how many objects povray can support in one scene?
I am making a whole city made out of cards (playing cards) - bridges,
seas, towers and so on. and I am getting worried when I see 800+ objects
and growing...
if 800 is for simple 8 floored house, what would happen about 20 floored
tower and a golden bridge 2 and the land itself? that would be
8,000,000+ objects
> and growing...
> 8,000,000+ objects
Pov can handle it if you have enough memory on your system. I have had
over 1,500,000 objects in one scene before and Pov had no problems
with it.
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Ken wrote in message <37EC0231.FE241C79@pacbell.net>...
>> and growing...
>> 8,000,000+ objects
>with it.
From a quick look at the source code, the limit at the moment appears to be
2,147,483,648 objects, however, this may just be a limitation in the
bounding box code.
Mark
In article <37ec5d43@news.povray.org> , "Mark Wagner"
> bounding box code.
You may want to run on a 64 bit system then...
Thorsten
e-mail: tho### [at] trf de
... with about a terabyte of RAM ...
rc
Thorsten Froehlich <tho### [at] trf de> wrote in message
news:37ecd3f6@news.povray.org...
be
> > bounding box code.
> Thorsten
So that's why my scene won't render...I have 2,147,483,650 objects.....and
they are all critical to the scene. ;-)
--Rainer
Mark Wagner <mar### [at] gte net> wrote in message
news:37ec5d43@news.povray.org...
be
> bounding box code.
> Mark
> --Rainer
I need a larger monitor because I don't even have that many pixels on my screen.
Ken Tyler
Mark Wagner <mar### [at] gte net> wrote:
: From a quick look at the source code, the limit at the moment appears to be
: 2,147,483,648 objects
I wonder why this and not 4,294,967,296.
Is this another example of "should use unsigned integers because negative
numbers are never used, but signed integers are used instead because it's
easier it type 'int' instead of 'unsigned'"?
negative
I've heard it argued that unsigned ints don't have as much cross-platform
support, though I don't know whether it's true or not.
Edward Coffey <e.c### [at] ugrad unimelb edu au> wrote:
: I've heard it argued that unsigned ints don't have as much cross-platform
: support, though I don't know whether it's true or not.
Unsigned integers are (of course) part of the ANSI C standard, so I don't
understand why it should be a portability problem.
It shouldn't be a performance problem. AFAIK in most of currently used
computers signed and unsigned integers are equally fast.
