POV-Ray : Newsgroups : povray.advanced-users : Intersection Testing in #while loops. Server Time
30 Jul 2026 11:06:18 EDT (-0400)
  Intersection Testing in #while loops. (Message 1 to 4 of 4)
Subject: Intersection Testing in #while loops.
Date: 10 Mar 2000 13:49:45
Message: <38C9444B.1A6E92FB@pacbell.net>
If I create a group of objects with a while loop
#declare Thing =
union {
 #declare a = 0;
   #while (a<10)
     #declare b = 0;
       #while (b<10)
         sphere{<a,b,0>,1}
       #declare b=b+1;
   #declare a=a+1;
and then intersected my new object Thing with a plane
intesection {
 object{ Thing }
  plane {y,0 }
would the intersection testing be done only to those objects that the
plane actually comes in contact with or would the intersection testing
be done against every object in the object Thing ?
Subject: Re: Intersection Testing in #while loops.
Date: 10 Mar 2000 14:33:50
Message: <38C9528C.CBB5E10E@merlin.net.au>
> #declare Thing =
> union {
>  #declare a = 0;
>    #while (a<10)
>      #declare b = 0;
>        #while (b<10)
>          sphere{<a,b,0>,1}
>        #declare b=b+1;
>      #end
>    #declare a=a+1;
>  #end
> intesection {
>  object{ Thing }
>   plane {y,0 }
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Good question. I suspect that all objects will be tested for
intersection.
It should be possible during parsing to test whether objects in an
intersection will actually intersect, at least for simple primitives.
PoD.
Date: 10 Mar 2000 16:01:19
Message: <38c9629f$1@news.povray.org>
>intesection {
> object{ Thing }
>  plane {y,0 }
Only the object it comes in contact with, in this case, but only because
you picked such an easy plane.
POV computes the bounding box of the intersection by intersecting the
bounding boxes of its constituents.  If a plane is axis-aligned, as
yours is, its bounding box is the half-space that would be considered
its "inside".  So the intersection of the two bounding boxes is the
half of the union's bounding box that is inside the plane.
Had you intersected with plane {x+y,0}, however, this optimization would
not have happened.  You could still attempt to bound it manually.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 11 Mar 2000 07:57:35
Message: <38CA4323.33636462@pacbell.net>
I suspected this was the case since some CSG operations on groups
of objects seem to operate much faster than they do on others.
Thanks for the input,
