Could somebody provide me with a function (preferably in a no-brainer macro form
:) that gives concentric cones? I want to use it in a pigment...
Thanks
Margus
On Wed, 17 Nov 1999 02:09:40 +0200, Margus Ramst <mar### [at] peak edu ee>
>Thanks
>Margus
Concetric in what manner? Sharing a common vertex and concentric in
terms of angle, or sharing a common angle and concentric in terms of
vertex and base?
Peter Popov
ICQ: 15002700
The latter.
Margus
> vertex and base?
> Peter Popov
> ICQ: 15002700
Still not sure to fully understand what you need, but would something like
this work ?
(To be used with the superpatch of course)
camera{location -z*10 look_at 0}
plane{ z,0
texture {pigment {crackle form x frequency 3
color_map{[0 color <1,0,0>][0.25 color <1,1,0>][0.5 color rgb
0][0.75 color <0,0,1>][1 color <0,1,0>]} }
finish{ambient 1 diffuse 0}
G.
Margus Ramst wrote:
> The latter.
> Margus
> > vertex and base?
> > Peter Popov
> > ICQ: 15002700
I wrote,
>> vertex and base?
And on Wed, 17 Nov 1999 12:59:31 +0200, you wrote:
>The latter.
>Margus
So, what parameters will you need? Vertex1, Vertex2 (vectors), Radius1
and Radius2 (floats), right? Maybe just Radius1 and Radius2, with
vertices 1 and 2 being <0,0,0> and <0,1,0> resp. I will think about
that.
Peter Popov
ICQ: 15002700
Hmm... No.
I mean something like the wood pattern, which is basically concentric cylinders.
Imagine a stack of cones, all having the same XZ axis and vertex angle, but each
uniformly scaled larger than than the previous one. This is basically how real
woodgrain is structured.
I hope this explains what I need...
Margus
> this work ?
I would imagine that none of this is necessary, really. Preferably, this should
be an infinitely looping pattern, with the tip of the cones tapering to a point,
and the cones themselves extending into infinity. The vertex angle might make
things more convenient, but everythig can be adjusted by scaling.
I re-iterate, I would use this function for a pattern, not some finite object.
Margus
Peter Popov wrote:
> I wrote,
> >> vertex and base?
> >The latter.
> >Margus
> that.
> Peter Popov
> ICQ: 15002700
What I still have trouble figuring out is the kind of pattern you expect to see when
applied to an object, and how it would be different from regular wood, or onion, or
even spherical. Perhaps you could hand-draw something and post it in binaries ???
G.
Margus Ramst wrote:
> Hmm... No.
> Margus
> > this work ?
After _LOTS_ of thinking I got a really short answer:
Given an aperture angle 'Angle' for the cone and a point 'p' in space,
the color for that point is:
-sin(Angle)*abs(p.x)+cos(Angle)*vlength(<p.y,p.z>)
(Of course if you need a value between 0 and 1 you have to clamp the value
returned by that function; I don't know how isosurface functions work but
I suppose that they do the clamping by themselves when calculating
pigments.)
Nieminen Juha <war### [at] punarastas cs tut fi> wrote:
: -sin(Angle)*abs(p.x)+cos(Angle)*vlength(<p.y,p.z>)
Btw, if there's no vlength()-function available, this achieves the same
thing:
-sin(Angle)*abs(p.x)+cos(Angle)*sqrt(p.y*p.y+p.z*p.z)
This might be close to what you want, they aren't exactly concentric,
more like stacked:
box {< -5, -5, 0>, < 5, 5, 5 >
function {sqrt(x^2 + z^2)-y}
color_map {
[0 color Black]
[1 color White]
Thanks, but Netscape plays tricks on me...
Could you repost your previous message, I cannot see it.
Apparently there are 2 other new messages from around the same time that I can't
see (groups pane shows 3 unread messages, but not so the message pane). Weird.
Margus
> thing:
Thank you, I think this is just about it.
Margus
> more like stacked:
> texture {
> pigment {
> color_map {
> [0 color Black]
> [1 color White]
When you posted this message Warps content was included. I don't know what
you are doing wrong sir.
> Margus
> > thing:
Ken Tyler - 1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Margus Ramst <mar### [at] peak edu ee> wrote:
: Thank you, I think this is just about it.
Could you please check my suggestion too so that I would not feel as doing
lots of thinking work for nothing? Thanks :)
Thank you. It works well, with just one problem: the pattern is mirrored along
the XY plane. I'll try to use my own brains to fix this :)
Margus
Yes, but I can't see the message (his own) that he quoted in this post.
Sir still doesn't know whats wrong.
Margus
Sounds like stormy weather ahead...
