POV-Ray : Newsgroups : povray.advanced-users : Patina Server Time
5 Nov 2026 22:50:26 EST (-0500)
  Patina (Message 1 to 20 of 20)
Subject: Patina
Date: 26 Oct 1999 07:11:23
Message: <38158BD5.F0F02B93@pacbell.net>
2. (Fine Arts) The color or incrustation which age gives to works of art;
especially, the green rust which covers ancient bronzes, coins, and medals.
 It is quite common to see a patina discoloration inside the cracks,
crevices, and deep folds on sculpture while it's surface maintains
more of the original material's coloration.
 How would one apply this affect to a 3d object with proceedural methods
rather than relying upon complicated image maps ?
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Subject: Re: Patina
Date: 26 Oct 1999 07:51:44
Message: <38159661.C6A99AF7@yahoo.com>
I would simply use a layered texture. It might be a good idea to use
UVPov so you can have filtering layers, though.
Subject: Re: Patina
Date: 26 Oct 1999 08:07:47
Message: <38159993@news.povray.org>
A very clumsy way is to use a layered texture with the "patina" pattern
going from inside out with more opacity nearer the middle, like a spherical
or onion, then scaled to fit as well as possible.  Not really good for
anything except roughly spherical or some other basic shape.
A real good way, if it could be done, would be to use the object itself as
the pattern somehow.  Only thing I can think of that might come close would
be a media-filled one scaled appropriately to hug the surface of the
original object.  Maybe same could be done by using fade_distance in a
semi-transparent copy too.  I just can't imagine fitting them together well
enough.
I'm just brain-storming (hazy sky, more like) because I've always liked the
idea of following the contours of a surface and applying that antiquing
effect. Nothing tangible has ever come of it, so I'm all ears.
Ken <tyl### [at] pacbellnet> wrote in message
news:38158BD5.F0F02B93@pacbell.net...
medals.
Subject: Re: Patina
Date: 26 Oct 1999 08:30:49
Message: <qqmhfje5mo6.fsf@goldach.fmi.uni-konstanz.de>
Ken <tyl### [at] pacbellnet> writes:
I'm not sure whether you're looking for an automatic generation of
patinas or a completely procedural approach. In the first case, you
should have a look at:
Modeling and Rendering of Metallic Patinas
Julie Dorsey and Pat Hanrahan
http://graphics.lcs.mit.edu/~dorsey/papers/patina/
I hope this helps
http://thomas.willhalm.de/
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: 2.6.2i
mQCNAzgBwGkAAAEEAKx6RGDGAhjwr2kEv7Z2oxx2SoYBpMWCN2M76HE0GLHRvvto
RMfuLp+ECPoyutG9DnrwpLGNKwntY10qsWNPZNHZ9obZOtQcZf+hYs+A/283l7Iv
EKtKsggRATbd44NECkkKLuWZzuklNaoSAN7SOnmG94ZpcjZTfIwTzXgp3F/9AAUR
tCRUaG9tYXMgV2lsbGhhbG0gPHRob21hc0B3aWxsaGFsbS5kZT4=
=UScf
-----END PGP PUBLIC KEY BLOCK-----
Subject: Re: Patina
Date: 26 Oct 1999 09:21:03
Message: <3815aabf@news.povray.org>
I have a SIGGRAPH article on just this subject.  Combined with the reference
Thomas posted, it should do just what you want.  The article is called
"Efficient Algorithms for Local and Global Accessibility Shading" and is
by Gavin Miller.  It was published in the SIGGRAPH 1994 Proceedings, but
is not available online.  It talks about how to texture objects based on
their accessibility to cleaning agents - deep ridges and cracks don't get
cleaned as effectively so they gather dirt (or corrosion) over time.
If someone wants to try to implement the techniques in this article, I'd
be happy to scan it and email it to one or two people.  That's in the scope
of the ACM's copyright notice, I believe.  Be warned that it isn't very
well suited to general objects like those in POV.  It does have some good
suggestions for heightfields, spheres, and meshes, though.
And, just to satisfy your lust for links, here's one everyone should know:
http://www2.iro.umontreal.ca/~ratib/code/cg.htm
Besides the content, this link is interesting because it lets you link
deeply but it uses Javascript to reconstruct the original frame structure.
While you're there, pay special attention to the link for Computer Graphics
Publications - that's where I got the title info for this paper (I have the
Proceedings at home.)
(That one should keep even The Great Ken busy for a few hours...)
Subject: Re: Patina
Date: 26 Oct 1999 11:46:05
Message: <3815CD6B.2F823E59@inapg.inra.fr>
The trick recently discovered by SamuelT in his  "chipped paint" series in
p.b.i. could be used for that : create a pigment pattern and then associate a
pigment function as a normal with a properly defined color_map. When the two
match, it gives interesting results. Of course, it will work only with
simulated shallow cracks, not with real 3D crevices and other real surface
perturbations, like folds.
Gilles
Subject: Re: Patina
Date: 28 Oct 1999 08:54:56
Message: <38184653.230BE36C@pacbell.net>
Thank you people for your suggestions and links to possible solutions.
I have come to the conclusion that it would be very difficult if not
impossible with proceedural textures. The mesh painting utilties are
looking like a very real possibilty however...
