POV-Ray : Newsgroups : povray.advanced-users : Array irritation. Server Time
5 Nov 2026 14:55:28 EST (-0500)
  Array irritation. (Message 1 to 27 of 27)
Subject: Array irritation.
Date: 17 Oct 2000 12:35:46
Message: <39ec7fe2@news.povray.org>
Hello,
I am attempting to learn the use of Arrrays for positioning of objects.
It works, a little.
I have a [3][10] array. I wish to use all data therein by counting down with
while loops. I wish for the loop to first use all 10 values from 3, then all
ten from 2 and lastly all 10 from 1.
I can't make code to do this. I am now very irritated.
The data in the array is controlled by two while loops that surround all of
this; this part works.
It seems that no computer/programming language of any sort works as I think
it should, I can't do as I wish with arrays, loops or etc.. Everything is
too dependant.
My main problem is creation of data in a loop, storage of this data, and
retrieval for usage outside the loops the data was generated with.
I'm not sure my sourcecode will help any, but I'll post it if needed.
Suggestions?
ian
Subject: Re: Array irritation.
Date: 17 Oct 2000 14:25:20
Message: <39EC99EF.283EA738@reading.ac.uk>
ian mcdonald wrote:
> Hello,
> It works, a little.
> too dependant.
> Suggestions?
> ian
// to declare the array
#declare MyArray = array[3][10] // remember :- indices [0..2][0..9]
// to initialise the array
#declare Index1 = 0; #while (Index1 < 3)
  #declare Index2 = 0; #while (index2 < 10)
    #declare MyAray[Index1][Index2] = Whatever_You_Want_To_Put;
  #declare Index2 = Index2 + 1; #end
#declare Index1 = Index1 + 1; #end
// to read the array as specified
#declare Index1 = 2; #while (Index1 >= 0)
  #declare Index2 = 9; #while (Index2 >= 0)
    #declare My_Retrieved_Value = My_Array[Index1][Index2];
  #declare Index2 = Index2 - 1; #end
#declare Index1 = Index1 - 1; #end
Hope this helps,
	Mike Andrews.
Date: 17 Oct 2000 15:02:30
Message: <39eca246@news.povray.org>
Source code might help (try to simplify it before posting if possible).
It would probably also help with a more precise description of what you want
to do, and what the problem is.
Greetings,
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 9)
/ Also visit http://www.povrayusers.org
Date: 17 Oct 2000 15:36:33
Message: <giapusk6m2qkq24ifm65osleibsse19b70@4ax.com>
On Tue, 17 Oct 2000 12:36:23 -0700, "ian mcdonald" <ian### [at] hotmailcom>
wrote:
>Hello,
>It works, a little.
>too dependant.
>Suggestions?
>ian
#declare A1=array[3][10]
      {"1","s","t"," "," ","A","r","r","a","y"}
      {"2","n","d"," "," ","A","r","r","a","y"}
      {"3","r","d"," "," ","A","r","r","a","y"}
#declare Rowcount = 2;
#declare Colcount = 0;
#while (Rowcount>-1)
  #debug "\n"
   #while (Colcount<10)
      #debug concat(A1[Rowcount][Colcount])
      #declare Colcount=Colcount+1;
   #debug "\n"
   #declare Colcount=0;
  #declare Rowcount = Rowcount-1;
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 17 Oct 2000 17:55:17
Message: <39ECC842.38398C3C@faricy.net>
Why concatenate one string? :)
Date: 18 Oct 2000 05:24:36
Message: <39ed6c54@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote:
: Why concatenate one string? :)
  I have seen this written in C:
double x = (double)(1.0);
  I'm just wondering why this wasn't enough:
double x = 1;
Date: 18 Oct 2000 05:43:21
Message: <39ED7102.9C9BD2E4@hotmail.com>
<chuckle> Who wrote that </chuckle> :)))
As far as I know most compilers convert constants at compile time.
> double x = 1;
Maybe they thought that the compiler would insert instructions to convert an
int to a double at runtime, unlikely though it is?
