POV-Ray : Newsgroups : povray.advanced-users : Square roots of negative numbers in isosurfaces? Server Time
19 Oct 2026 05:23:57 EDT (-0400)
  Square roots of negative numbers in isosurfaces? (Message 1 to 26 of 26)
Subject: Square roots of negative numbers in isosurfaces?
Date: 10 Jan 2000 09:00:16
Message: <3879E51F.77B9A241@my-dejanews.com>
How "should" an isosurface respond when there is an undefined region of
space?
I just ran something like
        function{noise3d(x^0.5/constant , y/constant , z/constant}
.  The result is symmetric about the x-axis!
Is this an algorithm mistake?
Did pov just uncover a great secret of mathematics: all this fuss over
the square root of negative numbers was a tempest in a teapot??
Subject: Re: Square roots of negative numbers in isosurfaces?
Date: 10 Jan 2000 10:55:10
Message: <387a00de@news.povray.org>
Greg M. Johnson <gre### [at] my-dejanewscom> wrote in message
news:3879E51F.77B9A241@my-dejanews.com...
> space?
*I* wouldn't want to get an error every time I had an isosurface
do (-1)^.5,  but I think this is a very debatable topic.
What would you like the program to do in this case?
The isosurface stuff converts x to absolute value of x
before trying to use the ^. This is just to avoid many floating
point errors.  The isosurface code does the same conversion
before applying sqrt() or ln().
Personally I think its OK, (but perhaps the program should put out
a warning). If you look at isosurface scenes posted in these newsgroups,
you will find a lot of square roots and logs of negative numbers being done,
and a lot of this is probably being done completely oblivious to the
mathematical inconsistency.
Date: 10 Jan 2000 11:02:27
Message: <387a0293@news.povray.org>
Does it only do that for fractional exponents, or does it also
do it for odd integer exponents?
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 10 Jan 2000 11:45:33
Message: <387a0cad@news.povray.org>
david sharp <dsh### [at] interportnet> wrote in message
news:387a0473@news.povray.org...
> Ron Parker <ron### [at] povrayorg> wrote in message
> news:387a0293@news.povray.org...
> Always.
No, not always. (I should have actually checked before replying)
there is a ffloor test to distinguish integers from fractions.
Date: 10 Jan 2000 13:53:13
Message: <387A29CF.D6C94973@my-dejanews.com>
Are you sure?
function {noise3d(x ^0.5, y, z)}, I know,  is symmetric about the x=0
plane.
function {noise3d(x^3.0, y, z)}, I will bet, behaves correctly, and has
a kind of symmetry like the curve y=x^3.
There is something "more wrong" here.  If Ron were correct, then x^3
would also be symmetric about x=0.
> > Always.
Date: 10 Jan 2000 23:17:20
Message: <387aaed0@news.povray.org>
Greg M. Johnson wrote:
> Are you sure?
Sure about what?
> plane.
Because x^.5 actually does (abs( x))^.5
(calling the C function pow(abs(x),.5) )
Because x^3.0 actually does x*x*x
Ron didn't claim x^3 was (abs(x))^3. I  prematurely did claim that, and
I was horribly, sorrowfully, and disgustingly mistaken.
> > > Always.
Date: 11 Jan 2000 15:26:49
Message: <387B913E.9BBE68F1@my-dejanews.com>
Actually, I think that this is what povray does:
if I say,               noise3d (x^a                            ,  y,z)
it processes        noise3d (sign(x)*pow(abs(x),a),  y,z)
I will try to prove this tonight.
[I thought someone had asked what SHOULD it do--was that note deleted?]  If
povray processes the formula above as I described, there's no problem--it was
just a mystery to be solved . . .
Date: 11 Jan 2000 15:38:34
Message: <387b94ca@news.povray.org>
Well, there's that little problem of x^2+y^2+z^2-1 (threshold 0) not being a
sphere anymore, but other than that...
Date: 12 Jan 2000 08:15:51
Message: <387C7DB8.95F16859@my-dejanews.com>
Okay, how about:
x^a =  sign(x)^int(a) * pow(abs(x), a)      ?
Povray is doing SOMETHING, as it gives me a picture in a mathematically undefined
region of space!  It was driving me crazy to figure out what it was doing  . . .
