This code shows something I found the other day: a macro (intp) wich returns a
number, affects the x-value when used in some vector expressions.
At first I thought it was a bug in MegaPov, but it also shows up in
POV-Ray 3.1e
#macro intp(X,X1,Y1,X2,Y2)
(Y2-Y1)/(X2-X1)*X - (Y2-Y1)/(X2-X1)*X1 + Y1
#macro Print(V1)
#local v1=V1*<1,1,1>;
#render concat(
str(i,1,0),": <",
str(v1.x,2,1),", ",
str(v1.y,2,1),", ",
str(v1.z,2,1),">\n"
#declare var1=.1;
#declare var2=1;
// this one adds var1*x
#declare i=0;
#while (i<=3)
Print( x + (y+z)*intp(i, 0, var1, 3, var2) )
#local i=i+1;
#render "\n"
// this is fine
#declare i=0;
#while (i<=3)
Print( <1, intp(i, 0, var1, 3, var2), intp(i, 0, var1, 3, var2)> )
#local i=i+1;
#render "\n"
//this is fine
#declare i=0;
#while (i<=3)
Print( x + (y+z)*.3*i )
#local i=i+1;
#render "\n"
//this is also fine
#declare i=0;
#while (i<=3)
Print( <1, .3*i, .3*i> )
#local i=i+1;
Hei Kyrre!
If you put parenthesis around your macro result it will
stop acting strange.
Like this:
((Y2-Y1)/(X2-X1)*X - (Y2-Y1)/(X2-X1)*X1 + Y1)
The third parameter; Var1 (Y1) passed to your macro
will not be multiplied with (y+z) if you don't do this.
(If you omit the parenthesis, then Var1 is promoted to
a vector before it's added to a vector.)
Tor Olav
mailto:tor### [at] hotmail com
> POV-Ray 3.1e
> #end
> #declare var1=.1;
> #declare var2=1;
> #declare i=0;
> #while (i<=3)
> #local i=i+1;
> #end
> #render "\n"
Ah! Thanks. It's so easy to treat something like intp() like a function.
sig
Tor Olav Kristensen wrote:
> Hei Kyrre!
> Like this:
> #end
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
> > POV-Ray 3.1e
> > #end
> > #declare var1=.1;
> > #declare var2=1;
> > #declare i=0;
> > #while (i<=3)
> > #local i=i+1;
> > #end
> > #render "\n"
Hei igjen.
This part of the expression would also have been
promoted to a vector if you hadn't passed 0 for the
second argument (X1) to the macro:
(Y2-Y1)/(X2-X1)*X1
It actually adds var1*(x + y + z)
(or <var1, var1, var1>)
Tor Olav
Btw.: Here's a slightly simpler macro to do the same:
((Y2-Y1)/(X2-X1)*(X-X1)+Y1)
You have to remember that a macro is _not_ a function. A macro is a
substitution string. The body if the macro is inserted in the place of
the call as-is.
So, for example this:
#macro Sum(X, Y)
X+Y
#declare result = 2*Sum(3,4);
will result in:
#declare result = 2*3+4;
The right way of doing the macro is, of course:
#macro Sum(X, Y)
(X+Y)
Now the result will be:
#declare result = 2*(3+4);
> the call as-is.
Hmmm...
If that is true, then why does this not work?
#macro Test(ss)
{ ss, ss, ss }
#declare TestArray = array[3] Test(2)
Tor Olav
Tor Olav Kristensen <tto### [at] online no> wrote:
: If that is true, then why does this not work?
I have no idea.
> > the call as-is.
> Hmmm...
Er, well...it should work.
I tried some other combinations, putting the brackets outside the macro,
enclosing each value with parenthesis...it still doesn't work. When I
put a #debug statement in the macro, I found the macro is never called.
Maybe you should compose a bug report. This looks like a real bug.
Christopher James Huff - Personal e-mail: chr### [at] yahoo com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
I suppose that it's because a macro call is not expected after the
declaration of an array and thus it never gets parsed.
Probably a mistake.
> Probably a mistake.
For me it seems to be parsed in some strange way, because I
get this error message:
{ <----ERROR
Test.pov: error: object or directive expected but { found instead.
Would the "{" appear in the error message if the macro
wasn't ever parsed?
Tor Olav
Btw: Does anyone know if it's possible to copy (and paste)
a text string from the error message window in the
Windows POV?
: Btw: Does anyone know if it's possible to copy (and paste)
: a text string from the error message window in the
: Windows POV?
Only the whole text window. This is what I have wondered too.