Subject: Re: Patina
Date: 28 Oct 1999 11:25:33
Message: <8E6DB458Fseed7@212.120.113.81>
>solutions. I have come to the conclusion that it would be
>very difficult if not impossible with proceedural textures.
>The mesh painting utilties are looking like a very real
I've never used it but would slope-dependent textures from the
superpatch be a possibility?
Ingo
Subject: Re: Patina
Date: 28 Oct 1999 11:45:32
Message: <slrn81grov.v8.ron.parker@ron.gwmicro.com>
Even better would be a texture based on the second derivative
of the surface, but such a thing is hard to calculate.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Subject: Re: Patina
Date: 28 Oct 1999 11:50:18
Message: <8E6DB2281seed7@212.120.113.81>
ehm, could you explain this please, in laymens terms?
Ingo
Subject: Re: Patina
Date: 28 Oct 1999 12:17:47
Message: <slrn81gtgd.v8.ron.parker@ron.gwmicro.com>
The first derivative is the slope (roughly.)
The second derivative is the rate of change of the slope. Smooth,
gently curving regions would have a low second derivative, while
sharply curving regions would have a high second derivative. The
curvature of the surface corresponds strongly to its accessibility.
Unfortunately, it's very difficult - if not impossible - to
calculate for CSG objects and some primitives, and it's pretty
meaningless for meshes: the second derivative of a mesh is either
zero or infinite (undefined, really) anywhere on its surface.  A
CSG of two spheres would have the same problem, except that the
curvature would be the radius of one of the spheres or undefined.
The paper I have here goes into excruciating detail on that problem.
One method the paper I have doesn't cover into in great detail is based
on monte-carlo methods: Just fire a bunch of random rays along near-
perpendiculars to the surface normal from locations just "above" the
intersection point with the surface and estimate the local curvature
from the resulting (nearby) intersections.  If there are none, you
can assume that the surface curves away from the normal and the
local accessibility is therefore infinite.
Subject: Re: Patina
Date: 28 Oct 1999 13:02:50
Message: <8E6DC315Aseed7@212.120.113.81>
>Smooth, gently curving regions would have a low second
>derivative, while sharply curving regions would have a high
>second derivative. The curvature of the surface corresponds
>Unfortunately, it's very difficult - ........
Ah, I see. Thanks
The monte-carlo method sounds promising.
Walking home from shopping I had an idea (well, the start of an
idea). Make several copies of the original. Modify each copy
slightly, scale, translate or surface subdivide etc. Then
difference the original and ead each copy, give each new object
a different pigment. Union all objects, slice them up and
make it into a df3-file. Use this as the base for texturing the
original object. Will it work? don't know.
Ingo
Subject: Re: Patina
Date: 28 Oct 1999 18:28:05
Message: <3818CDA7.628094F9@pacbell.net>
I don't know if it will work or not but you sure made my head hurt.
Subject: Re: Patina
Date: 29 Oct 1999 00:47:46
Message: <38192929.6AD7@pacbell.net>
Realy want to make your head hurt? Try calculating the stress tenser
across the event horizon of a black hole!
Ken Matassa
Subject: Re: Patina
Date: 29 Oct 1999 08:00:50
Message: <38199AE1.92FBCCE1@umh.ac.be>
Hello Ken Matassa,
a Schwarzschild or Kerr black hole :).
Fabian.
> Ken Matassa
Subject: Re: Patina
Date: 29 Oct 1999 17:43:38
Message: <381A12C1.8631E86B@aol.com>
Since every intersection has a normal calculation, what if you were to do a
prepass step and store all the normals for the intersections within the
image, then when you render estimate the curvature? I can see that there
might be problems around the edges of the surface, but could this work
somewhat?
-Mike
Subject: Re: Patina
Date: 29 Oct 1999 18:54:43
Message: <381A253A.DCE4364F@peak.edu.ee>
But with mirrors etc. the number of normals to be stored would become HUGE,
requiring massive amounts of memory. Monte Carlo sampling around the curent
intersection would give nearly the same result.
Margus
> somewhat?
> -Mike
Subject: Re: Patina
Date: 29 Oct 1999 20:05:59
Message: <381A341D.E42C9F1@aol.com>
Shouldn't be if you just store the normal at the intersection point of the
surface in question.  There could only be one normal per pixel, which I supposed
could create quite a few limitations.  Ah well, just a thought.
Subject: Re: Patina
Date: 30 Oct 1999 09:44:15
Message: <381af62f@news.povray.org>
There is a plugin for MAX called DirtyReyes which does just this, and very
realistically.  Unfortunately it uses mapping coordinates of the mesh and
thus I don't think could be implimented easily with POV-Ray.
Lance.
The Zone - http://come.to/the.zone
medals.
Subject: Re: Patina
Date: 1 Nov 1999 08:16:43
Message: <381d92bb@news.povray.org>
It's not true that there'd be just one normal per pixel.  It wouldn't be easy to
come up with a scene to demonstrate this, but it could be done.  Basically,
because of partial reflection, a single eye ray can spawn a couple dozen rays
inside the scene, any or all of which could hit the object in question.
