POV-Ray : Newsgroups : povray.advanced-users : A question about blobs Server Time
5 Nov 2026 16:28:29 EST (-0500)
  A question about blobs (Message 1 to 17 of 17)
Subject: A question about blobs
Date: 1 Jul 2000 23:01:23
Message: <395EAFC2.B8626649@attglobal.net>
Please refer to the message entitled "car ad" in p.b.i.
I've been playing around with blobs to model a car and I am having a
little problem with making them coincide properly.  The nose of the car
is a succession of smaller cylindrical blob objects and no amount of
playing with the radius or strength of the individual oblects will do
away with the "Michelin man" appearance.  If you look at the reflection
of the mountain, you'll see what I mean.
Any ideas?  More blobs?  Bigger radii?  Stronger values?
Howard?
Francois Labreque | Rimmer: "Let's go to red alert!"
     flabreq      | Kryten: "Are you sure, Sir?  You realize it
        @         |          actually means changing the bulb!"
  attglobal.net
Subject: Re: A question about blobs
Date: 1 Jul 2000 23:25:08
Message: <395eb614@news.povray.org>
"Francois Labreque" <fla### [at] attglobalnet> wrote in message
news:395EAFC2.B8626649@attglobal.net...
More blobs.  Didn't want to hear that I bet.  I've never seen perfectly linked
components when I try to make something out of a blob object.  It's something
to do with the math at the intersecting areas I guess.
You can try to increase strength and/or lower the threshold, but it isn't
likely you'll get absolutely smooth connection points with a mere half dozen
components, in my opinion anyway.
Date: 2 Jul 2000 00:17:10
Message: <j4gtls43ss3s8gga9neqp13aodnm9v6opd@4ax.com>
On Sat, 01 Jul 2000 22:58:10 -0400, Francois Labreque
Less blobs, larger radius, smaller strength, greater threshold. That's
how I solved the problem when it arose yesterday during the creation
of the twisted torus thingy. Basically, the lower the threshold and
the greater the strength, the less likely are the components to 'blob'
together and the more liable they are to jagging. Vice versa, when
they are of smaller strength (therefore requiring a larger radius to
compensate for that) and the threshold is higher, more components'
contributions are needed to overcome the threshold, causing them to
blob together.
I hope I made this clear enough, it's a little past 7 am and I am not
used to getting up so early so please forgive any oddities.
Peter Popov ICQ : 15002700
Date: 2 Jul 2000 11:17:17
Message: <395F5C3A.4854328E@attglobal.net>
> More blobs.
No.  But I was expecting it.
Francois Labreque |   //\\    Wear an ASCII ribbon!
     flabreq      |  ||  ||
        @         |   \\//    Support the campain
  attglobal.net        \\     against HTML e-mail!
Date: 2 Jul 2000 11:21:51
Message: <395F5D4B.319AABFB@attglobal.net>
> blob together.
Makes sense.  I'll give it a try.
That's alright.  I, too, was up at the crack of dawn (so to speak!).
Jacques Villeneuve finally has a racecar!  Yay!
> Personal e-mail : pet### [at] usanet
> TAG      e-mail : pet### [at] tagpovrayorg
     flabreq      |  ||  ||
Date: 2 Jul 2000 13:18:07
Message: <395f794f@news.povray.org>
It varies so much from instance to instance it is difficult to keep track of
how blob components interact.  As Peter was suggesting using larger radius,
smaller strength, and larger threshold can smooth them out it also takes close
proximity too or else you still get the "interaction zone crease".  So you
would need more components I believe, not fewer.
Date: 3 Jul 2000 15:23:10
Message: <3960e81e@news.povray.org>
> to keep track of how blob components interact.  As Peter was
> suggesting using larger radius, smaller strength, and larger
Isn't lowering the strength of all components basically the same as
increasing the threshold? I think multiplying the strengths of all the
components with 2 give the same result as dividing the threshold with 2. Is
that correct?
Greetings,
Rune
Updated June 12: http://rsj.mobilixnet.dk
3D images, include files, stereograms, tutorials,
The POV Desktop Theme, The POV-Ray Logo Contest,
music, 350+ raytracing jokes, and much more!
Date: 3 Jul 2000 16:05:57
Message: <3960f225@news.povray.org>
"Rune" <run### [at] inamecom> wrote in message
news:3960e81e@news.povray.org...
| that correct?
You are probably correct about that.  As long as the threshold and strength
remain in sync the blob is the same at any(?) value.  A 'threshold' at
one-forth of a control value is the same as 'strength' at 4 times the control
value when threshold is set back again and vice versa.
Date: 3 Jul 2000 17:35:10
Message: <chrishuff-45C4BA.16352003072000@news.povray.org>
In article <3960e81e@news.povray.org>, "Rune" <run### [at] inamecom>
> Is that correct?
Not quite. The falloff curve is kind of S-shaped, it isn't linear, so
the way the components blob together and the distance of the surface
from their centers will change.