Bye
Pabs
Date: 18 Oct 2000 06:01:06
Message: <h7tqus8sek4qu6ahfcq371v008q9nmunsd@4ax.com>
You're right David, concatenation is  absolutely redundant, although it does no
harm in this instance.  It's a good example of how bugs arise when you are
re-using code and don't think it through carefully enough :-)
Date: 18 Oct 2000 07:21:52
Message: <39ed87d0@news.povray.org>
Pabs <pab### [at] hotmailcom> wrote:
: Maybe they thought that the compiler would insert instructions to convert an
: int to a double at runtime, unlikely though it is?
  Current compilers can do lots of optimizations. Some of them are even
surprising.
  I was once debugging this kind of code (in C++):
int main()
    int i = 1;
    cout << i << endl;
  It was very strange since the debugger didn't execute the 'int i=1;' line
at all and it didn't even show the value of the variable 'i'.
  I thought that "what the **** is wrong with this?" until I realized that
I had all compile optimizations turned on. I turned them off and then the
debugging worked as expected.
  What happened was that the optimizations made by the compiler had converted
the above code to one equivalent to this:
int main()
    cout << 1 << endl;
  The compiler had completely wiped out the 'i' variable and that's why the
debugging looked so strange :)
  Btw, too many times I see code like this:
a = var>>2;  // equivalent to: a = var/4;
  The idea is that shifting is usually a lot faster than dividing so people
optimize by hand in this way.
  This, however, is nowadays made in vain and makes only the code harder to
read. I'd say that every current C(++) compiler can internally optimize this:
a = var/4;
to this:
a = var>>2;
so it's not necessary to do it by hand.
  Sometimes the optimizations made by a compiler are just marvelous. For
example most implementations of gcc convert this kind of code:
(var << 5)|(var >> 27);
(supposing that 'var' is an unsigned int of size 32 bits)
to this (in assembler):
rol [Variable], 5
(ie. "rotate the value [Variable] to the left 5 positions").
  In C there's no operation to rotate values like in most assemblers so you
have to do it with two shifts and one or.
  It's just incredible how the compiler can figure out that what you are
actually trying to do is a rotation and compiles the rather complex command
into one rotation assembler instruction (instead of two shifts and an or).
Date: 18 Oct 2000 10:27:59
Message: <jqcrus8b4ff8c7fg4st3a97f6lqpnsaagr@4ax.com>
Hi Warp, you recently wrote in povray.advanced-users:
> double x = 1;
Maybe the programmer previous written that line as
DBL x = (DBL) 1.0;
and had DBL defined as float, but didn't want to add the 'f' onto the
1.0.
Then he did a global search and replace and replaced DBL with double?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 18 Oct 2000 11:30:24
Message: <39edc20f@news.povray.org>
Lutz Kretzschmar <lut### [at] stmuccom> wrote:
: Then he did a global search and replace and replaced DBL with double?
  Why would he do that?
Date: 18 Oct 2000 18:52:15
Message: <39EE26FE.15BB84D4@faricy.net>
Hmm, sounds like MS...
Date: 18 Oct 2000 22:34:17
Message: <39EE5D5E.CCAB2069@hotmail.com>
Ever seen the sh*t f**cking code msvc produces with no optimisations for things
like the following?
++i;
the code is something like (I'm not to proficient in assembly so don't tease)
mov eax, i
add eax, 1
mov i, eax
The side effect is what we want since the value returned by the operator is just
discarded
What a waste of clock cycles - even I could tell you that
inc i
or something similar would achieve the desired result
Just because its compiled in debug mode doesn't mean I want the code to be bloated
like a bl**dy f**cking pig.
Grrrrrrrrrrrr!
Death to M$VC & M$ - NOW
Bye
Pabs
Date: 19 Oct 2000 01:28:45
Message: <39ee868d$1@news.povray.org>
In article <39ed87d0@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Ah, so you are learning assembler (variants) now...
> rol [Variable], 5
Just curious, which architecture were you compiling for here?
