POV-Ray : Newsgroups : povray.advanced-users : For the math minded people Server Time
25 Mar 2026 12:53:42 EDT (-0400)
  For the math minded people (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: For the math minded people
Date: 10 Jul 2000 17:09:38
Message: <396a3b92@news.povray.org>
Come on, it's povray. There's the easy way:
vlength(<2,3,4>-<7-8,3>)
Date: 10 Jul 2000 17:12:34
Message: <slrn8mkfsm.po3.ron.parker@linux.parkerr.fwi.com>
On Mon, 10 Jul 2000 16:46:26 -0400, Andrea Ryan wrote:
>Does the formula give the "hypotenuse" of a shape that looks like a doorstop or
>is it a different shape?
It gives the length of the diagonal of the largest rectangular face on a
solid that looks like a doorstop (assuming you mean a wedge-shaped doorstop.)
That happens to also be the straight line that connects the two points.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 10 Jul 2000 17:14:04
Message: <slrn8mkfvh.po3.ron.parker@linux.parkerr.fwi.com>
#macro DistanceBetweenPoints( A, B )
  vlength(<0,0,0>+A-B)
Date: 10 Jul 2000 18:30:39
Message: <chrishuff-4F7800.17305910072000@news.povray.org>
In article <396### [at] global2000net>, Andrea Ryan
> doorstop or is it a different shape?
It really just gives the hypotenuse of a 3D triangle...I sometimes think
of it as the line between the front-left-bottom corner and the
back-right-top corner of an axis-aligned box.
Date: 10 Jul 2000 18:42:21
Message: <396A5184.7D17EE41@spiritone.com>
Why add the <0,0,0>? It doesn't contribute anything.
Josh
> #end
eng### [at] spiritonecom
Date: 10 Jul 2000 19:26:37
Message: <396a5bad@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: Why add the <0,0,0>? It doesn't contribute anything.
  It converts the parameter to a vector. The parameter may be a single number.
Date: 10 Jul 2000 21:36:35
Message: <slrn8mkvbs.pr2.ron.parker@linux.parkerr.fwi.com>
Come to think of it, it's not necessary.  If either parameter is a vector, the
expression will be promoted at the addition stage, and if both are floats, it
will be promoted prior to taking the length.  So it really doesn't contribute
anything.
Date: 10 Jul 2000 23:07:18
Message: <396A8D10.543C1553@global2000.net>
Yes, that's the shape that I was thinking of.  Thanks.
Brendan
Date: 11 Jul 2000 16:50:45
Message: <396B880D.1D41BDF7@club-internet.fr>
Thanks for all your answers.
I'll use this one on Excel.
Cheers.
HF
> The scalar distance between two points can be found by:
> sqrt( (x2 - x1)^2 + (y2 - y1)^2 + (z2 - z1)^2 )
> where <x1, y1, z1> is your first point, and <x2, y2, z2> is your second
> point.
> So, in your example:
> sqrt( (7 - 2)^2 + (-8 - 3)^2 + (3 - 4)^2 )
> = sqrt( 5^2 + (-5)^2 + (-1)^2 )
> = sqrt( 25 + 25 + 1)
> = sqrt(51)
> = 7.14 (approximately)
> - How
> news:396A0D89.699D3985@club-internet.fr...
> > Hi you all.
> > To make a smooth animation, I'd like to measure the distance between two
> > points ( ie : distance between <2,3,4> and <7,-8,3>)
> > Does anyone know the formulae to calculate it?
> > Thanks
Date: 7 Aug 2000 15:43:01
Message: <398f1145@news.povray.org>
Sir,
You will find the answer to your question in the POV docs under "Float
functions' - vlength and then 'Vector Functions'.  It is then
straightforward to move a camera between the endpoints while looking_at
another point.
Yours sincerely,
Don Barron
> Hi you all.
> Thanks
