POV-Ray : Newsgroups : povray.advanced-users : Divide by Zero Error ? Server Time
6 Nov 2026 00:28:36 EST (-0500)
  Divide by Zero Error ? (Message 1 to 20 of 20)
Subject: Divide by Zero Error ?
Date: 8 Aug 1999 20:34:59
Message: <37AE20A5.A80C4782@pacbell.net>
Is this causing a divide by zero error or ? It gets past parsing but
when is gets to building bounding slabs it crashes Pov violently.
camera{location<0,20,20>look_at 0}
light_source{<0,50,100> rgb 1}
#declare Y = 0;
#while (Y < 50)
       #declare X = 0;
       #while (X < 50)
              sphere {
                     <X, Y, sin(X/Y)>, 0.1
                     pigment {color rgb<(sin(X/Y) + 1)/2, 0, 0>}
              #declare X = X + 1;
       #declare X = 0;
       #declare Y = Y + 1;
Ken Tyler
I know you are but what am I ? <Unknown child>
Subject: Re: Divide by Zero Error ?
Date: 8 Aug 1999 22:08:15
Message: <37ae3797.116490116@news.povray.org>
The crash is not a divide by zero error.  I'm not sure what it is, but
it might be a stack fault.  It crashes somewhere deep within the
Visual C++ runtime library for me, in the process of doing a malloc
under a pile of calls to sort_and_split.  In short, I have no idea
what you did here. :)
Date: 8 Aug 1999 23:01:58
Message: <37AE4302.DD6F29C5@pacbell.net>
Do you think it's a bug and maybe someone should report it ? You could
probably word it in programmerese better than I if you feel it is worth
bringing to the teams attention.
Ken Tyler
Date: 9 Aug 1999 02:14:07
Message: <37AE7180.98A70012@gci.net>
I think the arrows(<=========<<<<<<<) will show the problem.
Change #declare X=0; to #declare X=.00001 and it works fine.
> #declare Y = 0; <=========<<<<<<<
> #while (Y < 50)
>        #declare X = 0;
>        #while (X < 50)
>               sphere {
>                      <X, Y, sin(X/Y)>, 0.1 <=========<<<<<<<
> 0>}<=========<<<<<<<
>               #declare X = X + 1;
>        #end
>        #declare X = 0;
>        #declare Y = Y + 1;
> #end
> Ken Tyler
Date: 9 Aug 1999 02:18:40
Message: <37AE7292.D03BDF3D@gci.net>
I can't even read the code right. Change #declare Y=0; to #declare
Y=.00001 and it works fine.
Date: 9 Aug 1999 02:46:28
Message: <37ae7944@news.povray.org>
: #declare Y = 0;
:                      <X, Y, sin(X/Y)>, 0.1
  You should always avoid this kind of divisions.
Date: 9 Aug 1999 02:57:12
Message: <37AE7A11.78219F12@pacbell.net>
> : #declare Y = 0;
  Can I assume this is because before the count is incremented there is
a zero value for the division ?
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 9 Aug 1999 02:57:30
Message: <37af7add.2479942@news.povray.org>
  The quote is Paul Reubens (Pee-wee Herman), probably from the movie
"Pee-wee's Big Adventure". As you may recall, Mr. Reubens was sort of
blacklisted after an incident in an adult movie house involving no one else
but himself. He has washed his hands of that whole affair and has been
working steadily in recent years.
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 9 Aug 1999 03:02:29
Message: <37AE7B4F.20455CC7@pacbell.net>
  I'll grant that Pee-Wee may have used the line but it is by know means his
creation. I know this because I used it myself as a child and that predates
the Pee-Wee character by at least a couple of years :)
> As you may recall, Mr. Reubens was sort of blacklisted after an incident
> in an adult movie house involving no one else but himself. He has washed
> his hands of that whole affair and has been working steadily in recent years.
> Alan
Oh you mean Mr. Trenchcoat. I seem to remember something about that.
Ken Tyler
Date: 9 Aug 1999 03:42:16
Message: <37AE862B.2989040C@gci.net>
Ken,
    Your code let me play some and I will post a picture in the p.b.i.
