POV-Ray : Newsgroups : povray.advanced-users : non hollow my arse mr. pov!!!! aaarrrrggghh! Server Time
6 Nov 2026 01:51:04 EST (-0500)
  non hollow my arse mr. pov!!!! aaarrrrggghh! (Message 1 to 14 of 14)
Subject: non hollow my arse mr. pov!!!! aaarrrrggghh!
Date: 10 Jun 1999 22:46:49
Message: <37607853.5D360355@powersurfr.com>
any one know why when i have a set of planes like the diagram below i
can't use fog it says camera in non hollow object "o" is the campera
looking at the smi transpetant planes
               yyy
o               | | |
_______  | | |_____z
________| | |_____z
________| | |_____z
Subject: Re: non hollow my arse mr. pov!!!! aaarrrrggghh!
Date: 10 Jun 1999 23:25:23
Message: <376081A3.E8A541AE@geocities.com>
It might be because your planes are pointing the wrong way. One side of
the plane might be considered the inside.
>                yyy
> o               | | |
> _______  | | |_____z
> ________| | |_____z
> ________| | |_____z
Date: 11 Jun 1999 04:27:57
Message: <3760c88d@news.povray.org>
Planes are solid objects. They are as solid as a sphere or a box.
The plane divides the world into to parts: one side is outside and the
other side is inside. A plane is like a floor. You can stand on the floor,
ie. you are outside the floor, or you can dig a hole in the floor and go
inside it.
  The normal vector of the plane points _outside_ the plane. This means that
the direction of the normal vector is significant.
  It the normal vector of the plane points towards the camera, then the
camera will be outside the plane. If the normal vector points away from
the camera, then the camera will be inside the plane.
  It's as simple as that.
  PS. I have always wondered, why many people is confused with planes.
I understood the solidness of planes since the very first time I read
about them in the pov documentation. I have never got confused about
it.
Date: 11 Jun 1999 05:06:06
Message: <3760CEC0.A84FEB0@pacbell.net>
> it.
 I think a lot of people think of a plane object as an object similar to
a piece of paper with no deminsions in two directions but a finite
thickness. It is this misconception that causes the confusion.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 11 Jun 1999 08:21:40
Message: <3760ff54@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
:  I think a lot of people think of a plane object as an object similar to
: a piece of paper with no deminsions in two directions but a finite
: thickness. It is this misconception that causes the confusion.
  Perhaps "plane" should be changed to "infinite_box".
Date: 11 Jun 1999 08:34:39
Message: <37610212.A8D8B636@tiac.net>
Somehow, "Reflective sphere over checkered infinite_box" doesn't quite have
the same ring to it.. *grin*
Date: 11 Jun 1999 09:08:27
Message: <3761078F.1720B5DB@pacbell.net>
 I agree that certain eshetics must be maintained and this is one of them.
Besides "plane" is much easier to type than Warp's alternative identifier.
Ken Tyler
Date: 14 Jun 1999 01:40:32
Message: <37649460.7518D5F1@pool.informatik.rwth-aachen.de>
maybe "half-space"? BTW, would a very big box render faster than a plane
or vice versa?
Just curious,
/PETER/
Peter Santo (PUMP development)
Visit: http://www.ieee.rwth-aachen.de/mp3/
Date: 14 Jun 1999 01:50:04
Message: <3764980c@news.povray.org>
Peter Santo <san### [at] poolinformatikrwth-aachende> wrote:
: maybe "half-space"? BTW, would a very big box render faster than a plane
: or vice versa?
  I have always noticed, that planes are strangely slow to render, while
boxes are much faster, and I have always wondered why. In a box, you have to
test the intersection with 8 sides while in a plane you have to test the
intersection with just one side. If you make 50 big boxes it surely will
render faster than 50 planes.
  Can anyone explain why is this?
Date: 14 Jun 1999 06:59:19
Message: <3764DEDF.ED0EFE96@aol.com>
Maybe because planes are bounded larger?   I never really compared them, but
that's my guess.
-Mike
> : or vice versa?
Date: 14 Jun 1999 19:33:25
Message: <376590FA.940B897C@powersurfr.com>
wow i'm all glad ya had fun with my question hehe :)
>                yyy
> o               | | |
> _______  | | |_____z
> ________| | |_____z
> ________| | |_____z
Date: 21 Jun 1999 14:53:38
Message: <376E8ACF.BF8597A7@giwersworld.org>
> : or vice versa?
	I have not looked at the code but descriptions of how it works
in the docs suggests one of the first things it does before
rendering is check for bounds. That should result in faster
computation such as like precomuting tpi=2*pi when 2*pi is used
thousands of times.
	An infinite object like a plane does not have bounds and so
there can be no precomputing for speed.
Download 'us-ascii' (1 KB)
Date: 22 Jun 1999 01:49:44
Message: <376f23f8@news.povray.org>
Matt Giuer <mgi### [at] giwersworldorg> wrote:
: 	I have not looked at the code but descriptions of how it works
: in the docs suggests one of the first things it does before
: rendering is check for bounds. That should result in faster
: computation such as like precomuting tpi=2*pi when 2*pi is used
: thousands of times.
  A single box object does not have a bound, and even if it did, it would
be a... box!
Date: 22 Jun 1999 02:32:53
Message: <376f2e15@news.povray.org>
Yes it does... it's auto bound for the vistas.
Or at least that's what I thought... (switch on vista display and you should
see the auto bounds)
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
For a totally different experience, visit my Chroma Key Website:
Colorblind - http://listen.to/colorblind
