POV-Ray : Newsgroups : povray.advanced-users : Radiosity Server Time
19 Oct 2026 08:12:54 EDT (-0400)
  Radiosity (Message 1 to 13 of 13)
Subject: Radiosity
Date: 27 Jun 1999 09:14:41
Message: <377623c1@news.povray.org>
I'm trying to find proper radiosity settings for an indoors scene.
However, no matter what I do, I get one of the following:
  1. Very blotchy illumination, like someone was throwing paint on the
walls at random.
  2. Quite smooth illumination but somewhat grainy and extremely annoying
small dark spots in corners.
  I get the second type of illumination with settings which take centuries
to calculate (in my P-II 350MHz). If I use a little bit faster settings
I get the first type of illumination.
  Those dark spots in the second case appear no matter how small
error_bound I specify (I have gone as small as error_bound 0.05).
  The distance_maximum seems to be the key value which controls how much
the image goes to the first or the second case. With large distance_maximum
values the image gets blotchy while with small values it gets grainy.
I have tried several values between 1000 (the room is about 200 units wide)
and 1. With very small values the render time blows up and the walls look
like they had a finish { crand .2 }.
  The rendering time doesn't matter, but I just can't get rid of the
graininess and the annoying dark spots in the corners. The only way I
can do this is setting so bad values that the image gets blotchy, but that's
not a very good solution.
  Does anyone has any good advice?
  It's funny that I got really good values for the radiosity test images
in my web page, but I can't find them for this image (of course the settings
for those radiosity test images do not work with this image).
Subject: Re: Radiosity
Date: 27 Jun 1999 18:56:18
Message: <3776AC08.709A82A@aol.com>
Check into 'minimum_reuse'. Is it set too low or too high? Default being 0.015. This
value apparently depends a lot upon the image size as I understand it, pixel to pixel
plotting on the screen sort of thing. Though I could be wrong.
Quoting from the Scene Help file:
 This sets a minimum bound for the reuse. If this value is too low, (which it should
be
in theory) rendering gets slow, and inside corners can get a little grainy. If it is
set
too high, you don't get the natural darkening of illumination near inside edges, since
it reuses. At values higher than 2% you start getting more just plain errors
Unquote.
> walls at random.
 mailto://inversez@aol.com?Subject=PoV-News
Date: 27 Jun 1999 19:15:32
Message: <3776B0BE.AD763328@peak.edu.ee>
That would be a tough question even had I got your scene to test. A few things I
would do:
1) If there are no small objects, I use a distance_maximum thats around 5-25% of
the size of the room;
2) Try increasing minimum_reuse a bit - this should reduce graininess, but it
also tends to make corners too bright;
3) Use nearest_count of 10.
Remember also that a larger distance_maximum requires more rays to get accurate
results near objects.
In my experience, some blotchyness/graininess will always remain, unless you use
crazy settings (which you apparently have done)
Margus
Date: 28 Jun 1999 12:31:25
Message: <3777A3F7.3A84A09@inapg.inra.fr>
The problem seems to be that radiosity, like media, is distance-sensistive (i.e.
it performs differently at different scales). Apparently, the best distances
(meaning the size of the room for instance) are the ones used in the radiosity
example, so I use them as a basis. What I do is to give a general scale to the
whole scene (including the lights and the camera) and use this general scaling
factor to tune the picture for the best quality vs render time. I ran in exactly
the same problems as the ones you mention (plus the fact that a very low
error_bound seemed to crash the picture due to a lack of memory) and these
problems disappeared using the standard radiosity settings (in rad.inc)  with
the "right" distances. And the good news was that radiosity was not that slow. I
also noted that some radiosity artifacts are nicely smoothed by antialiasing.
I hope this helps.
Gilles
> walls at random.
Date: 29 Jun 1999 02:35:41
Message: <3778693d@news.povray.org>
Any idea how to rescale the whole scene (with thousand of objects)?