I think this is sort of what you were after.
Mr. Art
Date: 9 Aug 1999 06:14:38
Message: <37aeaa0e@news.povray.org>
:> : #declare Y = 0;
:> :                      <X, Y, sin(X/Y)>, 0.1
:>   You should always avoid this kind of divisions.
:   Can I assume this is because before the count is incremented there is
: a zero value for the division ?
  Yeah. You set Y to 0 and then calculate X/Y. This causes division by 0,
of course.
  (I don't know if this is what is making povray to crash, but you should
always avoid this kind of problems anyways)
Date: 9 Aug 1999 09:07:57
Message: <37aed2ad@news.povray.org>
Including a part in the wonderful new movie "Mystery Men."  Saw it
this weekend, laughed myself silly.  Some of you will tell me I was
already silly; that may be true. :)
Date: 9 Aug 1999 09:31:53
Message: <37aed849@news.povray.org>
[crossposted to .bugreports, note followups]
Yes, it's a bug.  Anything that crashes is a bug in my book, whether or
not it's due to bad code.  I've copied in the faulty code below, for the
sake of the bug hunters. (The loop on Y wasn't necessary to duplicate
the crash, so I've elided it.)
It may be worth noting that internally POV sets the result of a division by
zero to HUGE_VAL, which is 1e17 by default.  It's likely that some code
somewhere in the creation and subdivision of bounding slabs has trouble with
this huge number, which is something like 2^60.  I don't understand
sort_and_split all that well, I'm afraid.
------------- cut here -------------
#declare Y = 0;
#declare X = 0;
#while (X < 50)
      sphere {
      #declare X = X + 1;
Date: 9 Aug 1999 10:41:00
Message: <37aee87c@news.povray.org>
Ken napisa³(a) w wiadomości: <37AE20A5.A80C4782@pacbell.net>...
>#declare Y = 0;
>#while (Y < 50)
>       #declare X = 0;
>       #while (X < 50)
>              sphere {
>              #declare X = X + 1;
>       #end
>       #declare X = 0;
>       #declare Y = Y + 1;
>#end
Howdy!
I've rendered it with POV 3.02 and 3.1g (both for linux).
3.02 rendered it without any errors nor even warnings, but
POV 3.1g generated some division by zero warnings and when
it came to creating vista buffer, segmentation fault
occured (but I didn't gain root ;)
Wojtek 'ReaveR' Bauman | admin @127.0.0.1 | rea### [at] spleenwawpl |
http://reaver.spleen.waw.pl | Get PGP: finger bau### [at] inxpmwawpl
Key ID: 0xCB173E3E | ICQ: 3429749 | *** POV-Ray  F O R E V E R ***
Date: 9 Aug 1999 15:40:42
Message: <37af2eba@news.povray.org>
In article <37aed849@news.povray.org> , par### [at] fwicom (Ron Parker) wrote:
I suspect it to be a Windows compiler (or memory allocation library) bug. I
tried the scene up to 450 * 450 spheres without any problems, instabilities
or crashes on my Mac.
With a different Mac compiler we got other bugs like this one (not this
specific one!) deep inside memory allocation code or during complex
operations. Also we did extensive seaching we never found the causes and
maybe the size of POV-Ray just shows lots of the little bugs compilers have
to-date :-(
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Creating bounding slabs.
Scene contains 202500 frame level objects; 0 infinite.
Creating vista buffer.
Creating light buffers.
Displaying...
Rendering...
