POV-Ray : Newsgroups : povray.advanced-users : Depth output from POVray Server Time
6 Nov 2026 00:28:43 EST (-0500)
  Depth output from POVray (Message 1 to 23 of 23)
Subject: Depth output from POVray
Date: 21 Sep 1999 09:07:13
Message: <37e78301@news.povray.org>
Hi there.
Is there any way to make POV-ray output the depth to a file, instead of the
actual renders? That is, can POV output a Z-buffer sort of thing for import
in other programs?
Simen.
Subject: Re: Depth output from POVray
Date: 21 Sep 1999 09:14:44
Message: <37e784c4@news.povray.org>
This is a VFAQ. Anyone willing to write a comprehensive answer to this so
that I can put it on the page?
Date: 21 Sep 1999 11:31:31
Message: <slrn7uf96j.v8.parkerr@ron.gwmicro.com>
Someone wrote a whole chapter about this in a Waite Group book on making
SIRDS.  I could try to summarize the two methods they mentioned there, since I
have a copy of the book (probably now out of print) or I could just break down
and rewrite the patch I had for POV 2.2 that added this capability without any
serious scenefile modifications (or someone else could - it's just a tiny change
to determine_apparent_colour).
Date: 21 Sep 1999 12:33:30
Message: <37e7b35a@news.povray.org>
Ron Parker <par### [at] fwicom> schreef in berichtnieuws
slr### [at] rongwmicrocom...
this so
making
> SIRDS ....
What is / are SIRDS ?
Ingo
Date: 21 Sep 1999 12:40:18
Message: <37e7b4f2@news.povray.org>
>this so
>making
>> SIRDS ....
Single Image Random Dot Stereograms.  Often known by the trademarked
name "Magic Eye."
Date: 21 Sep 1999 18:46:48
Message: <WgroNzmOZ7X2FDK=ETYWw3peFcbG@4ax.com>
On Tue, 21 Sep 1999 15:09:19 +0200, "Simen Kvaal"
<sim### [at] studentmatnatuiono> wrote:
>Hi there.
>in other programs?
>Simen.
A quick and dirty way is to place the whole scene in a union, give it
a white pigment, an ambient of 1 and diffuse 0, and use black fog to
dim the distant objects. Works quite well for me.
Peter Popov
ICQ: 15002700
Date: 21 Sep 1999 21:17:05
Message: <37e82e11@news.povray.org>
Think I'd use a gradient z pigment instead.  I have one RDS (random
dot stereogram, not RayDreamStudio) program here that accepts the
depth info in Bmp images which I suppose might be simple color
shifting, not sure.  I need to dust it off and give it a try.
Peter Popov <pet### [at] usanet> wrote in message
news:WgroNzmOZ7X2FDK=ETYWw3peFcbG@4ax.com...
> >Hi there.
instead of the
for import
> >in other programs?
> >Simen.
it
> Peter Popov
> ICQ: 15002700
Date: 21 Sep 1999 21:29:59
Message: <37e83117@news.povray.org>
And what do you use it for? How would using this improve my scenes?
Date: 22 Sep 1999 04:25:50
Message: <7ZHoN30Y7JoT=URFG+w9p7XL5DM6@4ax.com>
On Tue, 21 Sep 1999 20:24:27 -0400, "TonyB"
You can use it as a selection in PSP, for example, apply gaussian blur
and have a cheap focal blur. Faster and smoother than POV's, though
not as accurate. Or you could desaturate the image with distance to
get a Rennaissance painting look. Such things.
Peter Popov
ICQ: 15002700
Date: 22 Sep 1999 04:27:41
Message: <V5LoN5TatESKTQfzmmjrCp0Po8Ya@4ax.com>
On Tue, 21 Sep 1999 20:16:01 -0500, "Bob Hughes" <inv### [at] aolcom>
>Bob
A linear gradient will give a very inaccurate result in points not
directly in front of the camera. I sometimes use a spherical pigment.
The problem is that it's hard to get its scale right, especially if
you have a ground plane, but for indoor or single object scenes it is
the best choice.
Peter Popov
ICQ: 15002700
Date: 22 Sep 1999 06:55:13
Message: <37e8b591@news.povray.org>
I am replying to my own post, now, because I've developed a way to do what I
wanted. I hope this could be of use to anyone who needs a depth-buffer from
a pov-ray scene.
I looked at an old pov-zine, and there it was mentioned that if I removed
all texures from the object and applied a deafult texture with gradient
which varies from white (near) to black (far) in the direction of the
looking vector of the camera, then I'd essentially get the depth information
in the rendering. Near points would be white and black points would be the
ones far away.
Some of you asked why someone would want tihis? One answer, (not mine), is
to use then in a SIRDS-program, which requires depth information from the
scene in order to generate the illusion of depth. This method works fine for
that purpose.