Yes, and there are many more tricks:
main:
 addi $0, $0, 10
 addi $1, $1, 15
 andi $2, $2, 0
 andi $3, $3, 0
for:
 andi $2, $2, 0
 beq  $0, $2, ret
 srl1 $0, $0
 sll1 $1, $1
 andi $2, $0, 1
 subi $2, $2, 1
 not  $2, $2
 and  $2, $1, $2
 add  $3, $3, $2
 j    for
ret:
 j    ret
Assume j is a unconditional jump, and srl1/sll1 are logical right/left
shifts by one bit.  Further assume all values are unsigned 8 bit ints.  $0
to $3 are registers (MIPS assembly notation), your input is in $0 and $1,
and the result is in $2.
What is this program doing?
   Thorsten
e-mail: tho### [at] trfde
Date: 19 Oct 2000 01:41:23
Message: <39ee8983$1@news.povray.org>
In article <39EE5D5E.CCAB2069@hotmail.com> , Pabs <pab### [at] hotmailcom>
> things like the following?
> ++i;
Maybe it is optimising, but in a different way than you expect. On the one
hand "i" might be needed somewhere else and inc i could only work on
register variables (sorry, I don't know x86 assembler too well).  This doing
either would give the same performance.  Especially if "i" is stored in a
rather complicated place or only used once, or a global variable, or a
million other things.
Or it might well be that the sequence it generates executes faster on modern
processors that translate your code to internal RISC-like instructions (like
P6 and later do).  Why come to this conclusion?
Well, what you see is a load/store (i.e. most RISC processors) way of
handling the problem.  Basically a load/store architecture based processor
will not have complex operations that work on memory and data at the same
time.  Everything first has to be loaded into a register, then it will be
processed and then placed back in memory.  This is usually more efficient
because these processors have much larger register files, 32 or even 64
registers compared to the 8 registers a x86 has.
    Thorsten
Date: 19 Oct 2000 01:49:56
Message: <39ee8b84$1@news.povray.org>
In article <39ee868d$1@news.povray.org> , "Thorsten Froehlich"
Correction: the result is in $3 or cousre.  And btw, you may assume all
registers are inited to 0.
Date: 19 Oct 2000 03:59:13
Message: <39eea9d1@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: Maybe it is optimising, but in a different way than you expect. On the one
: hand "i" might be needed somewhere else and inc i could only work on
: register variables (sorry, I don't know x86 assembler too well).
  The 'inc' instruction works also directly with memory locations
(ie. variables) but is slower than an 'inc' on a register. But of course
loading the variable first on a register, incrementing the register and
then storing the register on the variable is not faster (it's actually slower,
I think).
  And besides, if it's not optimizing (as the original poster said), it
should generate the simplest code, not the fastest.
Date: 19 Oct 2000 04:07:07
Message: <39eeabab@news.povray.org>
: Just curious, which architecture were you compiling for here?
  Sparc.
  The assembler instruction I wrote in my article was fictitious
(pseudo-assembler). It's not Sparc assembler.
: What is this program doing?
  No idea.
  A wild guess: Either a multiplication or a division?
Date: 19 Oct 2000 09:14:22
Message: <slrn8utstf.2pq.ron.parker@fwi.com>
>I think).
It might pipeline better.
If it's not optimizing, it's not checking to see whether the result of
the calculation is used, so it always computes it.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 19 Oct 2000 09:22:29
Message: <39eef594@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: It might pipeline better.
  AFAIK instructions that handle the same register can't be executed in
different pipelines at the same time (at least this in a Pentium).
Date: 19 Oct 2000 09:28:20
Message: <tpttusgkh5soek049ibglpo603576eh6un@4ax.com>
Because he found that float was not precise enough?
- Lutz
Date: 19 Oct 2000 09:57:32
Message: <slrn8utvee.2rv.ron.parker@fwi.com>
That's probably true, but a load-modify-store sequence might be more easily
run in parallel with another such sequence.  Of course, if that's the case,
they would have microcoded inc as such a sequence.  I suspect the real
reason your compiler built it that way is the second reason I gave.