Done Tracing
untitled.pov Statistics, Resolution 100 x 100
Pixels:           10000   Samples:           10000   Smpls/Pxl: 1.00
Rays:             10000   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Sphere                             332             178     53.61
Bounding Box                      3505             333      9.50
Light Buffer                      3539            1053     29.75
Vista Buffer                     43551           24318     55.84
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:              117   Succeeded:                    0
Smallest Alloc:                 26 bytes   Largest:          1620024
Peak memory used:        140421828 bytes
Time For Parse:    0 hours  3 minutes  22.0 seconds (202 seconds)
Time For Trace:    0 hours  0 minutes   1.0 seconds (1 seconds)
    Total Time:    0 hours  3 minutes  23.0 seconds (203 seconds)
-- [AnimFrame] file#:'untitled.pict' frame#:0 clock:0
Reclaiming memory
-- [Stack] Total Stack space used = 8320 bytes
-- [Finish]  File=untitled.pov,  Time=09.08.1999  21:29:57 Uhr
POV-Ray Mac Memory Cache Statistics
Cache hits:                2513256   Cache misses:              8581
Total calls to malloc:     2521837   Cache hit rate:             99%
Date: 10 Aug 1999 03:15:24
Message: <37afd18c@news.povray.org>
In povray.bugreports Thorsten Froehlich <tho### [at] trfde> wrote:
: I suspect it to be a Windows compiler (or memory allocation library) bug. I
: tried the scene up to 450 * 450 spheres without any problems, instabilities
: or crashes on my Mac.
  The fact that a program doesn't crash in certain platforms doesn't mean
that the program is bugless.
  I once made a program which worked just fine in SunOS and Digital Unix
but crashed in a malloc()-call in Linux. Was there some problem with Linux
memory management?
  Not at all! Actually the memory management of Linux was better than the
ones in SunOS or Digital Unix. The bug was in my program (I made an
off-by-one mistake when writing to a table). The memory management of
Linux saw this and crashed the program while SunOS and Digital Unix were
unable to. Thanx to Linux I found the problem and was able to fix it.
  So the bug _may_ be in the program although it works in some systems.
Date: 10 Aug 1999 03:43:48
Message: <37afd834@news.povray.org>
In article <37afd18c@news.povray.org> , Nieminen Mika <war### [at] cctutfi>
> memory management?
Yes, I know. As I said, with a different Mac compiler (= different C
libraries) we get problems like that, too. Unfortunately  you never know
(without knowing where in the code it happens) if a compiler bug or a code
bug causes writing to an invalid location.
     Thorsten
e-mail: tho### [at] trfde
Date: 10 Aug 1999 04:59:10
Message: <37afe9de@news.povray.org>
: Yes, I know. As I said, with a different Mac compiler (= different C
: libraries) we get problems like that, too. Unfortunately  you never know
: (without knowing where in the code it happens) if a compiler bug or a code
: bug causes writing to an invalid location.
  "My code is NOT buggy. The problem must be in the compiler. Or Windows.
Or in intel's cpu. But my code is NOT buggy!" ;)
Date: 10 Aug 1999 06:49:50
Message: <37b003ce@news.povray.org>
In article <37afe9de@news.povray.org> , Nieminen Mika <war### [at] cctutfi>
:-)  "My computer doesn't work, the screen is always dark. The problem is
the OS, the CPU, Windows, and it is all the programmer's fault.  He won't
plug in the power cable for me!"
But serious: Of course we all know that POV-Ray has a lot of small bugs,
like all software of that size has (sad but true). Sometimes it gets worse
because a specific platform/compiler doesn't like a particular bug which is
mostly "harmless" on other platforms.
I.e. on the Mac I recently had to chase a bug that sounds "impossible": When
inserting a CD the POV-Ray core code would abort with an error when parsing
a macro that is in an include file.
Now you say: What does POV-Ray care about CDs? - Nothing, of course! BUT
when mounting the CD the Mac OS would for some reason for a short time
change the global default directory to read from (there is no rule that it
may not). This wouldn't cause any problems using Mac OS file-io (which
doesn't depend on file and path names to find a file "again").  Now, whose
"bug" is it: Is it POV-Ray using standard C io, the Mac OS written in 1983
in Pascal, or the compiler library mapping the standard C io to the Mac file
handling?  Everything contributes to it resulting in a bug...
    Thorsten
Thorsten Froehlich
Date: 10 Aug 1999 07:13:03
Message: <37B0094D.79E95E22@giwersworld.org>
	I would hope he washed his hands afterwards.
Download 'us-ascii' (1 KB)
