POV-Ray : Newsgroups : povray.advanced-users : scale in animation... Server Time
23 Oct 2026 12:49:11 EDT (-0400)
  scale in animation... (Message 1 to 4 of 4)
Subject: scale in animation...
Date: 26 Jul 1999 21:23:37
Message: <379d0a19@news.povray.org>
i'm trying to scale an object for an animation where the object shrinks.
here is what i've tried:
sphere {0,1 pigment {rgb 1} scale 2*(clock+.0001) }
sphere {0,1 pigment {rgb 1} scale -2*(clock+.0001) }
sphere {0,1 pigment {rgb 1} scale (clock+.0001)/2 }
sphere {0,1 pigment {rgb 1} scale (clock+.0001)/.5 }
 the results are always an object that enlarges. does anyone know how i
would scale it to shrink with the clock value?
   thanks in advance,
     jason
Subject: Re: scale in animation...
Date: 26 Jul 1999 21:53:51
Message: <379d112f@news.povray.org>
Jason Dinger wrote in message <379d0a19@news.povray.org>...
shrinks.
scale (1-clock)*factor
when clock is 0 the result is 1*factor
as the clock progresses towards 1 this becomes closer to
0*factor
So things will get smaller
HTH
Have Fun
Martin
me### [at] tesseractcomau
Date: 27 Jul 1999 01:45:14
Message: <379D48E3.25FF33B9@puzzlecraft.com>
There's a completely different technique described in my tutorial "Advanced
POV Animation for Beginners" that allows the use of non-linear clocks as
well as multi-stages, compound clocks and complex paths. Scaling is of
course included in the effects. The tutorial is based on Chris Colefax's
Clock Modifier macro and is very easy to learn.
http://www.puzzlecraft.com/cm/ClockMod.html
steve
>    thanks in advance,
>      jason
Date: 27 Jul 1999 04:53:22
Message: <379D7381.BB13B630@ele.kth.se>
Hej Jason,
here is what you did:
start of animation: clock=0
end   of animation: clock=1
clock=0    scale 0.0002
clock=1    scale 2.0002
clock=0    scale -0.0002
clock=1    scale -2.0002
(same as above but mirrored)
clock=0    scale 0.00005
clock=1    scale 0.50005
exactly the same as number 1, because 1/.5=2
Here is what you could do:
linear
sphere {0,1 pigment {rgb 1} scale 1-clock }
clock=0    scale 1
clock=1    scale 0
slow in the beginning
sphere {0,1 pigment {rgb 1} scale 1-clock*clock }
clock=0    scale 1
clock=1    scale 0
fast in the beginning
sphere {0,1 pigment {rgb 1} scale (1-clock)*(1-clock) }
clock=0    scale 1
clock=1    scale 0
sphere {0,1 pigment {rgb 1} scale cos(pi*clock) }
clock=0    scale 1
clock=1    scale 0
fast in the middle
sphere {0,1 pigment {rgb 1} scale 0.5+0.5*cos(2*pi*clock) }
clock=0    scale 1
clock=1    scale 0
You can even further modify these examples by including the expression
after "clock" in the equation "pow(<expression>,p)" with different
values for p.
1<p   => slower in the beginning, further acceleration to the end
0<p<1 => acceleration in the beginning, slowing down to the end
Or you could simply modify the range of the clock variable with the
commandline parameters "+KI" and "+KF"...
Uwe.
