POV-Ray : Newsgroups : povray.advanced-users : vlength( ) Server Time
5 Nov 2026 16:27:41 EST (-0500)
  vlength( ) (Message 1 to 18 of 18)
Subject: vlength( )
Date: 9 Jun 2000 00:20:00
Message: <3940710D.6EAE55D@aol.com>
Does anybody know how vlength converts vectors to floats? I've use it,
but I'm interested in knowing what the output is. Does it average the
vector numbers to create one float? Thanks in advance.
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Subject: Re: vlength( )
Date: 9 Jun 2000 00:38:09
Message: <394074b1@news.povray.org>
I think you'll find it uses something more Pythagorean than a simple
average: the formula for the length of a vector (as shown in the POV-Ray
docs) is the square root of the sum of the squares of each of the vector's
components, ie:
   sqrt (vdot(V, V))
which equals:
   sqrt (V.x*V.x + V.y*V.y + V.z*V.z)
in the case, obviously, of a three dimensional vector.
Date: 9 Jun 2000 00:46:16
Message: <39407698@news.povray.org>
A vector is really a direction and a length (scalar), vlength just returns
the length.
In POV however, a vector is represented as a point in space by XYZ
coordinates, the direction and length aren't very obvious (to most). The
direction is considered the direction from the origin (0,0,0) to the vector
point, and the length of the vector is the length from the origin to vector
point. I think vlength(x,y,z) is just sqrt(x*x+y*y+z*z).
If I'm wrong someone please correct me.
Date: 9 Jun 2000 00:47:59
Message: <394076ff@news.povray.org>
wow are you 15 minutes in the future?
Date: 9 Jun 2000 01:05:37
Message: <39407BC0.6E1D4081@aol.com>
So, is there a way to get a perfect average from a vector number? I'm
experimenting with eval_pigment and it has become necessary to convert vectors
to floats.
> components, ie:
>    sqrt (vdot(V, V))
> which equals:
Samuel Benge
Date: 9 Jun 2000 01:26:51
Message: <39408048.98CDDC1B@hotmail.com>
try
$ vec = <1.1, 1.0, 0.9> //initialize the vector
$ av = (vec.x+vec.y+vec.z)/3.0 // get the average
#debug concat(str(av,0,5),"\n") //output the average - 0.90000 - 5 decimal places
 or use .red, .green & .blue instead of .x, .y & .z but .x, .y & .z work as well
you could also create a macro
#macro average(vec)
 ((vec.x+vec.y+vec.z)/3.0)
or did you want something else
Pabs
Date: 9 Jun 2000 03:45:43
Message: <3940a0a7$1@news.povray.org>
SamuelT skrev i meldingen <39407BC0.6E1D4081@aol.com>...
vectors
>to floats.
Well, mathematically speaking, there is no such thing as "an average from a
vector number," But if you want the average of the components, just add and
divide, like this:
#macro average1(foo)
((foo.x+foo.y+foo.z)/3)
If you want the average from, say n vectors, do this:
#macro average2(array_of_vectors, num) // assume first entry is at index 0.
#local sum=<0, 0, 0>;
#local c=0;
#while (c<num)
#local sum = sum + array_of_vectors[i];
#local c=c+1;
(sum/num)
I think it should work at first try ... This macro creates a vector whose
components are the average of the respective components of the vectors in
question.
As, the others here pointed out, vlength() returns the length of a vector.
Another way to think of a vector is a point in space with xyz-coordinates as
the components in the vector. vlength() then returns the distance from <0,
0, 0> to <x, y, z>, in other words the lengt of the straight line joining
those two points. Thus, vlength could be regarded as some kind of "average"
of the components; if one are willing to use the word a bit freely...
Simen.
Date: 9 Jun 2000 16:56:59
Message: <39415ABB.3AF4F3F6@aol.com>
Thanks guys. I'll try the simple macro for averaging the 3 components of
the vector. I seem to be getting accurate results from using one vector
inside of vlength. I'll run a test to see if it's really accurate or
not.
Samuel Benge
Date: 10 Jun 2000 15:42:40
Message: <39429a30@news.povray.org>
What are you trying to do?
  The average of the components of a vector doesn't sound like anything
rational. The length of a vector sound much more useful.
Date: 12 Jun 2000 18:37:00
Message: <394566DD.DAC31764@aol.com>
It's for the eval_pigment stuff I've been using. I needed to convert a color
vector into a float value so I could use it for elevation. The best way I
could think of doing this would be averaging the components of the color
vector. I'm now using a macro instead of vlength, and it works great.
Date: 12 Jun 2000 19:31:22
Message: <slrn8katie.7pu.ron.parker@linux.parkerr.fwi.com>
Use the NTSC conversion for rgb to luminance.  You should see some examples
of it in the POV source.  Two of them might even match. :)
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 12 Jun 2000 23:01:49
Message: <3945A4C5.517F61D8@aol.com>
What pov source? The actual code which makes POV-Ray?
Samuel Benge
Date: 13 Jun 2000 09:08:12
Message: <3946323c@news.povray.org>
: It's for the eval_pigment stuff I've been using. I needed to convert a color
: vector into a float value so I could use it for elevation.
  So in practice what you are trying to do is to convert a color to b/w
(ie. a brightness value).
  There's an exact formula on how each color component affects the brightness,
and I don't remember exactly the values, but this might be a good
approximation:
brightness = red*0.25 + green*0.6 + blue*0.15
Date: 13 Jun 2000 09:27:48
Message: <slrn8kcej1.8e5.ron.parker@linux.parkerr.fwi.com>
Yes.  For example, in png_pov.c you'll see:
color = (png_byte)floor((line_data[col][RED]*0.30 +
                         line_data[col][GREEN]*0.59 +
                         line_data[col][BLUE]*0.11) * 255.0);
Date: 13 Jun 2000 12:36:08
Message: <394663CA.15F8EBC7@aol.com>
Ron posted this from the POV source at 6:30:
Perhaps I can use your idea+his values to make it work?
> approximation:
Date: 13 Jun 2000 13:14:09
Message: <39466CB5.8A7BD9A9@aol.com>
Well, this simple macro seems to be working. It is a combination of your idea and
Ron's pasted code.
#macro Lum( Color )
 Color.x*.3
 +Color.y*.59
 +Color.z*.11
Funny thing, Photoshop's desaturation seems to be goofy. It gives unexpected
results, although the desaturation tool itself seems to be fine.
> approximation:
Date: 14 Jun 2000 04:28:49
Message: <39474241@news.povray.org>
: color = (png_byte)floor((line_data[col][RED]*0.30 +
:                          line_data[col][GREEN]*0.59 +
:                          line_data[col][BLUE]*0.11) * 255.0);
: Perhaps I can use your idea+his values to make it work?
  It's not my idea. It's a commonly known equation.
  Using those values it would be:
brightness = red*0.3 + green*0.59 + blue*0.11
Date: 16 Jun 2000 16:21:35
Message: <394A8C26.9378A1C8@online.no>
I see that Ron Parker and Warp already have suggested some conversion
formulas for your problem.
Here are links to some more info about such formulas:
http://www.neuro.sfc.keio.ac.jp/~aly/polygon/info/color-space-faq.html
(Look at the end of item 5.2 - HSL, HSV)
(Rewritten html version of above page ?)
http://members.xoom.fr/scorpion/docs/txt/color_faq.html
(9.2 - Color look-up table to a gray scales)
http://www.inforamp.net/~poynton/notes/colour_and_gamma/ColorFAQ.html#RTFToC9
Tor Olav
mailto:tor### [at] hotmailcom
