POV-Ray : Newsgroups : povray.advanced-users : Math question Server Time
30 Jul 2026 09:34:55 EDT (-0400)
  Math question (Message 1 to 7 of 7)
Subject: Math question
Date: 9 May 2000 23:34:51
Message: <3918D8BA.79E41F33@hotmail.com>
Say I have a ray represented by a ray origin & a unit length direction
vector and
a point some-where along the ray - how do I find the distance along the
ray in the direction of the ray's direction vector from the origin  - ie
in the below diagram the distance found would be negative
ray --------------|------------------------------------->
         ^       ray
         |      origin
      point on   dist = 0
        ray
      dist = -1
Download 'us-ascii' (1 KB)
Subject: Re: Math question
Date: 10 May 2000 06:44:41
Message: <39193d98@news.povray.org>
#macro Dist(RayOrigin, Direction, Point)
  ((Point.x-RayOrigin.x)/Direction.x)
// supposing that 'Direction' actually is a unit vector
Date: 10 May 2000 09:02:51
Message: <chrishuff_99-0FD131.08061210052000@news.povray.org>
In article <3918D8BA.79E41F33@hotmail.com>, Pabs <pab### [at] hotmailcom>
> vector and
I think you are looking for the distance between two points. In POV
scenes, just use vlength(PtA-PtB). If in a POV patch, I think there is a
VDist() macro.
If in something else, it can be implemented like this:
double vdist(double x, double y, double z, double a, double b, double c)
{   return sqrt(sqr(x-a) + sqr(y-b) + sqr(z-c));}
Of course, you should probably use some kind of vector data type to
simplify things.
This gives you the distance, the direction(+/-) should be pretty easy to
figure out.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 10 May 2000 15:45:20
Message: <sqejhso8m5hqbugjhcpgsru1jiipjgf2vv@4ax.com>
Or if it's not:
  #local Dir=vnormalize(Direction);
  ((Point.x-RayOrigin.x)/Dir.x)
Peter Popov ICQ : 15002700
Date: 10 May 2000 22:01:20
Message: <391A13E8.53BB7F05@hotmail.com>
> Or if it's not:
> #end
Will try this - actually this is for part of a patch (ParticlePatch)
> VDist() macro.
> simplify things.
> figure out.
I tried using VDist & the result is always positive because -ve * -ve = +ve
Thanks all
Pabs
Date: 10 May 2000 22:28:19
Message: <chrishuff_99-9914E0.21314010052000@news.povray.org>
In article <391A13E8.53BB7F05@hotmail.com>, Pabs <pab### [at] hotmailcom>
> +ve
The point direction should not be difficult to figure out...something
like this maybe(I am tired and this is untested, so be warned):
O = ray origin(vector)
Pt = point on ray(vector)
Dir = ray direction(normalized vector)
Dist = point distance, calculated with VDist(floating point)
DBL cosA = 0;
VECTOR tmp;
VSub(tmp,Pt,O);
VNormalizeEq(tmp);
VDot(cosA, Dir, tmp);
if(cosA<0)
{   Dist *= -1;}
This basically flips the number(positive to negative) if the point and
the direction are not on the same side of the ray. I think.
Date: 11 May 2000 21:30:07
Message: <391B5EC6.7981033F@hotmail.com>
THANKS - IT WORKS
