POV-Ray : Newsgroups : povray.advanced-users : Spirals Server Time
19 Oct 2026 07:17:02 EDT (-0400)
  Spirals (Message 1 to 11 of 11)
Subject: Spirals
Date: 19 Sep 1999 14:31:22
Message: <37e52bfa@news.povray.org>
I wonder how to make spirals in povray.......
I have seen some examples of it in pictures but I wonder how it is done if
it is spirals
is it bending the objects or is it a nuber of objects placed very smartly?
Subject: Re: Spirals
Date: 19 Sep 1999 14:57:57
Message: <37E5321D.804F0A4B@peak.edu.ee>
There is no spiral object in POV, so you have to place objects (or points)
'smartly'. A blob or many spheres would do the trick in official POV. The
Superpatch has the sphere_sweep object which is ideally suited for spirals.
Calculating the points for a straight spiral is easy; bent spirals are something
I'll leave to others.
Margus
> it is spirals
Date: 20 Sep 1999 06:27:06
Message: <37e60bfa@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote:
: There is no spiral object in POV
  But there's a spiral pattern if that's enough.
Date: 21 Sep 1999 08:49:07
Message: <37e77ec3@news.povray.org>
No he wants an actual 3D helical spiral...
Nieminen Juha <war### [at] cctutfi> wrote in message
news:37e60bfa@news.povray.org...
Date: 21 Sep 1999 09:13:43
Message: <37e78487@news.povray.org>
Lance Birch <lan### [at] usanet> wrote:
: No he wants an actual 3D helical spiral...
  How do you know? Strictly speaking he didn't actually say that he wants
a helical _object_ but a helical form. Perhaps he was referring to a
helical pattern of colors.
Date: 21 Sep 1999 11:40:10
Message: <37e7a6da@news.povray.org>
ta da... ;)
Remco de Korte <rem### [at] xs4allnl> wrote in message
news:37E79B5D.D2555C74@xs4all.nl...
wants
Date: 21 Sep 1999 13:04:34
Message: <37e7baa2@news.povray.org>
Lance Birch <lan### [at] usanet> wrote in message
news:37e7a6da@news.povray.org...
> ta da... ;)
> wants
smartly?
Think of a spring.... somthing like that....
Date: 21 Sep 1999 14:57:33
Message: <37e7d51d@news.povray.org>
Coil Generator available from Chris Colefax is probably a fine enough
example : ) but here's another one (courtesy Dave Dunn):
/* Spiral Tap */
// INPUTS
#declare Clockwise = true;
#declare Number_Of_Rotations = 3;
#declare Start_Radius = 10;
#declare Spiral_Height = 30;
#declare Blob_Radius = 1;
#declare Spiral_Color = Red;
#declare Invert = false;
#declare Tip_Over = false;
// DECLARATIONS
#declare Spiral = union {
#declare Count = 0;
#while(Count<360*Number_Of_Rotations)
blob {
threshold .5
sphere
{<Start_Radius-(Count*(Start_Radius/(360*Number_Of_Rotations))),0,0>,B
lob_Radius,1}
#if (Clockwise = true)
rotate y*Count
#else
rotate y*-Count
translate <0,Count*(Spiral_Height/(Number_Of_Rotations*360)),0>
pigment {Spiral_Color}}
#declare Count = Count+1;
#if(Invert = true)
translate <0,-Spiral_Height/2,0>
rotate z*180
translate <0,Spiral_Height/2,0>
#if(Tip_Over = true)
rotate x*90
#end}
object {Spiral}
AC <amb### [at] teliacom> wrote in message news:37e7baa2@news.povray.org...
> > ta da... ;)
that he
> > wants
referring to a
very
> smartly?
Date: 22 Sep 1999 06:40:11
Message: <37e8b20b@news.povray.org>
: ta da... ;)
:> is it bending the objects or is it a nuber of objects placed very smartly?
  He asked for a helical form and then suggested a couple of solutions to
the problem using objects. Perhaps he didn't know that you can also do it
with patterns.
Date: 22 Sep 1999 06:45:58
Message: <37E8B28A.2B4FE81E@pacbell.net>
http://www.geocities.com/SiliconValley/Lakes/5675/utilities.html
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 24 Sep 1999 17:29:43
Message: <37EBECEF.EBB47672@netvision.net.il>
tell me more about smartly blobs and sphere_sweep object.
I never heard of them. I have an old version of povray
> Margus
> > it is spirals
