POV-Ray : Newsgroups : povray.advanced-users : Text objects on Pov? Server Time
19 Oct 2026 05:23:30 EDT (-0400)
  Text objects on Pov? (Message 1 to 7 of 7)
Subject: Text objects on Pov?
Date: 10 Dec 1999 12:23:38
Message: <3851371a@news.povray.org>
I came across a problem with the text object....
I was trying to write "LÄGERTIDNING" with the text object but Povray put
another character instead of the Ä , I was able to Use chr(128) and got the
character.
The problem was that I did dot find a way to put the whole word in the same
text object
like in "LÄGERTIDNING" but I had to split it up into parts like "L"
,chr(128), "GERTIDNING".
Is there a way to put all the characters in one string so that I only have
to use the Text command once to draw the word?
Ambis
Subject: Re: Text objects on Pov?
Date: 10 Dec 1999 12:32:37
Message: <38513935@news.povray.org>
AC <amb### [at] teliacom> wrote:
: Is there a way to put all the characters in one string so that I only have
: to use the Text command once to draw the word?
  Yes, using the concat() function.
Date: 10 Dec 1999 17:32:21
Message: <38517f75@news.povray.org>
Nieminen Juha <war### [at] punarastascstutfi> wrote in message
news:38513935@news.povray.org...
have
Not exactly what I mean........
line from a povfile:
 text { ttf "c:\windows\fonts\Times.ttf" "NÄPP" .1, 0 pigment {rgb <0,0,0>
scale .1 }  rotate <0,0,0>}
The "Ä" is not am "Ä" when I render the immage so I have to use chr(128),
Is it possible to do somthing like this in Povray.....
 text { ttf "c:\windows\fonts\Times.ttf"                "N" + chr(128) +
"PP"          .1, 0 pigment {rgb <0,0,0> scale .1 }  rotate <0,0,0>}
I think you get the idea
Date: 10 Dec 1999 17:53:07
Message: <chrishuff_99-5E6B76.17532910121999@news.povray.org>
>  <0,0,0>
Maybe that character can only be accessed with the Unicode patch by Jon
Cruz. It is included in the Superpatch, although it apparently has some
problems with the Mac.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 10 Dec 1999 21:01:47
Message: <3851B023.47BF9C17@xs4all.nl>
> only
> have
> Warp -*/
> <0,0,0>
> chr(128),
Yes, as Warp said:
text {
  concat("N" + chr(128)+"PP")
  .1, 0
  rotate <0,0,0>
Date: 11 Dec 1999 01:41:24
Message: <3851F1F4.4ED4DA22@geocities.com>
> >  <0,0,0>
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Yes, the Unipatch should do the job. It's in the superpatch.
See here for some simple docs
http://www.geocities.com/SiliconValley/Network/4453/unipatch/
http://www.geocities.com/SiliconValley/Network/4453/unipatch/unipatch.jpg
But it is very strange that chr(128) should work for that. But... that's
because it happens to be the location of the capital letter 'A' with diaeresis
in the Apple roman font encoding, and the official POV-Ray goes for the first
Apple encoding table in all fonts... (try a different font and you might get
it popping up in a different location)
Oh, and the Unipatch doesn't really have a problem with the Mac. Just with
poorly done Mac fonts :-) . But in the version that I'm almost done with, that
is fixed. Along with some bugfixes that will cause even the standard POV-Ray
to choke on most newer Mac fonts.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Subject: Re: Text objects on Pov? ...... Thanks
Date: 11 Dec 1999 05:46:08
Message: <38522b70@news.povray.org>
Remco de Korte <rem### [at] xs4allnl> wrote in message
news:3851B023.47BF9C17@xs4all.nl...
> > only
> > have
> > Warp -*/
> > <0,0,0>
> > chr(128),
> Yes, as Warp said:
> text
>   .1, 0
>   rotate <0,0,0>
Thanks for the help, It solved my problem
Ambis
