POV-Ray : Newsgroups : povray.advanced-users : Trace, Normal: a problem Server Time
12 Apr 2026 01:05:50 EDT (-0400)
  Trace, Normal: a problem (Message 1 to 9 of 9)
Subject: Trace, Normal: a problem
Date: 28 Jun 2000 12:45:29
Message: <395A2C86.6EDCD317@aol.com>
Hello. I have a problem regarding the MegaPOV feature, 'trace' and
surface normals detected by it. I want to rotate objects according to
the surface normal, to get boxes or other objects to stick out
perpendicular from slanted surfaces. Here is what I tried, using
information for the surface normal from trace:
rotate < Norm.z*90, 0, Norm.x*90 >
In my code the rays are shot straight down onto an object. Boxes are
placed onto the surface of the object and rotated to near accuracy,
but.... The problem is that they aren't rotated precisely! Sure, on the
more horizontal parts boxes are straight up and down, and sure, on the
vertical parts of the object the boxes are placed horizonally...but all
the ones in between down remain perpendicular to the objects' surface! I
don't get it. Is it a bug with the MegaPOV code? Is it a bug wth my own
code?
Thanks in advance. I'll post code and an image describing the problem
later, if anyone who is willing to help needs to know exactly what it
looks like.
~Sam
Subject: Re: Trace, Normal: a problem
Date: 28 Jun 2000 13:40:14
Message: <chrishuff-84140E.12401628062000@news.povray.org>
That code is wrong. The normal values aren't angles, the normal is an
ordinary vector. The usual way of doing it is to use a matrix transform,
try using one of the ReOrient macros drifting around.
Date: 28 Jun 2000 14:26:13
Message: <395A4421.D24D010F@aol.com>
I thought the matrix transform was only good for skewing things.... Do you
use the normal vector somehow in the matrix transform? What does the
reorient macro do (and where can I find it)?
Thanks,
~Sam
Date: 28 Jun 2000 15:02:47
Message: <chrishuff-F4429A.14025028062000@news.povray.org>
http://users.erols.com/vansickl/macs.htm
And while you are at it, you might want to check out his matrix tutorial:
http://users.erols.com/vansickl/matrix.htm
Date: 28 Jun 2000 15:23:36
Message: <395A5196.91FC06A@aol.com>
Thanks! That matrix tutorial is even better than having he macro alone. FYI, I
need the macro for some ground cover experiments, probably resulting in another
memory-intensive macro :)
~Sam
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Date: 29 Jun 2000 01:50:13
Message: <395ae395@news.povray.org>
SamuelT wrote in message <395### [at] aolcom>...
FYI, I
another
You might want to look at the "vegetate" include file for reference:
http://www.geocities.com/rengaw03/povray.html
Mark
Date: 29 Jun 2000 05:57:37
Message: <395b1d91@news.povray.org>
SamuelT <STB### [at] aolcom> wrote:
: I thought the matrix transform was only good for skewing things....
  Matrix can do EVERYTHING! :)
  "Unfortunately no-one can be told what the matrix is... You have to see
it for yourself." - Morpheus, The Matrix.
Date: 29 Jun 2000 09:51:21
Message: <395B545B.A3DFD8B5@schunter.etc.tu-bs.de>
Only *linear* transformations!
"Don't try to bend the spoon, that's impossible, try to realize the obvious..."
Date: 29 Jun 2000 19:59:07
Message: <395be2cb@news.povray.org>
"Do you think that's air you're breathing...?"
