![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Fabian BRAU <Fab### [at] umh ac be> wrote:
: Because one mesh of an object or 1000 mesh (copies) of the
: same mesh use almost the same amount of memory.
With that small mesh, not really. There has to be a way to say "a copy
of this mesh is located here". This 'handle' with information about the
copy may take even more memory than that mesh with two triangles.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for the clarification.
Fabian.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> Have you tested if there's any difference in render time between putting
> all those 1000 rectangles into a union or separately in the scene?
> Povray may be able to make some bounding box optimizations with unions,
> but I may remember wrong.
The rectangles are already structured in unions.
I tested different arrangements concerning this point (larger/smaller
blocks of rectangles) and there was only small difference in memory use,
but time was the same (+/- 1 sec)
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I made a more specific test with a scene containing 11620 rectangles
(and only those rectangles :-).
These are the results:
mesh
Peak memory used: 20078124 bytes
Time For Parse: 0 hours 0 minutes 3.0 seconds (3 seconds)
Time For Trace: 0 hours 1 minutes 13.0 seconds (73 seconds)
Total Time: 0 hours 1 minutes 16.0 seconds (76 seconds)
triangle union
Peak memory used: 20313423 bytes
Time For Parse: 0 hours 0 minutes 4.0 seconds (4 seconds)
Time For Trace: 0 hours 1 minutes 35.0 seconds (95 seconds)
Total Time: 0 hours 1 minutes 39.0 seconds (99 seconds)
polygon
Peak memory used: 20260648 bytes
Time For Trace: 0 hours 1 minutes 9.0 seconds (69 seconds)
Total Time: 0 hours 1 minutes 12.0 seconds (72 seconds)
box 0 height
Peak memory used: 20450420 bytes
Time For Parse: 0 hours 0 minutes 2.0 seconds (2 seconds)
Time For Trace: 0 hours 1 minutes 7.0 seconds (67 seconds)
Total Time: 0 hours 1 minutes 9.0 seconds (69 seconds)
clipped plane
Peak memory used: 22095452 bytes
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ahhh! The zero-height box wins :) I'll be using those for my clouds now
~Sam
Christoph Hormann wrote:
> polygon
> box 0 height
> clipped plane
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
