POV-Ray : Newsgroups : povray.advanced-users : difficult questions (for me anyway) Server Time
5 Nov 2026 19:37:10 EST (-0500)
  difficult questions (for me anyway) (Message 1 to 22 of 22)
Subject: difficult questions (for me anyway)
Date: 8 Mar 2000 11:48:51
Message: <38c68473@news.povray.org>
I've two questions:
I have a cylinder from 0 to x*1, rotate it randomly around the y axis. Can I
find the xyz values of the end point that was x*1?
If so: I make a second cylinder from this point to x*2 and rotate it
randomly - does it rotate around zero or around the end point of cylinder
one? If it rotates around zero how can I make it rotate around the end of
cylinder one? do I have to translate it to zero, then rotate it, then
translate it to the end of cylinder one?
loop back to question one!
Hope that makes sense
Mick
       http://www.minda.swinternet.co.uk/index.htm
Subject: Re: difficult questions (for me anyway)
Date: 8 Mar 2000 12:11:02
Message: <38c689a6$1@news.povray.org>
Mick Hazelgrove skrev i meddelandet <38c68473@news.povray.org>...
I
I don't think that's possible, if you don't calculate the random value and
save it in a variable before you rotate the cylinder, like this:
#declare R = rand();
rotate <0, R, 0>
Then you can calculate the new endpoint using sin() and cos().
>one?
Yes, everything rotates around <0, 0, 0> in POV.
Yeah.
--ll
Date: 8 Mar 2000 12:19:55
Message: <38c68bbb@news.povray.org>
Lars Luthman <no### [at] spamse> wrote:
: #declare R = rand();
: rotate <0, R, 0>
: Then you can calculate the new endpoint using sin() and cos().
  Or more easier with vrotate().
Date: 8 Mar 2000 13:13:23
Message: <38c69843@news.povray.org>
Please explain, for me and for other maths disadvantaged pov users!
Date: 8 Mar 2000 13:38:06
Message: <38C69E24.E80E6439@gci.net>
From the docs:
vrotate(A,B)
Rotate A about origin by B.
Given the x,y,z coordinates of a point in space designated
by the vector A, rotate that point about the origin by an
amount specified by the vector B. Rotate it about the x-axis
by an angle specified in degrees by the float value B.x.
Similarly B.y and B.z specify the amount to rotate in degrees
about the y-axis and z-axis. The result is a vector containing
the new x,y,z coordinates of the point.
A contains a point reference
B contains a rotation reference.
The function vrotate(A,B) returns the new point reference
if you rotate point A by rotation B.
i.e. point{<0,0,0> translate A rotate B}
I know that there is no object called point{ <location>
[OBJECT_MODIFIERS...] }
but it does help to use it in this way with translate and rotate .
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 8 Mar 2000 14:07:53
Message: <38c6a509@news.povray.org>
Thanks everybody, problem solved.
Mick
"mr.art" <mr.### [at] gcinet> wrote in message news:38C69E24.E80E6439@gci.net...
> From the docs:
> vrotate(A,B)
> Mr. Art
> Bill DeWitt 2000
Date: 8 Mar 2000 15:20:01
Message: <pwldTMAYWrx4EwnE@econym.demon.co.uk>
You can get it to behave either way. You just have to configure things
right. If you want cylinder 2 to rotate about the end of cylinder 1,
then define them something like this:-
#declare Forearm = cylinder {0,x,...
  rotate <...>  // elbow
#declare WholeArm = union {
  cylinder {0,x,...}
  object {Forearm translate x}
  rotate <...>  // shoulder
The rotate instruction attached to Forearm rotates it about the elbow,
and the rotate instruction attached to WholeArm rotates the whole arm
about the shoulder keeping the elbow joint connected.
In general, the trick is to create the objects with the rotation point
at zero, apply the rotation, then perform the translation to where you
really want them later. In this way you can keep adding more sections to
the hierarchy and they'll all hang together and rotate correctly about
the joints you create.
Mike Williams * ##
Gentleman of Leisure
Date: 8 Mar 2000 23:38:18
Message: <38C729F2.FF588583@faricy.net>
> I've two questions:
cylinder { <0,0,0>,<1,0,0>,n rotate bla*y } //correct?
then the end point will be <sin(bla),0,cos(bla)>
Unfortunately, yes. Maybe I should add arbitrary origin to those macros... :-)
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 9 Mar 2000 03:17:10
Message: <38c75e06@news.povray.org>
Mick Hazelgrove <mha### [at] mindaswinternetcouk> wrote:
: Please explain, for me and for other maths disadvantaged pov users!
  As mr. art said, there's this thing called "documentation". Ever heard
about it?
Date: 9 Mar 2000 03:27:47
Message: <38C7611A.C08BD85@pacbell.net>
> about it?
I have but without the proper educational background there are times it
makes absolutely no sense what so ever. An example is sometimes worth
1000 documented words. If a person had understood the original explaination
they would not have asked for clarification. What is easy for you may be
difficult for others. Not every thing in POV-Ray is inherently obvious
or intuitive. We are here to help not criticize. Dare to teach so that
others may learn. Patients is a virtue. Lead by example. Give till it
hurts.