Date: 13 Jan 2000 23:41:23
Message: <387EA67E.7CE91E84@faricy.net>
What I think POV *should* do is not include these areas in the graph. Say I
want to graph a hemisphere on my TI-89, I do x^2+y^2+z^2=1, z^2=-x^2-y^2+1,
z=sqrt(1-x^2-y^2), and graph it and it gives me my hemisphere, and the area
*outside* the hemisphere is ignored (not rendered) because it is sqrt(neg).
Because if people want it to work the other way they can always just make
it sqrt(abs(x)) instead of sqrt(x).
Date: 14 Jan 2000 00:02:47
Message: <chrishuff_99-A0DA74.00030614012000@news.povray.org>
In article <387EA67E.7CE91E84@faricy.net>, David Fontaine
> I
> z^2=-x^2-y^2+1,
> area
> sqrt(neg).
I think this might be difficult to do, because the isosurface is solved
by sampling the function at different points. I don't see how it could
be done.
Then again, it is after midnight now, it is probably just that I am
tired and not thinking straight.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 14 Jan 2000 17:10:49
Message: <387F9E1B.F3DF1811@my-dejanews.com>
But the point is that pov is doing SOMETHING.  If it finds a definite
isosurface for a mathematically undefined region of space, then povray is in
reality not computing the given function, but converting it to some defined
function. Or there is an error in how it has defined some functions.
perhaps
    x^a = sign(x)^int(a) * abs(x)^a
because
    noise3d(x^3.1, y, z)
gives "something" for negative values of x !
I'm not complaining as much as striving to solve the mystery . . .
> > I
> > z^2=-x^2-y^2+1,
> > area
> > sqrt(neg).
> be done.
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 14 Jan 2000 17:16:00
Message: <387F9F51.19F25191@my-dejanews.com>
Yet another possibility, as I jokingly suggested, is that pov has "discovered"
solutions to these functions, and mathematicians and programs like Lotus 123 are
"wussies" for refusing to give an answer to these unorthodox
questions..............
> perhaps
> because
Date: 14 Jan 2000 17:21:35
Message: <chrishuff_99-19A28A.17215614012000@news.povray.org>
In article <387F9E1B.F3DF1811@my-dejanews.com>,
> in reality not computing the given function, but converting it to some
> defined
But if it stops when it attempts to sample at an undefined spot, there
could be defined areas that would be missed or rendered incorrectly.
Maybe there should be a "strict_math" option. If strict_math is on, then
it will perform the solving operation as it usually does, and then test
the function at that point using standard math to see if it is defined
at that point. If it is defined, then count it as an intersection,
otherwise skip it. That way, the undefined areas would be removed(by a
kind of customized clipping). And older isosurfaces would still work
properly, either with the addition of "strict_math off" or by having
strict_math default to off.
Chris Huff
Date: 14 Jan 2000 21:20:24
Message: <FslWUEAg43f4EwTB@econym.demon.co.uk>
That might be possible when using the function as an isosurface, but
such a function can also be used as a pattern for a pigment or normal.
When a function has no solution in a region of space you could ignore it
if you're using that function to define a surface, but what could you do
if there's a point where the surface exists but the pigment and/or
normal doesn't. E.g.
sphere {0,1
            function {noise3d(x^0.5/K, y/K, z/K)}
            colour_map{[0 rgb <1,0,0>][1 rgb <1,1,0>]}
        normal {
Mike Williams + #
Gentleman of Leisure
Date: 15 Jan 2000 22:45:49
Message: <38813C69.D04DBC9F@faricy.net>
> sphere {0,1
>         pigment {
>         normal {
Well it's up to the user to make a function that doesn't do that. It could issue
a warning and replace it with zero or something.
Date: 17 Jan 2000 07:04:08
Message: <38830469.C475282D@my-dejanews.com>
No problem, but pov is doing SOMETHING.  It makes up its own definition in the
undefined areas. That's the mystery.
what is x^a?
> Chris Huff
Date: 17 Jan 2000 11:54:25
Message: <38834975.C6C381E5@ij.net>
> what is x^a?
    x to the power a or exp( a * log(x) )
    If a = 2 then it would be x*x
Date: 17 Jan 2000 16:20:44
Message: <388386DC.48C2398@my-dejanews.com>
> > what is x^a?
Nope.  You cannot take the ln(x) of a negative x! Therefore, that's NOT what povray
is doing!  My guess is
x^a= sign(x)^int(a)* abs(x)^a .
