POV-Ray : Newsgroups : povray.advanced-users : 48 bit png output broken Server Time
5 Nov 2026 16:30:59 EST (-0500)
  48 bit png output broken (Message 1 to 14 of 14)
Subject: 48 bit png output broken
Date: 8 Aug 2000 20:46:55
Message: <3990AA10.9DDAE53D@kivisalo.net>
+fn16 produces 24bit png in 3.1g and mega 0.5. Stats says 48bpp. Win95.
K.K.
Subject: Re: 48 bit png output broken
Date: 9 Aug 2000 03:04:23
Message: <39910277$1@news.povray.org>
In article <3990AA10.9DDAE53D@kivisalo.net> , Kari Kivisalo
Hmm, it work just fine for me.
Are you sure you are using a program that supports 16 bit per colour
component PNG images?  I know a few that will read any PNG but convert it to
8 bit per colour component.
You can test if it works by using any scene with 8 and then 16 bit per
colour component and simply compare the file sizes.  Even with compression
the 16 bit per colour component image will be larger.
      Thorsten
Date: 9 Aug 2000 03:37:11
Message: <39910A40.26B16AAC@schunter.etc.tu-bs.de>
>       Thorsten
I use +fn16 for 16 Bit heightfields (hf_gray_16) and it works (at least with
megapov)
Date: 9 Aug 2000 05:38:13
Message: <39912685@news.povray.org>
You should know better and not post binary attachments to a non-binaries
group.
Date: 9 Aug 2000 12:56:47
Message: <39918d4f$1@news.povray.org>
In article <39912556.174ADE9F@kivisalo.net> , Kari Kivisalo
> Photoshop 5.5 says it's 16bit but displays this.
> Looks like high/low bytes are reversed.
That would be a Photoshop problem...
     Thorsten
e-mail: tho### [at] trfde
Date: 9 Aug 2000 15:02:03
Message: <3991A8AF.D654D090@faricy.net>
> group.
Oh? And what do you call the data string in your sig? ;)
Date: 9 Aug 2000 20:00:22
Message: <3991F135.3EADF561@mailbag.com>
Source.  Certainly not a binary, at least not in the technical sense.
Then again, I don't think it's entirely proper to post PPM files to text
groups. ;-)
-Mark Gordon
Date: 9 Aug 2000 21:18:07
Message: <chrishuff-0DB083.20191109082000@news.povray.org>
In article <3991A8AF.D654D090@faricy.net>, David Fontaine
His signature is two lines of somewhat human-readable text, in the
message and not as an attachment, written in a programming language (C),
and generated by a human. The image was a ~50KB JPEG image file
attachment. There is a big difference.
Messages with file attachments(including attachments of text files) go
in one of the binary groups, only post text messages to text groups.
Date: 10 Aug 2000 09:13:03
Message: <3992AA72.8BEC1CEF@kivisalo.net>
Is there _any_ app that can open pov 48bit output and save as uncompressed
tif or raw? I guess there isn't raw output option for advanced users because
advanced users just patch it in if they need it :). I'm not going to patch yet.
K.K.
Date: 10 Aug 2000 12:47:24
Message: <qpm5pso2ccfa3pnid549j6q9flihh7bjur@4ax.com>
On Thu, 10 Aug 2000 16:13:22 +0300, Kari Kivisalo <kar### [at] kivisalonet>
I think ImageMagick and/or the GIMP can do it. Both are for Unix but
there are Windows ports and I think there are ports to other popular
OSs.
Peter Popov ICQ : 15002700
Date: 10 Aug 2000 13:58:32
Message: <3992ED5C.AA910340@kivisalo.net>
The Gimp port can read 48bit but exports as 24bit.
ImageMagick converts to inverted byte order 24 bit tif
and really messes up 48 bit tif, psd and raw export.
K.K.
Date: 11 Aug 2000 03:49:19
Message: <ohb7ps8kg6tmmugnte5k5se5jpr622a3nm@4ax.com>
On Thu, 10 Aug 2000 20:58:52 +0300, Kari Kivisalo <kar### [at] kivisalonet>
OK, I'll try PhotoPaint and ZSoft PaintBrush to see what they can do.
Date: 13 Aug 2000 11:15:50
Message: <3996BBBD.7B783AE5@kivisalo.net>
Image Alchemy and pngtopnm can't convert to 48bit
and the official ptot png2tif stops on assert failure.
I need Star Trek universal phase translator converter to
open this file.
K.K.
Date: 19 Aug 2000 18:25:58
Message: <slrn8ptqbc.bpb.hjp-usenet@teal.h.hjp.at>
>groups. ;-)
You don't?
---8<------8<------8<------8<------8<------8<------8<------8<---
P3
15 5 1
1 0 0 1 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0
0 1
1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0
0 1
1 0 0 1 0 0 1 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0
0 1
1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 0
0 0
1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0
0 0
SCNR,
	hp
   _  | Peter J. Holzer    | Nicht an Tueren mangelt es,
|_|_) | Sysadmin WSR       | sondern an der Einrichtung (aka Content).
| |   | hjp### [at] wsracat      |    -- Ale### [at] univieacat
__/   | http://www.hjp.at/ |       zum Thema Portale in at.linux