Date: 9 Mar 2000 04:40:35
Message: <38C77193.C429545C@ica.uni-stuttgart.de>
> hurts.
The virtues of a noble POVer ... I wonder if you have sworn an oath for
it.
Thank you Ken!  I really mean it.
Marc
Marc Schimmler
Date: 9 Mar 2000 04:54:49
Message: <chrishuff_99-543B15.04563509032000@news.povray.org>
In article <38C729F2.FF588583@faricy.net>, David Fontaine
I prefer:
cylinder { <0,0,0>,<1,0,0>,n rotate bla*y}
The end point will be vrotate(<1,0,0>, bla*y)
Note that your solution should be <sin(degrees(bla)), 0,
cos(degrees(bla))>, unless you specify your angles in radians. But
vrotate works for any rotation, instead of just a rotation around an
axis, so I would recommend you use it. It also makes your code easier to
figure out when you come back to it after abandoning it for a week.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 9 Mar 2000 06:18:00
Message: <38C788FF.E25C883C@pacbell.net>
> it.
Well I do swear from time to time...
  Well thank you for thanking me. Looking back to all of the questions
I have answered and all of the people I have helped I am satisfied with
the contributions I have made to the POV-Ray community. At other times
I wonder if I have done enough. Was my help needed ? Were my answers
good enough ? Should I have tired harder, written more, and explained
better ? All I can really do is contribute what I can and hope that
others share what they know when they too have the opportunity to.
Date: 9 Mar 2000 06:32:05
Message: <38C78FBC.E0929D84@nanterre.marelli.fr>
It should be <sin(radians(bla), 0, cos(radians(bla)))>, isn't it ?
Assuming bla is in degrees...
Bouf.
Date: 9 Mar 2000 07:00:17
Message: <chrishuff_99-A18175.07020309032000@news.povray.org>
In article <38C78FBC.E0929D84@nanterre.marelli.fr>, Bouf
Er, yes. My explanation? I was only on my second cup of coffee this
morning. :-)
Oh, another way to do it(assuming you are using MegaPOV) would be
vtransform(<1,0,0>, rotate bla*y). Not necessarily the best way in this
case, but if you are using several transformations in a row, you can
#declare them as a transform and use that to modify both the object and
the vector. Like this:
#declare Vect = < 1, 0, 0>;
#declare Trans =
transform {
    rotate, scale, translate...
object {MyObj
    transform {Trans}
#declare startVect = vtransform(Vect, Trans);
Chris Huff
Date: 9 Mar 2000 08:17:58
Message: <38c7a486$1@news.povray.org>
Especially if you happen to be a doctor or a dentist.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 9 Mar 2000 11:01:17
Message: <38c7cacc@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: We are here to help not criticize.
  I apologize.
  It's just that sometimes the RTFM-mentality hits me when something looks
so simple (to me) in the manual.
Date: 9 Mar 2000 11:44:14
Message: <38c7d4de@news.povray.org>
Thanks again for your help.
The trig solution should have been obvious but for some reason didn't occur
to me in this context.
Vector math is something we did not study 45years ago when I was at school
and I have had little time to try and understand it since. I have learnt
allot from this discussion about vrotate and have solved my original problem
now, using both vrotate and trig.
One last point. Many of us do not work in environments full of high powered
mathematical brains and computer gurus - we rely on this news groups to help
us understand. I for one thank you for all your patience.
Mick
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-A18175.07020309032000@news.povray.org...
> morning. :-)
> #declare Trans =
> transform {
> object {MyObj
>     transform {Trans}
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 9 Mar 2000 12:09:00
Message: <38C7DB6A.F2F34FA4@spiritone.com>
There is a brief visual explanation here:
http://www.spiritone.com/~english/cyclopedia/vrotate.html
hopefully this helps. If not, please send me osme feedback so I can make
this more useful for people
Josh
Josh English
eng### [at] spiritonecom
Date: 9 Mar 2000 17:33:58
Message: <38C82748.F7A08FF1@peak.edu.ee>
There are some vector math examples (in the animations section, I believe). I
really recommend anybody who has trouble understanding the maths render those
examples since, as you say, they are worth a 1000 words.
Heck, they even helped me understand what vdot does. No verbal explanation had
managed to do that.
Perhaps similar examples should be added to encompass more functions. The one
Mick mentioned seems a common requirement.
Margus
Date: 9 Mar 2000 18:32:06
Message: <38C833B5.111745F5@faricy.net>
Oh yeah, forgot. That's such a pain in the arse.
What's so great about radians anyway? That the arc length of one radian is
the radius? Some magical property of pi? Why do mathematicians always seem
to prefer radians to degrees?
Date: 10 Mar 2000 00:26:20
Message: <38c8877c@news.povray.org>
David Fontaine wrote in message <38C833B5.111745F5@faricy.net>...
Because calculus works out much better if you use radians.
Mark
