POV-Ray : Newsgroups : povray.advanced-users : For the math minded people Server Time
5 Nov 2026 16:33:47 EST (-0500)
  For the math minded people (Message 1 to 16 of 16)
Subject: For the math minded people
Date: 10 Jul 2000 13:56:43
Message: <396A0D89.699D3985@club-internet.fr>
Hi you all.
To make a smooth animation, I'd like to measure the distance between two
points ( ie : distance between <2,3,4> and <7,-8,3>)
Does anyone know the formulae to calculate it?
Thanks
Fabien Hénon
Subject: Re: For the math minded people
Date: 10 Jul 2000 14:05:50
Message: <396a107e@news.povray.org>
of course:
distance(<x,y,z> to <x1,y1,z1>) =
   __________________________
  /            2                  2                   2
\/ (x - x1)   +  (y  - y1)  +    (z  -  z1)
Fabien Hénon <ffj### [at] club-internetfr> wrote in message
news:396A0D89.699D3985@club-internet.fr...
> Hi you all.
> Thanks
> Fabien Hénon
Date: 10 Jul 2000 14:06:34
Message: <slrn8mk4vs.pm2.ron.parker@linux.parkerr.fwi.com>
On Mon, 10 Jul 2000 19:53:13 +0200, Fabien Hénon wrote:
>Hi you all.
The simple way, in POV script, is vlength(A-B) where A and B are the vectors
you want the distance between.  The formula actually used is
sqrt( (A.x-B.x)*(A.x-B.x)+(A.y-B.y)*(A.y-B.y)+(A.z-B.z)*(A.z-B.z))
which is from the Pythagorean Theorem in three dimensions.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 10 Jul 2000 14:07:58
Message: <396a10fe@news.povray.org>
The scalar distance between two points can be found by:
sqrt( (x2 - x1)^2 + (y2 - y1)^2 + (z2 - z1)^2 )
where <x1, y1, z1> is your first point, and <x2, y2, z2> is your second
point.
So, in your example:
sqrt( (7 - 2)^2 + (-8 - 3)^2 + (3 - 4)^2 )
= sqrt( 5^2 + (-5)^2 + (-1)^2 )
= sqrt( 25 + 25 + 1)
= sqrt(51)
= 7.14 (approximately)
- How
> Hi you all.
> Thanks
> Fabien Hénon
Date: 10 Jul 2000 14:55:14
Message: <396A1A62.15B3629C@faricy.net>
Oded wrote:
> of course:
>   /            2                  2                   2
Gee, that looks nice in the variable-length font, but maybe you should've
aligned to the fixed-width font... :)
Date: 10 Jul 2000 16:56:26
Message: <396A3622.FD698EE@global2000.net>
Does the formula give the "hypotenuse" of a shape that looks like a doorstop or
is it a different shape?
Brendan
> >Hi you all.
Date: 10 Jul 2000 17:09:38
Message: <396a3b92@news.povray.org>
Come on, it's povray. There's the easy way:
vlength(<2,3,4>-<7-8,3>)
Date: 10 Jul 2000 17:12:34
Message: <slrn8mkfsm.po3.ron.parker@linux.parkerr.fwi.com>
It gives the length of the diagonal of the largest rectangular face on a
solid that looks like a doorstop (assuming you mean a wedge-shaped doorstop.)
That happens to also be the straight line that connects the two points.
Date: 10 Jul 2000 17:14:04
Message: <slrn8mkfvh.po3.ron.parker@linux.parkerr.fwi.com>
#macro DistanceBetweenPoints( A, B )
  vlength(<0,0,0>+A-B)
Date: 10 Jul 2000 18:30:39
Message: <chrishuff-4F7800.17305910072000@news.povray.org>
In article <396### [at] global2000net>, Andrea Ryan
> doorstop or is it a different shape?
It really just gives the hypotenuse of a 3D triangle...I sometimes think
of it as the line between the front-left-bottom corner and the
back-right-top corner of an axis-aligned box.
Date: 10 Jul 2000 18:42:21
Message: <396A5184.7D17EE41@spiritone.com>
Why add the <0,0,0>? It doesn't contribute anything.
Josh
> #end
eng### [at] spiritonecom
Date: 10 Jul 2000 19:26:37
Message: <396a5bad@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: Why add the <0,0,0>? It doesn't contribute anything.
  It converts the parameter to a vector. The parameter may be a single number.
Date: 10 Jul 2000 21:36:35
Message: <slrn8mkvbs.pr2.ron.parker@linux.parkerr.fwi.com>
Come to think of it, it's not necessary.  If either parameter is a vector, the
expression will be promoted at the addition stage, and if both are floats, it
will be promoted prior to taking the length.  So it really doesn't contribute
anything.
Date: 10 Jul 2000 23:07:18
Message: <396A8D10.543C1553@global2000.net>
Yes, that's the shape that I was thinking of.  Thanks.
Brendan
Date: 11 Jul 2000 16:50:45
Message: <396B880D.1D41BDF7@club-internet.fr>
Thanks for all your answers.
I'll use this one on Excel.
Cheers.
HF
> point.
> = sqrt(51)
> - How
> > Hi you all.
> > Thanks
> > Fabien Hénon
Date: 7 Aug 2000 15:43:01
Message: <398f1145@news.povray.org>
Sir,
You will find the answer to your question in the POV docs under "Float
functions' - vlength and then 'Vector Functions'.  It is then
straightforward to move a camera between the endpoints while looking_at
another point.
Yours sincerely,
Don Barron
"Fabien Hénon" <ffj### [at] club-internetfr> wrote in message
> Hi you all.
> Thanks
> Fabien Hénon