However, I wanted a real Z-buffer output. I am testing a shading program I
have written and want to use some objects that I really know what looks
like. I have generated several million random points that form a shape in
three dimensions. POV cannot easily handle  that many spheres, so I've
written a program that makes a Z-buffer and shades the scene from that. In
order to test the performance, I needed som Z-buffers of "real" world
things, like cubes, spheres, torii et.c. Then it would be easy too se how
realistic the shading of the z-buffer was. (It's hard to see with some
smoke-resembling cluod of dots.)
To the point. Here is a scene I wrote this morning (local time):
// beginning of code:
#declare cam_pos = <0,0, -5>
#declare cam_rot = <20, 0, 0>
#declare max_depth = 10;
#declare min_depth = 1;
default {
                        onion
                        color_map {
                                [0.0 color rgb 1]
                                [1.0 color rgb 0]
                        phase min_depth/(max_depth-min_depth)
                        scale (max_depth-min_depth)
                finish { ambient 1 diffuse 0 }
                translate cam_pos
                rotate cam_rot
        location cam_pos
        direction z
        up y
        right 4/3*x
        look_at 0
        rotate cam_rot
box {-1, 1 rotate <50, 40>}
// end of code.
This scene is a general case. I can change the camera position in cam_pos
and rotation in cam_rot and still generate a z-buffer output. If I used a
simple gradient texture, I would have errors. Mainly because of perspective
distortion. Points on the edge of the image which have color w, say 0.8,
would actually be farther away than a point with color w in the middle of
the image. The solution was to use the onion procedural texture, which is
cocentric spheres centered at the origin. For the depth-view purposes, the
texture is translated to the camera location, so that the centre of the
spheres is located at the view-point. Then, it is rotated, if the camera is
rotated to a new place.
By using this method, one can easily verify that a point (x,y,z) with
distance d from the eye, would get the same color as any other point (x1,
y1, z1) with distance d from the eye.
The next problem is scaling of the texture. The texture has originally a
range of 1, that is it wraps from black to white every 1 units from the
centre of the texture, that is the eye in this case. We want to scale it so
that the nearest *visible* point gets a shade close to white, while the
farthest visible point gets a shade closer to black. There must be no
wrapping, or else we would get wrong depth-information.
The solution is quite easy, you scale and offset the wrapping of the texture
with
where max_depth is an estimate of the distance to the farthest point we want
to shade, and min_depth is the distance to the nearest.
The output from this source is an approximate depth-buffer from the scene,
which then can be used as wished.
Simen.
Date: 22 Sep 1999 09:15:26
Message: <37e8d66e@news.povray.org>
>>Bob
>the best choice.
When I wrote my patch I originally wrote it to take the length of
the eye ray (analogous to a spherical gradient) but it seemed to
warp the resulting scene.  When I switched to a linear gradient
(length of eye ray dotted with camera direction vector) it flattened
out.
Another thing that can help, if your SIRDS program supports it (I
have one that does) is to use hf_gray_16.
Date: 22 Sep 1999 17:33:08
Message: <37e94b14@news.povray.org>
Interesting to know. Thanks guys.
Ron Parker <par### [at] fwicom> wrote in message
news:37e8d66e@news.povray.org...
(random
> >>Bob
pigment.
is
> >the best choice.
> out.
Date: 22 Sep 1999 17:48:42
Message: <37e94eba@news.povray.org>
Please forgive me if I'm being ignorant but from what Ron has said
about planar applied rays (sorry Ron, I'm quoting vaguely) versus
spherical it seems the "depth" is not a part of the original
calculations.  Could that be true at all? For instance, a scene gets
figured orthographically first maybe and then any other camera
perspectives are added into that afterward, like a sort of non-ray
warping?
Just curious now.
Simen Kvaal <sim### [at] studentmatnatuiono> wrote in message
news:37e8b591@news.povray.org...
do what I
depth-buffer from
> a pov-ray scene.
removed
gradient
the
information
be the
> ones far away.
mine), is
from the
fine for
> that purpose.
program I
looks
shape in
I've
that. In
world
se how
some
> default {
>         texture {
>                 pigment {
>                         onion
>                         color_map {
>                                 [0.0 color rgb 1]
>                                 [1.0 color rgb 0]
>                 translate cam_pos
>                 rotate cam_rot
> camera {
>         location cam_pos
>         direction z
>         up y
>         right 4/3*x
>         look_at 0
>         rotate cam_rot
> // end of code.
cam_pos
used a
perspective
0.8,
middle of
which is
purposes, the
the
camera is
with
(x1,
originally a
the
scale it so
the
no
texture
> with
we want
scene,
> Simen.
Date: 22 Sep 1999 17:53:31
Message: <37e94fdb@news.povray.org>
>warping?
Nope, not true at all.  The camera type is the only thing that determines
the distribution of the eye rays that are shot into the scene.
