "cos(...)*0.5 + 0.5" or "sqr(cos(...))"
instead of just "cos(...)". Again, this might be something you want to
have...otherwise, there won't be any destructive interference.
I would suggest you keep the existing function(with negative values
intact), divide the result of the function by the number of waveforms
used(or the total of their amplitudes), and clamp it to the [0, 1]
range.(it should already be <1 after those steps, but could still go <0)
> Hello,
> the trick.
A real hologram? Then it is not onion patterns regardless of
appearance.
If you want to create a hologram of an image they you have to calculate
the phase interference sum at each point of the image of the rays from
all parts of the image. For an image of 1000 pixels that is 1000 phase
dependent rays per pixel. They can only be calculated correctly for a
single color, monochromatic light.
States require proof of age for tobacco and alcohol
but not for lottery tickets. Ever wonder?
-- The Iron Webmaster, 233
> appearance.
You're right, I just use the onion pattern to determine the phase phi(i) of
point source i, but then add the fields vectorial (plus reference light)
sum(sin(phi(i)))^2+sum(cos(phi(i)))^2
That only works for holograms of discrete point sources (glowing dots). For
that I already need sizes of abt. 8000x8000 pixels to see the pattern.
Right, that would be nice, but again, to get reasonable results the
resolution must be much higher, and for a b times b pixel picture that's a
b^4 order problem. It would thke months to render.
That is true in any case. I'm trying to create a transmissive hologram by
taking a picture of my printed picture on bw film. That shrinks the size
considerably and gives me a nice diffracting high resolution pattern, which
I can aim my HeNe laser at.
> > appearance.
I am lost here. We are singing from the same hymnal. We agree it is a
huge task. We agree POVray can't do it.
Where are we going with this?
Bill Clinton is sterile and Hillary has a daughter.
Put three and three together for the unfaithful bitch.
-- The Iron Webmaster, 11
Hello Matt!
I tried to reply to your e-mail, to keep the thread from growing, but it
bounced.
No offense, but actually we don't quite agree. There are two different
approaches. Mine, to calculate the interference pattern of a handful (say
10) pointsources (read: glowing dots in space :) workes quite well (at least
in terms of rendering time abt. 4h for 8000x8000 (PII 233).
Loco!
btw. did you ever punch in your name at google? That's certainly not you,
right?
Cheers,
Daniel
>right?
Sadly, it is. Followups to off-topic.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