Date: 19 Oct 2000 10:59:44
Message: <39ef0c60$1@news.povray.org>
In article <39eeabab@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
>   Sparc.
OK.  I was asking because I was interested if Sparc supports rotations in
hardware.
>   No idea.
Good guess, it is a multiplication.  It plays around with bit patterns and
overflows to be able to accomplish the result in only 4 registers.
     Thorsten
PS: Division (recursive) could look like this ...
 addi $3, $3, 4
 addi $1, $1, 47
 sw   $1, 0($0)
 sw   $0, 1($3)
 addi $1, $0, 10
 sw   $1, 2($3)
 addi $1, $0, 1
 sw   $1, 3($3)
 jal  $1, sub
 lw   $1, 0($3)
 lw   $2, 1($3)
 lw   $2, 0($2)
wait:
 j wait
sub:
 sw   $1, 4($3)
 lw   $1, 2($3)
 subi $2, $0, 1
 beq  $1, $0, ret
 lw   $2, 1($3)
 lw   $2, 0($2)
 slt  $2, $2, $1
 subi $2, $2, 1
 beq  $2, $0, ret
 lw   $2, 1($3)
 sw   $2, 6($3)
 lw   $2, 2($3)
 sll1 $2, $2
 sw   $2, 7($3)
 lw   $2, 3($3)
 sll1 $2, $2
 sw   $2, 8($3)
 addi $3, $3, 5
 jal  $1, sub
 subi $3, $3, 5
 lw   $2, 5($3)
 sw   $2, 0($3)
 lw   $1, 2($3)
 lw   $2, 1($3)
 lw   $2, 0($2)
 slt  $2, $2, $1
 bne  $2, $0, ret_now
 lw   $2, 1($3)
 lw   $2, 0($2)
 sub  $2, $2, $1
 lw   $1, 1($3)
 sw   $2, 0($1)
 lw   $2, 0($3)
 lw   $1, 3($3)
 or   $2, $2, $1
ret:
 sw  $2, 0($3)
ret_now:
 lw  $1, 4($3)
 jr $1
// calculates x / y
int sub(int *x, int y, int cnt);
int main()
 int x = 47;
 cout << sub(&x, 4, 1) << "\n";
 cout << x << "\n";
 return 0;
 int temp;
 if(y == 0)
  return -1;
 if(*x < y)
  return 0;
 temp = sub(x, y << 1, cnt << 1);
 if(*x >= y)
  *x -= y;
  temp |= cnt;
 return temp;
Date: 19 Oct 2000 15:21:28
Message: <39ef49b8@news.povray.org>
First my apologies to the group for not responding in two days. I have been
working and not much else. I now know what 1,200mg of caffine does to the
human body. : (
I discovered my problem when I read Michael Andrews post, telling me that
the arrray is not as one would expect. I thought having an array of [N][N]
would mean I had an array of that precise size, and not [N-1][N-1].
That was my entire problem. Povray did not like the fact that I was calling
the array with the values it was defined with. My loops went from 3 to 1 and
10 to 1, not 2 to 0 and 9 to 0.
My thanks to the group for your help.
ian
Michael Andrews <M.C### [at] readingacuk> wrote in message
news:39EC99EF.283EA738@reading.ac.uk...
Date: 22 Oct 2000 10:22:17
Message: <39f2f818@news.povray.org>
:>   Why would he do that?
: Because he found that float was not precise enough?
  Wouldn't a
typedef double DBL;
be better and easier to do?
Date: 24 Oct 2000 04:26:42
Message: <p5d9vs0894vnrsndusf589uk7muts9j6rh@4ax.com>
> typedef double DBL;
Yes, it would, I guess. Your guess is as good as mine about why
someone would write the example you quoted in the first place, you
certainly wouldn't find a construct like that in my code <g>......
- Lutz
Date: 24 Oct 2000 04:36:54
Message: <39f54a26@news.povray.org>
For things like this, look at:
http://web2.airmail.net/~sjbaker1/software/horrors.html