My calculations were for a standard perspective camera, as that was the
only kind available in POV 2.2.  They'd do weird things with the newer
camera types.
Date: 23 Sep 1999 05:19:57
Message: <37e9f0bd@news.povray.org>
Great, thanks for making that clear to me.  Camera is the key I guess
a person could say.  I knew of the typical concept of rays going from
camera to scene rather than from scene to camera, just wondered of
that possible final derivitive because it sure sounded like it was a
two step process you were talking about.  I need to stay out of the
logistics of it anyway if I can't work with them  : )
news:37e94fdb@news.povray.org...
gets
> >warping?
determines
the
newer
> camera types.
Date: 24 Feb 2019 19:45:00
Message: <web.5c733a4950a5b280a6ca73bb0@news.povray.org>
> a pov-ray scene.
> ones far away.
> that purpose.
> default {
>         texture {
>                 pigment {
>                         onion
>                         color_map {
>                                 [0.0 color rgb 1]
>                                 [1.0 color rgb 0]
>                 translate cam_pos
>                 rotate cam_rot
> camera {
>         location cam_pos
>         direction z
>         up y
>         right 4/3*x
>         look_at 0
>         rotate cam_rot
> // end of code.
> with
> Simen.
I would like to get depth image and found your solution here. Thanks.
Beyond depth image, I would like to get the coordinates of each pixel.
Do you have any idea to do that? Thanks again.
Best
Shouyang
Date: 25 Feb 2019 10:00:12
Message: <5c7402fc$1@news.povray.org>
> Best
> Shouyang
Hi, If you are willing to compile your own POV-Ray version, and if I
remember correctly, someone in the last year or two created a
fork/branch of POV-Ray on github which created a depth map output.
Unfortunately, while trying to figure out how to search all POV-Ray
forks for the branch on github I triggered some sort of "abuse
detection" thing and I'm for a while frozen out of github search...
Unsure how to really do such a search so maybe I indeed created some
kind of search a problem for github.
It should be at worst you can look through the user-forks for the branch
starting perhaps from:
   https://github.com/POV-Ray/povray/network/members
There have been other patches over the years too, but unsure of the
state of these.
Bill P.
Date: 25 Feb 2019 16:45:01
Message: <web.5c74617750a5b280765e06870@news.povray.org>
> Best
> Shouyang
Hi Shouyang,
Perhaps you could take a look at something a few of us worked on a while back:
http://news.povray.org/povray.tools.general/thread/%3Cweb.5ba183edb47e1707a47873e10%40news.povray.org%3E/?mtop=424641
You could put your whole scene inside a union{} and then use the macro to output
where the ray intersects the scene for each pixel.
Alternatively, you might be able to use the color of the depth map to return a
numerical z-position, and use the x,y position on the screen to give the rest of
the vector info.   Using an orthographic camera would probably make life easiest
here.
So, create a deep gradient texture, apply it to an untextured scene, Then you
can do an x, y nested loop with eval_pigment to determine the x, y, and z
coordinates (within certain limits of accuracy)
Date: 26 Feb 2019 10:10:01
Message: <web.5c75558f50a5b2807d6f44740@news.povray.org>
> > Best
> > Shouyang
> Hi Shouyang,
> here.
Thanks for your answer. Your work on the trace macro is very interesting!
However, I did not know how to do that for all the pixels and output the
coordinates information. Could you please provide a small code example?
(Sorry for this greedy request.) Thanks again.
Date: 26 Feb 2019 20:25:01
Message: <web.5c75e65650a5b280765e06870@news.povray.org>
I'll see what I can work out.
I can't recall where we all left off with this, so I'll have to pick through it
again.  It's good practice anyway  ;)
The thing you want to do is look at the macro call.
pos_finder (SURFACE, CL, LA, Angle, screen_x_position, screen_y_position, 1.0)
SURFACE is the collection of abjects in the scene
CL - camera location
LA - look at
Angle - camera angle
screen_x_position
screen_y_position
1.0 - no idea what this is at the moment.  :D
So basically the idea is to just plop that into a nested x-y loop, and have it
spit out the location vector of where the trace() ray intersects the scene
objects.  Probably the best way if to write it to a file.
I think I had some free time when I was helping to work this out, but less so
now, so it may take a while.
But I'd say that the end goal would be to package it all up into a macro that
will scan the whole view frustum and output the visible surface vectors to a
file.
Might be fun to have the option to write the pigment data to file as well with
eval_pigment, and then reconstruct the scene with pixel-sized boxes or spheres.
Date: 27 Feb 2019 20:57:43
Message: <5c774017$1@news.povray.org>
> LA - look at
> screen_x_position
> screen_y_position
> file.
Shouldn't each pixel have four corners that need to be measured?
Mike
Date: 27 Feb 2019 20:58:25
Message: <5c774041$1@news.povray.org>
> Mike
That was probably a stupid question. :(
Mike