My re-writing of the function is "defined" for all values of x and a, whereas x^a is
NOT.
Again, I hound this point not to attack the giants whose shoulder we stand on--pov
developers--but to have fun at solving a mathematical mystery : what IS pov doing?
Date: 17 Jan 2000 16:25:00
Message: <3883870C.729B3B58@pacbell.net>
Perhaps only Mr. Suzuki can answer this question...
Date: 17 Jan 2000 16:32:09
Message: <38838a59@news.povray.org>
void func_exp_xy(void)
  if (((*calc_stack_top)>0) && ((*calc_stack_top)<16) &&
      (FFLOOR(*calc_stack_top)== *calc_stack_top))
    fint= *(calc_stack_top--);
    ftemp1= (*calc_stack_top);
    for (; fint>1; fint--) (*calc_stack_top)*= ftemp1;
  else
    calc_stack_top--;
    *(calc_stack_top)= pow( *(calc_stack_top),*(calc_stack_top+1));
translated:
in the equation x^y,
if y is an integer between 1 and 15 inclusive
  calculate x^y by multiplying x by itself y times.
otherwise,
  call the C function pow(x,y) and return its result
  directly.
Presumably, pow(x,y) itself does something when presented
with invalid parameters, but what that is isn't specified
in the MSVC documentation.  It may be specified in the ANSI
C spec; I haven't checked.
Date: 17 Jan 2000 17:26:46
Message: <38839656.3849FE0C@my-dejanews.com>
Thanks.  But the mystery deepens. I found a web page mentioning an ANSI standard:
http://www.thinkage.com/expl/c/lib/pow.html
|  <math.h>
|  z = pow( x, y );
|  Description:
|  "pow" returns "x" to the power "y". If "x" and "y" are both zero, or if "x" is
|  non-positive and "y" is not an integer, "pow" return -HUGE_VAL and sets
|  "errno" to EDO
I have little understanding of this stuff, but pov seems to be doing something
different.
>   directly.
Date: 17 Jan 2000 19:35:05
Message: <3883b539@news.povray.org>
In article <38838a59@news.povray.org> , ron### [at] povrayorg (Ron Parker)
The docs I have say this:
The macro pow(x,y) returns x raised to the power yx xy.
If x is +0.0 and y is negative, then pow returns +inf and signals divide by
zero.  If x is -0.0, and y is integral and negative, then pow signals divide
by zero and returns +inf if y is even, or -inf if y is odd.
The function pow returns NaN and signals invalid if:
both x and y are 0.0, or
x is +-inf and y is 0.0, or
x is 1.0 and y is +-inf, or
x is -0.0 or negative and y is non-integral.
     Thorsten
e-mail: tho### [at] trfde
Date: 18 Jan 2000 00:15:58
Message: <3883F73F.9ED303FD@ij.net>
> > > what is x^a?
    I do abs(x) when I have such problems. Mathematicians hate me but it usually
works.
    sign(x) is my second last resort. I'd rather avoid it as it usually does not work
being function specific as to whether or not it works. My last resort is actually
digging into the function and making sense of it.
> NOT.
    The idea of epsilon, for small values of zero, is also a useful compuational
concept. x+.000001 never hurts when folks do theoretical implementations.
    I do not claim to know all the computational tricks, but I think I do. If you are
really into a function you can find more adaptive ways to avoid problems. But I can't
remember the +.000001 trick failing since 1967. You can't publish the trick without
showing it applies but if it works ... So what is your audience?
    I am sure there are but I do not know of any smooth function (not discontinuous
like
1 and 0 binary) that has any problems with evaluation at any point but real zero. And
with a smooth function the small value always works.
    This not new so I guess I am missing your problem. Care to repeat or rephrase?
Date: 18 Jan 2000 00:23:38
Message: <3883F90B.CFEC940E@ij.net>
> |  <math.h>
> |  z = pow( x, y );
> |  Description:
> |  "errno" to EDO
> different.
    If this is the issue, the current vice the older one that POV implements, is like
exp(4096).
    If that guess is valid ... comments?
Date: 18 Jan 2000 08:16:10
Message: <3884679a@news.povray.org>
like
Well, sqrt(x) is undefined for all x<0.  But somehow the isosurface patch
manages to deal with that.  I think the reason is that the processors we
usually run it on keep going on getting a NaN result.  Try running it on
an alpha and see how quickly it manages to crash.
