Hi you all.
To make a smooth animation, I'd like to measure the distance between two
points ( ie : distance between <2,3,4> and <7,-8,3>)
Does anyone know the formulae to calculate it?
Thanks
Fabien Hénon
of course:
distance(<x,y,z> to <x1,y1,z1>) =
__________________________
/ 2 2 2
\/ (x - x1) + (y - y1) + (z - z1)
Fabien Hénon <ffj### [at] club-internet fr> wrote in message
news:396A0D89.699D3985@club-internet.fr...
> Hi you all.
> Thanks
> Fabien Hénon
On Mon, 10 Jul 2000 19:53:13 +0200, Fabien Hénon wrote:
>Hi you all.
The simple way, in POV script, is vlength(A-B) where A and B are the vectors
you want the distance between. The formula actually used is
sqrt( (A.x-B.x)*(A.x-B.x)+(A.y-B.y)*(A.y-B.y)+(A.z-B.z)*(A.z-B.z))
which is from the Pythagorean Theorem in three dimensions.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
The scalar distance between two points can be found by:
sqrt( (x2 - x1)^2 + (y2 - y1)^2 + (z2 - z1)^2 )
where <x1, y1, z1> is your first point, and <x2, y2, z2> is your second
point.
So, in your example:
sqrt( (7 - 2)^2 + (-8 - 3)^2 + (3 - 4)^2 )
= sqrt( 5^2 + (-5)^2 + (-1)^2 )
= sqrt( 25 + 25 + 1)
= sqrt(51)
= 7.14 (approximately)
- How
> Hi you all.
> Thanks
> Fabien Hénon
Oded wrote:
> of course:
> / 2 2 2
Gee, that looks nice in the variable-length font, but maybe you should've
aligned to the fixed-width font... :)
David Fontaine <dav### [at] faricy net> ICQ 55354965
Does the formula give the "hypotenuse" of a shape that looks like a doorstop or
is it a different shape?
Brendan
> >Hi you all.
Come on, it's povray. There's the easy way:
vlength(<2,3,4>-<7-8,3>)
It gives the length of the diagonal of the largest rectangular face on a
solid that looks like a doorstop (assuming you mean a wedge-shaped doorstop.)
That happens to also be the straight line that connects the two points.
#macro DistanceBetweenPoints( A, B )
vlength(<0,0,0>+A-B)
In article <396### [at] global2000 net>, Andrea Ryan
> doorstop or is it a different shape?
It really just gives the hypotenuse of a 3D triangle...I sometimes think
of it as the line between the front-left-bottom corner and the
back-right-top corner of an axis-aligned box.
Christopher James Huff - Personal e-mail: chr### [at] mac com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
Why add the <0,0,0>? It doesn't contribute anything.
Josh
> #end
eng### [at] spiritone com
Josh English <eng### [at] spiritone com> wrote:
: Why add the <0,0,0>? It doesn't contribute anything.
It converts the parameter to a vector. The parameter may be a single number.
Come to think of it, it's not necessary. If either parameter is a vector, the
expression will be promoted at the addition stage, and if both are floats, it
will be promoted prior to taking the length. So it really doesn't contribute
anything.
Yes, that's the shape that I was thinking of. Thanks.
Brendan
Thanks for all your answers.
I'll use this one on Excel.
Cheers.
HF
> point.
> = sqrt(51)
> - How
> > Hi you all.
> > Thanks
> > Fabien Hénon
Sir,
You will find the answer to your question in the POV docs under "Float
functions' - vlength and then 'Vector Functions'. It is then
straightforward to move a camera between the endpoints while looking_at
another point.
Yours sincerely,
Don Barron
"Fabien Hénon" <ffj### [at] club-internet fr> wrote in message
> Hi you all.
> Thanks
> Fabien Hénon