Date: 4 Jul 2000 05:06:56
Message: <39619EA4.1568A9B8@yahoo.com>
there's a great beginner tutorial out there.  i think it is by jeff
lee.  one of the things he shows is how blobs of different radii can
have the same appearant radius, but still interact quite differently.  i
believe this is the exact thing this thread has been talking about.
> > Is that correct?
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Date: 4 Jul 2000 10:49:22
Message: <3961f972@news.povray.org>
> > Is that correct?
The shape of the falloff curve is irrelevant.
As long as 2 function remains the same *relative to each other*
the intersection points remains the same. The code below proves it.
The first row shows blobs where both the threshold and the strengths
increase with the same amount from left to right. The blob remain the same.
The second row shows blobs with increasing threshold, and the third row
shows blobs with decreasing strength. You can see that the two rows look
exactly the same.
light_source {<1,2,-3>*10, color 1}
#default {pigment {color rgb 1}}
#declare X = 1;
#declare Y = 7;
#while (X<Y)
   blob {
      threshold 1*X
      sphere {x, 1.5, 2*X rotate 000*z}
      sphere {x, 1.5, 2*X rotate 120*z}
      sphere {x, 1.5, 2*X rotate 240*z}
      scale 0.2
      translate <(X/Y)*6-3,+1.5,5>
   blob {
      threshold 1*X
      sphere {x, 1.5, 8 rotate 000*z}
      sphere {x, 1.5, 8 rotate 120*z}
      sphere {x, 1.5, 8 rotate 240*z}
      scale 0.2
      translate <(X/Y)*6-3,0,5>
   blob {
      threshold 1
      sphere {x, 1.5, 8/X rotate 000*z}
      sphere {x, 1.5, 8/X rotate 120*z}
      sphere {x, 1.5, 8/X rotate 240*z}
      scale 0.2
      translate <(X/Y)*6-3,-1.5,5>
   #declare X = X+1;
Greetings,
Rune
Date: 4 Jul 2000 12:04:51
Message: <chrishuff-086B15.11050104072000@news.povray.org>
In article <3961f972@news.povray.org>, "Rune" <run### [at] inamecom>
You are right, I was thinking of changing radius, not strength. If you
render these three blobs you will see what I meant.
blob {
    sphere {< 0, 0.5, 0>, 0.75, strength 1}
    sphere {< 0,-0.5, 0>, 0.75, strength 1}
    threshold 0.25
        pigment {color Red}
    translate <-2, 1, 0>
blob {
    sphere {< 0, 0.5, 0>, 1, strength 1}
    sphere {< 0,-0.5, 0>, 1, strength 1}
    threshold 0.5
        pigment {color Red}
    translate < 0, 1, 0>
blob {
    sphere {< 0, 0.5, 0>, 1.5, strength 1}
    sphere {< 0,-0.5, 0>, 1.5, strength 1}
    threshold 0.75
        pigment {color Red}
    translate < 2, 1, 0>
Date: 4 Jul 2000 12:31:39
Message: <3962116b@news.povray.org>
Yes, radius and strength are two very different things! :-)
BTW, where can I find an example scene that uses your blob pattern?
I can't get it to work.
Greetings,
Rune
Date: 4 Jul 2000 14:43:47
Message: <chrishuff-C2257F.13435804072000@news.povray.org>
In article <3962116b@news.povray.org>, "Rune" <run### [at] inamecom>
There are some included with the other sample scenes: bloblattice.pov and
blobpattern.pov. Also, I forgot to allow the "strength" token, so don't
use "strength". The strength value just immediately follows the radius.
This will be fixed in the next release of MegaPOVPlus.
Date: 4 Jul 2000 17:05:45
Message: <396251a9@news.povray.org>
"Chris Huff" wrote:
> > pattern? I can't get it to work.
> Also, I forgot to allow the "strength" token, so don't use
Um, then it is useless for the my purpose.
I try to keep the programs I use down to a minimum, so I only use official
POV-Ray and MegaPov. I don't even know if there's a Windows version of
MegaPOVPlus yet?
Greetings,
Rune
Date: 4 Jul 2000 18:02:07
Message: <chrishuff-E0F19D.17021804072000@news.povray.org>
In article <396251a9@news.povray.org>, "Rune" <run### [at] inamecom>
How does that make it useless? It is just a syntax issue...a keyword
which is optional in the blob object isn't accepted at all in the blob
pattern.
> MegaPOVPlus yet?
There is one available on my web site, but it is an older one. I haven't
released the next version, including the blob pattern fixes, yet.
Date: 4 Jul 2000 20:03:14
Message: <39627b42@news.povray.org>
> a keyword which is optional in the blob object isn't accepted
> at all in the blob pattern.
Sorry, I misunderstood you. I never used the strength keyword anyway.
It'll probably do fine then, if just I could get it to work.
> > I don't even know if there's a Windows version of MegaPOVPlus yet?
But the blob pattern is also included in regular MegaPov, and I found the
files you mentioned, so my problem is solved for now. :-)
Greetings,
Rune