Date: 29 Jun 1999 04:01:29
Message: <37787DFA.9F05EFF8@inapg.inra.fr>
#declare sc=10;
//#declare sc=0.10;
union{
    all objects here
    scale sc
camera{
    location PointLoc*sc
    camera stuff
    look_at PointLook*sc
light_source{PointLight*sc color LightColor}
There may some other scaling involved if you use fog or fade_distance but it
should be straightforward. Media will be a problem, though.
G.
Date: 29 Jun 1999 11:06:07
Message: <3778e0df@news.povray.org>
There should be a keyword in povray like:
global_settings { global_scale .1 }
Date: 29 Jun 1999 11:11:10
Message: <3778E170.4930F9A0@pacbell.net>
  It might help all of those people that keep trying to model the solar
system in real world units and then run into the problem of max epsilon
values being exceeded.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 30 Jun 1999 05:11:58
Message: <3779DF36.CACD40B5@powersurfr.com>
why is there a max value anyways i wanted to make a solar system animation
> Ken Tyler
Date: 30 Jun 1999 07:01:35
Message: <3779f90f@news.povray.org>
Noah A <vip### [at] powersurfrcom> wrote:
: why is there a max value anyways i wanted to make a solar system animation
  The computer can handle only finitely large numbers.
  In a typical 32-bit computer (like PC) a floating point value takes 32
bits and a double value 64 bits. As you can see, they can only represent
certain amount of different values (which should go from as small values
as possible to as large values as possible with as small steps as possible).
  With a 64-bit value you can represent pretty large amount of numbers, but
only a finite amount of them (and sometimes a too little amount). With
these same 64 bits it should be possible to represent numbers like
0.000000001 and 100000000.
  Also the resolution has to be limited. You may be able to represent the
number 100000000 and the number 100000002 but not the number 100000001
because there's not enough bits for such a detailed precision.
  This precision problem is the reason why we need an epsilon value. Suppose
the previous case. If we have a=100000000 and b=1 and we calculate their
addition a+b, the result is not 100000001 because it can't be represented
in the floating point format, but the result is 100000000 instead.
Because of this comparing two floating point numbers together may be
pretty inaccurate. So what we do is making the comparation with certain
precision. This means that if two numbers are close enough to each other,
they are considered the same. The epsilon value states this precision.
  There's absolutely no need to represent the solar system taking a metre
as the measure unit. You can perfectly use, for example 1000 km as the unit
or even 1 AU (Astronomical Unit, ie. the distance from the Sun to the Earth).
  Actually it doesn't make sense to use a too small unit because you don't
have the distances between planets at that precision. You will only be
wasting valuable bits. It's like taking the micrometre as measure unit when
all the distances are measured in metres. There will only be six useless
zeros after each value.
Date: 1 Jul 1999 03:45:08
Message: <377b1c84@news.povray.org>
One day I'll actually look at the source myself (I've got it lying around on
some partition somewhere), 'till then, can anyone tell me what precise
format POV does use? Is it 32bit, 64bit or something else?  Does this vary
from platform to platform?  If it is less than 64bit, when will this be
changed?
Date: 1 Jul 1999 05:04:54
Message: <377b2f36@news.povray.org>
Edward C. <edw### [at] hotmailcom> wrote:
: One day I'll actually look at the source myself (I've got it lying around on
: some partition somewhere), 'till then, can anyone tell me what precise
: format POV does use? Is it 32bit, 64bit or something else?  Does this vary
: from platform to platform?  If it is less than 64bit, when will this be
: changed?
  AFAIK povray uses the 'double' type for most of its floating point
calculations. This type is 64 bits in most computers.
Date: 9 Jul 1999 09:35:41
Message: <3785FAB2.9124D3A4@aol.com>
You might try upping the count value, as this will improve the quality. Also,
I've found that a good trick for setting distance_maximum is to use one third of
the distance between the camera location and the look_at. Finally, if you add a
bit of normal to your wall, like a bozo .2, the shadow banding is much less
noticable.
> walls at random.
