POV-Ray : Newsgroups : povray.advanced-users : tiles etc..... Server Time
30 Jul 2026 11:06:18 EDT (-0400)
  tiles etc..... (Message 1 to 3 of 3)
Subject: tiles etc.....
Date: 24 Mar 2000 08:40:13
Message: <38DB703D.AAD57708@psu.edu>
Hi.
I am having a little problem that i hope you all could help me with.
I am trying to make a tiled floor with cracked or partially dissolved
tiles. I have set up a nested #while loop which takes care of placing
each tile based on the dimensions supplied by the user. The tiles are
superellipsoids. Now here comes the problem... to eat away from the
tiles I can either difference each tile with a height-field (inside the
#while loop), or difference the whole, completed floor (all tiles are
unioned) with one huge height-field. The problem is the parsing time,
using the former approach, parsing times of 2-4 hours are not uncommon,
the latter parses much quicker, but I have less control (and to a
certain extent, quality). I want to stay away from normal modifiers
because I want a true 3-D decayed floor. Any suggestions?
-Paul
Subject: Re: tiles etc.....
Date: 24 Mar 2000 11:52:36
Message: <chrishuff_99-7732BC.11544624032000@news.povray.org>
In article <38DB703D.AAD57708@psu.edu>, Paul Jones <pdj### [at] psuedu>
You could use isosurfaces. Even if you only use them for individual
tiles, you can get a speed improvement(isosurface superellipsoids are
often faster than the superellipsoid primitive). You could also make a
bunch of tiles out of one isosurface, if you design the function
properly. Something like this will work for that:
isosurface {
    function {abs(sin(x*pi))*abs(sin(z*pi))*abs(y)}
    threshold 0.05
    sign -1
    eval
    accuracy 0.01
    contained_by {box {<-2,-1,-2>, < 2, 0, 2>}}
        pigment {color rgb < 0.8, 0.5, 1>}
        finish {brilliance 3}
    scale < 1, 0.2, 1>
This parses and renders fast, and you can use difference or intersection
to get cracks and gaps. You can also use pigments to modify the surface,
slower rendering but potentially great results:
#declare CrackFn = function {
    pigment {crackle ramp_wave
        color_map {[0 color rgb <0,0,0>][1 color rgb <1,1,1>]}
        turbulence 0.1
isosurface {
    function {(1-abs(sin(x*pi))*abs(sin(z*pi))*abs(y))*1.05
        &(1-CrackFn(x,y/5,z))*1.1
    threshold 1
    eval
    accuracy 0.01
    scale < 1, 0.2, 1>
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Date: 24 Mar 2000 11:54:24
Message: <38db9dbf@news.povray.org>
Using a proper normal modifier can give a very good result with a lot
faster parse/render time. Unless you want to look to the floor very closely.
